Question about T-Mobile Wing™ Smartphone
T-Mobile Wing won't turn on
It won't power up or charge up... i tried resetting it and everything and it still doesn't turn on
    Problem Solver:
  • 7 Answers
Take it to store to make sure that it's not a faulty battery or charger.those can be replaced easily.but the issue can also be the charging hub.......it could have separated from the mother board or simply be worn.in any case.....take it to a t-mobile branch for some simple testing.hope this helps.
Posted on Oct 28, 2008
My wing t-mobile display was locked. And what
You need to do a hard-reset. This will erase your added content (third party programs stored in phone memory, notes store in phone memory, etc.)
You must press the reset button while pressing the left and right soft-buttons at the same time. You need your stylus or something small enough to press the recessed button next to the volume control. Once you press the reset button, keep holding the soft buttons it is reset. The display lock should be gone... as well as everything else you put on it.
Hope this helps,
Bill
Mar 27, 2010 | T-Mobile Wing™ Smartphone
My tmobile wing doesnt turn on even when plugged to the ac please help my brother inserted a memory card into it and suddenly turne off now it doesnt charge or turn on not even the red light comes on
you need to buy a new battery go to tmobile and they will have them their if you are still under warenty or your phone is insured it sould be free but if not it will be li 15 to 30 bucks
good luck!
Jul 08, 2009 | T-Mobile Wing™ Smartphone
T mobile wing
The T-mobile wing,which won't make a sound anymore. You'll wanna back up your content to your PC using the software provided. Active Sync Window 6.0. You can dowload it from www.htic.com/activesync for free. Just connect via USB cord. Once that is all backed up, do a hard reset.
aster Reset for a HTC Pocket PC: Warning: Performing a Hard/Master Reset will remove all of your data (settings, files, 3rd party applciations, etc.) from your device and will only reload the Windows Mobile Software and components. The method for Hard Resetting/performing a Master Reset on HTC devices can vary by model. Below are the instructions for the most common method. If these steps do not work for you, consult your user manual or contact your wireless carrier for additional assistance.
  • With the device powered on, press and hold the Left and Right Soft Keys.
  • Whilst holding the Left and Right Soft Keys, perfrom a Soft Reset on the device by inserting the stylus into the reset hole.
Feb 04, 2009 | T-Mobile Wing™ Smartphone
Tmobile wing frozen
Turn off your mobile and then pull out the storage card, Restart your device, it should work now !!!
Jan 10, 2009 | T-Mobile Wing™ Smartphone
My password is not unlocking my t wing
you need to do a hard reset. this will reset the phone but it will also delete all memory
!- hold the two soft key(upper right and left key on keypad under screen)
2- while holding soft keys, insert stylus rset hole next to charging port on bottom of phone.
3. you will be given option screen to clear memory
Nov 04, 2008 | T-Mobile Wing™ Smartphone
Tmobile wing windows media player wont open
try a soft reset.......if this does not work.......then a hard reset, BACK UP FILES BEFORE HARD RESET.......if none of this helps then back to HTC service center it goes.
Oct 26, 2008 | T-Mobile Wing™ Smartphone
Unable to sync my T-Mobile Wing with computer
The T-Mobile Wing is not compatible with Windows Mobile Device Center vr. 6.1
My computer had updated itself to the higher version during a Windows update a few weeks ago.
Once vr. 6.1 was uninstalled, and vr. 6.0 was reinstalled, I was able to sync my Wing again.
Jul 01, 2008 | T-Mobile Wing™ Smartphone
Hard Reset Wing
Hold down both soft keys (both above the send and end key's) and use the stylus to push the reset button in between the volume key and micro sd slot. Then the screen will turn on and tell you something to the extent of press "Send" to perform a factory reset. Hit send, and your good to go.
Apr 24, 2008 | T-Mobile Wing™ Smartphone
Button stuck?
or course, powercycle....if that doesnt work, a master reset will be needed.....because it sounds like there might be somehitng stuck on the screen in the corner for make it scroll around, clean the screen with a qtip and rubbing alchohol.....if that doesnt work, try a software reset. with the phone off, you will have to press and hold the button withthe lines on them and press the power button.....release the powerbutton.....the phoen should turn on and go to a black screen with white writing....release the soft keys here and press the green call button...it will reset the phone, but in turn, you will loose your info that is not stored on the sim or media card...
this is hard to do, so if you can navigate through the phone go to start, setttings, system, clear storage. it does the same thing. good luck :)
Dec 31, 2007 | T-Mobile Wing™ Smartphone
T-Mobile Wing™ Smartphone Logo
44 people viewed this question
Top T-Mobile Computers & Internet Experts
MUSTAFA BULENT...
MUSTAFA BULENT...
matt
matt
Are you a T-Mobile Computer and Internet Expert? Answer questions, earn points and help others
