Validating identity I have a laptop connected to a wireless belkin router and under status it says validating identity. Why is this happening? connected through to internet but still is attempting to "validate identity"
  • racs31 May 11, 2010
    Which operating system are you using
SOURCE: validating identity
To fix, you go into the properties page of your wireless connection, go to "Wireless Networks" tab and then to Properties of the chosen wireless network you are trying to connect to. Then go to "authentification" tab and untick the box saying "Enable IEEE802.1x to the availiable network" and that should solve your problem
Graham
UK
Posted on Jun 21, 2008
SOURCE: hawking extender hangs
They just issued new firmware: http://www.hawkingtech.com/support/details.php?CatID=32&FamID=105&ProdID=394#Firmware
You might try that...
-Tom-
Posted on Dec 31, 2008
  • 12 Answers
SOURCE: i need to make our internet connection secured
this link should show you the steps to securing your wireless connection:
http://www.belkin.com/support/article/?lid=en&pid=F5D8233-4&aid=10177&scid=0
Posted on Feb 18, 2009
SOURCE: problem in wireless connection and showing limited access
typing incorrect password weather in wireless setting or in computer
Posted on Aug 22, 2009
SOURCE: Belkin N Wireless Router - wireless light no longer lit up
Just in case it helps anyone else, I just had to toggle between broadcasting SSID and fixed the problem.
Posted on Sep 30, 2009
Validate identity
BELKIN ::::
WIRELESS SECURITY ISSUES
Step 1 : Connect Router - Computer ( Wired)
Step 2 : Open Router Setup by typing http://192.168.2.1 on the address bar of internet explorer
Step 3 : On the left under wireless click wi - fi protected setup
Step 4 : Leave the password blank and click on submit
Step 5 : Disable it and Click on apply changes
Step 6 : On the left under wireless click Security
Step 7 : Enable 64 Bit WEP
Step 8 : Type a 10 digit number on the key 1 ( 2 in each box )
Step 9 : Click apply changes
Step 10 : on the left under wireless click channel and SSID
Step 11 :Change the Wireless channel to 6
Step 12 : Change the SSID to a different name ( no Spaces )
Step 13 : Click apply changes
Step 14 : Now Scan and connect to this network ( Wireless )
Let me know if it works
Regards
TOM
Jan 31, 2011 | Belkin Basic Wireless Router
I have a cisco by linksys and i have validating indentity went a enable on seting and my labtop came up but i still have validating identity when i start up lab top status connection will this go away if...
you will have an option called wifi protected setup(wps)...You need to disable this particular feature...
This feature when enabled gives the error message like "validating identity"...
or by the other way instead of disabling the wps, you can add the network manually by entering the network information like ssid, password and security type...
This will also help....
This is a 100% proven solution for validating identity....
Because I directly work for Belkin....
Dec 11, 2010 | Belkin (F5D5231-4) Router
My wireless connection is showing the status of Validating Identity after installing my new netgear Router. What should I do
Please follow the steps as mentioned in the below link to resolve the issue:
Validating Identity
If you need any further assistance then please let me know.
Regards
Anand
May 20, 2010 | NetGear WGR614 Wireless Router
The router status is saying 'validating identity'. One of the computers in the house is able to connect, but the other one won't.
The computer that will not connect does not have security settings that match the router settings. You need to consult your router manual, determine what those settings are on the rounter, then go into your control panel and under "wireless" set them to match.
Jul 13, 2009 | D-Link Computers & Internet
Laptop says validating identity
Right click on wireless network connection and go to properties. From the Wireless Networks tab, choose your wireless network and then click Properties.
Click the Authentication tab. On the Authentication tab, Uncheck"Enable IEEE 802.1x authentication" for this network check box. and click oK.
Now reconnect to the wireless network and you will be able to connect to it.
IF you still face issue then please enable WPA encryption on the wireless router and that should work fine with both the laptops.
Rate it, if it helps.
Jun 27, 2009 | Belkin Computers & Internet
Cant find certificate for wireless
Jun 14, 2009 | Belkin (F5D5231-4) Router
D-Link Wireless: validating identity
I believe this has to do with your automatic router/setup for wireless networks....but this is what I did to clear the same problem:
1) Right click on the tray icon that is searching for validation and select status.
2) A "Wireless Network Connection Status" box will open, click "Properties".
3) Your "Wireless Connection Properties" box will open showing the Wireless Networks available. Find the wireless network you are connected to and highlight it by clicking once, then click "Properties" just below.
4) Another box will then open with the properties for your network. Click on the "Authentication" tab.
5) Un-check the "Enable IEEE 802.1x Authentication...." checkbox.
You're good to go.... :)
Jun 17, 2008 | Computers & Internet
Validating identity
Graham
UK
Jan 20, 2008 | Belkin (F5D5231-4) Router
Computers & Internet Logo
615 people viewed this question
David Payne
David Payne
