Question about HP LaserJet 2100 Printer
Laser Printer All of a sudden it started printing smudges on the page. Does that mean the toner is running low or something else? The printed part looks fine, not faded or anything.
  • rebshaw Jan 11, 2008
    Every page has a smudge and it's right down the middle. Replacing the toner cartridge didnt help. I havent tried to replace the fuser yet.
    Sergeant:
  • 279 Answers
When the paper is fresh out of the printer, does the ink that looks okay smudge if you rub it with your finger? If so, it means the fuser is going bad. Otherwise, it's probably a bad toner cartridge that's leaking toner onto the paper.
Posted on Aug 28, 2007
How do I fix my Samsung Multi-function laser printer which has started to print smudged pages.
try to stop the sheet just before it enters the fuser and see if the marks are on the paper already. if not then it has to be the fuser if they are them you have another issue.
Jan 15, 2015 | Samsung CLX-3175FN Color Laser All-in-One...
Smudge line on side of page
Smudges are most likely from the toner cartridge. If you can take your finger and run over the print and it smudges, then it is the fuser.
Aug 01, 2014 | Dell C1765nf Multifunction Color Laser...
Just replaced black cartridge in my 2600n color laser. I have smudged about a half inch wide 2/3rds over the right of each page. It only smudges in black. I have recalibrated several times. Printed at...
If this just started after you replaced the toner cartridge, one would have to say that it is a bad toner cartridge.
Print something that smudges. Pull down the front cover and look at the cartridges. Pay attention to the top one(black).
Look at the drum on that cartridge. You should see the toner sitting there. Compare it to the other cartridges which should be clean.
Feb 08, 2011 | HP Color LaserJet 2600n Printer
CHECK TONER MC
Hello
This means your ink level is low but you can confirm this by doing the following;
.The Lexmark C500n uses powdered ink, called toner, like other laser printers. The printer creates a magnetic charge on the paper as it passes through the machine, forming text and images on the page. The printer then applies pressure and heat to the paper, fusing the powdered ink to the page so it will not smudge or run. At any time, you can check the amount of ink left in the printer's toner cartridge by printing a status page. This page will also show a tally of the number of pages printed by the machine, among other information.
Turn on the printer and let it warm up. Ensure the light next to "Ready" illuminates.
Press the "Go" button, or the button with the icon of the hand pressing a button. Use the arrow button on the printer's control panel to highlight "Test Menu," then press the button with the check mark.
Press the arrow button until you highlight "Status Page" on the printer's display panel. Wait as the printer generates a status page.
Retrieve the status page from the printer's output tray.
By doing this you will know the level of your toner.
Oct 23, 2010 | Lexmark C500n Laser Printer
Samsung scx5315f printing black smudge along edge of page
The fact that it's printing anything suggests that it is not a Toner problem. Remove the toner, and have a look at the run inside the printer, checking for any excess toner which is in there. Also, check the Drum and Imaging Unit for damage, wear and tear etc. There will also be a static strip near the imager, with a little tab which you can sweep across the unit to clean it.
Mar 05, 2009 | Samsung SCX-5315F All-In-One Laser Printer
Printing black smudges across the page at 10 cm intervals
Most likely cause by the drum unit. Replace drum or upgrade printer.
Jan 24, 2009 | Brother HL 1030 Laser Printer
HP Laserjet 1100, band of unprinted area after new toner install
Hi Friend,
You have mentioned this is a 2nd hand printer,
you have to service the printer,(fuser unit)
if the problem exists after fuser service check Laser Scanner also,
Thanks
Lux5
Nov 28, 2008 | HP LaserJet 1100 Printer
Black ink smudges for color print mode only, not for grayscale
- Try to reallign the cartridge, run a print test, after that if the issue still persist - uninstall and reinstall software - run test and re-allign again the cardtridge using software. run print test again.
Oct 08, 2008 | Samsung CLP 300 Laser Printer
Half the page is dark grey
Low toner.
Consider how often you print.
If you print more than twice a day, toner will tend to run low after half a year, so I would buy a replacement cartridge and see if this solves your issue.
They aren't terribly expensive, so it is worth a shot.
Sep 09, 2008 | Samsung CLP 300 Laser Printer
HP LaserJet 2100 Printer Logo
280 people viewed this question
Clive
Clive
