Just moved into a house which has a SMEG SWD 1600 washing machine, can't for the life of me work out how it works. Is there such a thing as a user guide for dummies?
  • Anonymous Feb 18, 2009
    same/.
SOURCE: Smeg Washing machine
This happened to us before and we had to actually reset the unit. I had to call the tech support and they walked me through the process.
Posted on May 29, 2007
  • 641 Answers
SOURCE: Machine vibrates excessively during spin cycle
Open washer's cover and look for a released or a malfunction shock absorber. Good luck!
Posted on Sep 04, 2007
SOURCE: Hoover Vision 1600 drum not spinning?
I have similar problem with same model unit, found brushes on motor worn to point copper contact is hitting and scoreing commutator. Easy checked, ensure power completely disconnected, lie machine on side and gently rotate drum looking in side the motor. The commutator is what looks like a circular block of copper segments which will rotate with the drum and should be evenly worn and coated with carbon from the brushes. If you see a clean copper area, usually in the center, then the brushes are worn down below workable levels. Suggest replacing should resolve problem.
Posted on Jun 08, 2008
  • 7 Answers
SOURCE: washing machine very loud and machine moves during spin cycle
Normal these mean unbalance load of clothes. Try to balance it with heavy clothes opposite each other. The fabric that hold more water tend to be heavier during the spin cycle. Also try not to overload the machine by washing clothes just half to 3 quarters full
Posted on Jan 06, 2009
SOURCE: Smeg WM 16 AAA WASHING MACHINE
Try turning power off, unscrewing the back panel of the machine and removing, reaching inside and giving the wheel which looks like a waterwheel (has 'fans') a couple of turns. This is the pump and sometimes small particles jam the wheel. Turn the power back on and if still in mid-cycle should resume and finish.
Posted on Apr 10, 2009
Smeg washing machine reset
I would first go to the manufactures website for a user guide to identify the root of the fault in the problem section or even write to them for advice eric
Dec 22, 2017 | Washing Machines
Can you please find me a user manual online for an ariston swd 1000
Hi Nicola ,
The manual seems not available online however u can call to request a printed copy on 08448 225 225
Hope it works for if not plz revert
Thanx
Aug 22, 2011 | Ariston Technologies Washing Machines
On display E6? WHAT DOES IT MEAN?
Hello,the issue is either that the filter at the front bottom has some particles in it. if you have cleaned this then remove the outlet pipe at the back and run water through it. If that works ok then the only thing left is the pump. I've been informed by Smeg that it would probably mean a replacement pump is needed. One thing to try after cleaning the pipes and filter is to get a low level bucket and put the end of the outlet pipe into it to let the water drain off. So long as the bucket is at a low level it will allow the machine to drain off. Then try switching the machine off for a few minutes, then back on and running another cycle. Last thing to check is that there is no blockage inside the machine where the water emptys through the hole in the rubber at the front. If none of that works then have a chat to SMEG support at this page:
Thanks
May 23, 2010 | Smeg WD16BA Front Load Washer / Dryer
Smeg integrated dishwasher continually washing - won't move to drying cycle.
you should check the heating element. if the water is not hot enough, the timer will not advance. crack open the door mid-cycle. let the water stop flying around. then open it all the way up. if you don't get a big ball of steam, you have an indication that your heating element may not be working properly. this is not too hard to check the resistance with a multimeter and then replace, if necessary. good luck
Nov 02, 2009 | Smeg STA4645U 18" Fully Integrated...
MANUAL FOR INDESIT 1600 WIL163
I have the solution for your query.
In your browser bar, type in ----
indesit user manuals
Click on---
manuals- user guides- handbooks- indesit service
In the search box enter your model and down load the relavent instructions.
Please leave a fixya rating if you consider my solution appropiate to your problem.
Thankyou.
Jan 29, 2009 | Indesit W 123 Front Load Washer
Mar 25, 2007 | Smeg WDI12 Front Load Washer / Dryer
Smeg dishwasher
Hi, You can download SMEG dishwasher manuals from here: http://www.smegtech.com/site/smeg/myapp/libretti/index.php?lang=EN Al.
Feb 02, 2007 | Smeg CSU2001 Built-in Dishwasher
Washing Machines Logo
51 people viewed this question
Top Washing Machines Experts
