Question about Harman Kardon HK695 Computer Speakers
SPeaker and Headphone
My speaker and headphone does not work. i tried to work on the control panel, and checked if anything mutd, but nothing is muted. I tired my best, but could not fix it. Unsure of the cause
    Novelist:
  • 180 Answers
If both speakers AND headphones aren't working and nothing is muted, it sounds (no pun intended) like your sound card has gone south. Have you checked in Device Manager to see if it's still listed? Right click My Computer>Properties>Hardware>Device Manager. Check under Sound, Video and Game Controllers to see if it's there. If so, right click and choose Update Drivers just in case it somehow got wiped out. That would be the easy fix and I hope it's not your card!
Thanks for using Fixya.com and please rate this tip accordingly.
Posted on Jan 11, 2009
Sentry 2.1 surround sound speaker system. i have my rca cords plugged in to my tv, but i only get sound from my tv, nothing out of the speaker itself. it only works when i have my headphone jack into
Most televisions have a setting that controls whether the TV uses its internal speakers or sends the sound to the audio out jacks for an external amplifier or speakers.
Try going through the settings menu and follow through the audio/speaker selections and confirm that the TV is set to use external speakers.
Best Regards,
Sep 01, 2017 | Televison & Video
Toshiiba satellite p205 Internal Harmon Kardon Speakers Do Not Work
Most likely its a nardware problem.
If Device manager shows the audio driver is working and enabled and when you plug an headphone into the headphone/audio out and you only get sound from the right headphone then the audio amp chip is faulty.
If the headphone sounds OK then the easiest solution is to connect a set of powered speakers to your laptop.
May 03, 2012 | Harman Kardon HK695 Computer Speakers
The headphone and external speakers don't work on my acer but the internal speakers are fine
check if you plugged them in the proper port the green one is proper for speaker.
Mar 31, 2011 | Acer Aspire One A150-1006 Notebook
Headphone audio doesn't work when pluged into headphone jack but will work if pluged into speaker jack
since speaker works nothing should stop the headphone it is likely that the headphone is faulty.try another headphone
Mar 16, 2011 | HP Pavilion DV8225NR Notebook
Adding remote control activated ''mute'' to TV headphone jack
Generally when the head phone jack is inserted the speakers will get disconnected automatically.
If you are going to use external amplifier you can try the AV sockets. Opening the TV you may require the special screw drivers some times.
Jul 07, 2010 | Televison & Video
My Acer Extensa 4820 volume is to low
Double click on the volume control at the bottom right corner of the screen or go to control panel (by clicking all programs or windows logo) and choose Sound And Audio Devices. When you are in the volume control panel box, make sure that all volume controls are at its maximum. If this doesn't work, try a different speaker or a headphone. If your speaker/headphone has volume control, set it accordingly. If still nothing, reinstall the driver for your audio device.
Dec 19, 2009 | Computers & Internet
Sound is working but internal speaker is not working
Connecting headphones to the system will disabled the internal speakers until the headphone jack is disconnected, at which such time the internal speakers should function again.
If you disconnect the headphones and the internal speakers are not re-activated, then there may be damaged to the microswitch in the jack. (Try rebooting after the headphones are disconnected too)
Mar 01, 2009 | Dell Latitude D410 Notebook
Headphone jack does not work
your headphone jack is corrupted in internal, cause when you put your headphone jack in internal you activate the switch to switch speakers to headphone and this switch is out of order.
you have to go to a specialist to replace your headphone jack on your amplifier. sorry for this bad news. ;)
Mar 31, 2008 | Onkyo TX-8511 Receiver
TOSHIBA E740 VOLUME CONTROL
Are you using a headphone or the Pda's speaker?
The speaker could be damaged or disconnected - try connecting a headphone to the Pda to see if the sound works.
Feb 22, 2008 | Toshiba e740 Pocket PC
Harman Kardon HK695 Computer Speakers Logo
65 people viewed this question
Top Harman Kardon Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Are you a Harman Kardon Audio Player and Recorder Expert? Answer questions, earn points and help others
