Question about Hobart 24 in. LXIH-3 Built-in Dishwasher
Hobart LXiH preesure gauge is to low - 7 PSI
This Hobart LHiH machine has been in use for >3 yrs. The pressure gauge on the dishwasher reads 7 PSI during the fill and rinse cycle (zero all other times). Per the manual it should be between 15 -25 PSI. The manual also states that the incoming pressure should not be above 25PSI and if it is a regulator should be placed in-line. The incoming line pressure is 45 PSI and no regulator was placed in-line...obviously not to the manual recomendation but that's the way it was. We just placed a regulator in the line and the pressure is not regulated to 25 PSI. A plumber and I tried to troubleshoot the dishwasher and verified that the pressure gauge and main solenoid is working properly. We couldn't understand how backpressure is supposed to be placed on the gauge to allow the pressure to read 25 PSI. What part of the system provides the backpressure? Is it the heater booster? Or some other small oriface in the line? The parts catalog didn't show anything to provide backpressure.
As a side note when the system was operating with no regulator (45 PSI input) the gauge on the dishwasher read 12 PSI. With the 25 PSI regulator it reads 7 PSI. I hope we didn't damage anything due to the high pressure.
  • 41 Answers
Adjust your prv if you screw it in all the way replace it . make sure your new one has a bypass built in
Posted on Dec 07, 2008
  • 4 Answers
Todd - A pressure regulator will REDUCE pressure only. There is no back pressure - the machine's gauge is reading the incoming water pressure as it fills/rinses. Assuming the gauge is OK, the machine is only seeing 7 psi. There is an inline strainer in teh machine, check that for blockage. You said the machine was operating on 45 psi with a reading of only 12 psi. There may be some kind of pressure reducer - I have seen Hobart use special supply hoses with builtin orifices.
hope this helps, if not email me, i service commercial machines and came across your question as I was looking for help myself!
dishwasher in subject line
Posted on Nov 26, 2008
Hobart LXI-H rinse doesn't work
water flow pressure needs to be a min. of 15 PSI..
Apr 26, 2012 | Hobart 25 in. LXIH-4 Built-in Dishwasher
I have AM14C Hobart dishwashing machine and when the rinse turns on we only get about 5 PSI, how do I adjust the pressure or what do I need to look at?
the pressure regulator turn screw clockwise to turn up pressurre.But the line strainer could be plugged do you have bad water.Is the gauge can get a gauge at home depot for cheap.0 to 60 psi should be ok.usually made by dont have to use a hobart gauge.
Apr 22, 2011 | Hobart 42 in. AM14C-154 Free-standing...
Starts ok wrench appears heats ok wash cycle pressure strong at first then fades wrench appears -p2 -cleaned screens and checked spray arms .incoming water pressure 20 psi whats wrong ?
Check the spray arm. Machine water pump. After this pump pressure
builds up to the spray arm. Rubber hosejunction inside the wash tub.
This place gets connected to the spray arm system.
You can see this when you draw the tray for loading vessels.
Slowly push it and watch the junction where this gets locked into the
rubber hose mouth inside the wash tub. There should not be any
water pressure leak.
Sep 17, 2010 | Hobart 24 in. LXIH-3 Built-in Dishwasher
I have a hobart lxih that is leaking from the backflow valve even after replacing it
Make sure your flow pressure is 15 to 25 PSI. Flow pressure below 15 PSI will cause the vacuum breaker to leak.
Jun 18, 2010 | Hobart 25 in. LXIH-4 Built-in Dishwasher
Hobart AM 14 model pressure rise
Are you refering to the water pressure gauge near the top of the unit?
If so, during the final rinse/sanitize cycle the gauge should read between 15 and 25 psi.( flow pressure ) and is usually controlled by a water pressure regulator piped into your plumbing near the machine. Once the cycle has finished, it's normal to see the gauge register much higher pressure readings ( static pressure ) This is the water pressure being supplied to your building. Pressures of 60psi+ are not uncommon. What, I think, you're describing is normal.
All the best.
Oct 23, 2009 | Hobart Dishwashers
E-2 Error on LX30 Hobart Dishwasher
E-2 error is a fill problem. Water did not reach the lower probe within the time out. (innitial fill only
1- Is the bottom probe clean?
2- No fill water (check valve, hose,fill screen in end of hose, and fill source.)
3- low water pressure, should be 20 PSI flow.
4- Fuse 1FU blown.
5- Check wiring to fill valve.
6- Check relay board function.
Feb 15, 2009 | Hobart 24 in. LXIH-3 Built-in Dishwasher
Hobart dishwasher model LX30H; displays wrench and E4.
Water is not to top sensor in alotted time.
Top sensor is in right rear corner, and is the upper of the two. Check the connector to the probe on the outside at the back. (sometimes gets wet fro vacuum breaker leaking when dirty or low flow pressure. Machine needs 20 psi flow rate
Dec 11, 2008 | Hobart 24 in. LXIH-3 Built-in Dishwasher
Hobart lxih
E4 indicates water level has not reached top water sensor. Check for proper flow-water pressure to machine (15-25psi) and clean sensor in wash tank
Jul 16, 2008 | Hobart 24 in. LXIH-3 Built-in Dishwasher
Hobart lx30 E3 error
Error Code E3 relates to a problem with the fill. Specifically that the water level has not been recognized at the middle water sensor. This can be caused by a problem with the drain system as you describe, or by low water pressure to the machine (should be 15-25psi flow), or bad wire connection to this middle sensor.
Check for proper water pressure first (should be a gauge on the machine) during the fill. Then check / repair drain as needed. These will probably eliminate the problem
Jun 19, 2008 | Hobart 24 in. LXIH-3 Built-in Dishwasher
Hobart 24 in. LXIH-3 Built-in Dishwasher Logo
432 people viewed this question
Top Hobart Dishwashers Experts
Garth Jackson
Are you a Hobart Dishwasher Expert? Answer questions, earn points and help others
