Question about AEG B1180-4 Electric Single Oven
NEFF HOB NEFF ELECTRIC HOB HEATS ONLY FOR UPTO 15 MINUTES AND THEN AUTOMATICALLY SWITHES OFF. IT IS POSSIBLE TO USE THIS AGAIN ONLY AFTER HOB COOLS DOWN, AGAIN IT CAN BE USED ONLY FOR ANOTHER 10-15 MINUTES.
  • AEG Master
  • 5,568 Answers
Your heater is probably equipped with a bimetal thermal switch to prevent overheating and, if it is like most made in China now, it is defective or at least highly inaccurate. If you can locate the device, using a metal shield to divert some of the heat will help it serve its original function as a safety. Look for a thick (4-5 mm), button-like device with two terminals and a diameter of 1.5-2.0 cm.
This point of failure is shared with a majority of drip coffee makers that fail way too early.
Posted on Oct 18, 2008
What size cable and fuse do I need to run a Neff oven 3.68kw. and induction hob 7.2kw together ?
Divide the total load by the volts available ie. 11kw by 240v or 110v, the result is current in amps. You need a cable of a suitable cross section to transmit that amperage. There is also a distance calculation to be considered as this affects the available load. Get a sparkie to guide you as to correct sizing.
Nov 04, 2014 | Neff Ovens
Hi, 3 of the 4 oven hobs have failed to work on the 720ef. only 1 of them heats up now. when you turn the knob of the failed hobs only 1 out of the 3 makes the click noise but still doesnt heat up,...
Normally the 720ef is the oven, the hob is a separate unit and in my case is a STOVES 600G gas unit. Your unit may have a built on hob but the handbook for the 720ef does not detail this. In my case the hob ID is on the lower right hand side of the unit.
I think you will find that the elements may have failed but you will need to identify the hob to ensure correct replacements. Normally the element rating is on the base of the element. The handbook will tell you how to take the thing to pieces. It is possible that the hob element controls have failed but unlikely for all three or it may be a combination of both parts. I think you may have to contact an electrician to test everything to sort this out.
Mar 08, 2011 | Stoves 720EF Electric Double Oven
Do all neff oven & hobs have to wired in using 6mm cable or can they be wired into a13 amp system
If it is a single oven on it's own then it can be used from a 13 amp plug and socket, the same with the hob, if it is seperate from the oven it can be used from a 13 amp socket.
If it is a combined unit, then it will have to be hard wired to a seperate circuit using 6mm twin and earth cable, and fused on it's own circuit.
Nov 07, 2010 | Neff B1421 Electric Single Oven
Is this oven suitable to have a Induction Hob
Provided there is a space between the top of the oven and the hob, it should present no problem.
You will of course need a seperate plug outlet for hob
May 21, 2010 | Neff B1421 Electric Single Oven
Neff u1421 bottom oven: Either fan works but no
You need to replace the oven fan element, as there is probably a seperate element in use when used on convection heat.
Please rate my solution.
Thanks.
Oct 24, 2009 | Neff U1421 Double circotherm Electric Oven
No Instruction manuals
Down load them from Neff.
http://www.neff-home.com/uk/service/manual
Then you can print them.
Aug 04, 2017 | Neff Ovens
Oven switching off
Hello, this is a commom problem. The cooling fan is not working correctly and you need a new controller. The part number is 8996619267611 and costs about £28.00.
Nov 11, 2006 | AEG B1180-4 Electric Single Oven
AEG B1180-4 Electric Single Oven Logo
162 people viewed this question
Top AEG Ovens Experts
ashburton
Sal De
Steve
Are you an AEG Oven Expert? Answer questions, earn points and help others
