Question about Hotpoint WMA35 Front Load Washer
Motor brushes? Machine started making funny crackling noises and then stopped spinning. Now it just has some of the lights on and wont do anything. From past experiens I guess the motor brushes are gone? looking underneath I can only see one of the brushes pointing directly downwards - do I have to take the motor off to get to the other one?
  • 641 Answers
I am not familiar with your specific washer, but there are some washers that has a hole in the bottom that allow you an access to the brush. In case you don't have this access (I hope that you will have !) you should take the motor off for it. Good luck !
Posted on Jun 12, 2006
SOURCE:
Replaced beko motor brushes on washing machine and they are making funny noise
Please remove and reset the brushes are it could be out of alignment , Please check this link for tips: Brush setting
Feb 01, 2013 | Washing Machines
Hi. my vent made some funny noises last week and
Check the fan blades and see if it's being restricted.Another method is remove the fan blade turn the unit on and see if it spins if it doen'nt tap the motor gently and see if turns.If this works the motor brushes are worn
Sep 28, 2009 | Broan-NuTone N-QT100FL Combination Light...
Drum does a small turn then stops but wont empty -wont wash either beko 1000 rpm
Hi if your beko 1000 spin washing machine wont drain or has a spin problem then you have to check the carbon brushes first.
Also check all waste pipes are clear and inspect the pump I have included this video below.
At our website I am doing self diagnostic videos on these beko's as we speak so all tutorials will be in this link below
How to replace Beko Washing Machine Motor Carbon Brushes
you might find this test video helpful but only do it if you have checked the motor
Aug 23, 2009 | Washing Machines
On/off button and mini load LED's flashing ON Hotpoint WT540
Make sure there is no water left in m/c, lay hose down to draln completely, try spin again, if still no go, remove motor and check brushes.
Dec 15, 2008 | Hotpoint Aquarius WD63 Front Load...
Washing machine
This deffenitly could be the brushes. Wierd sound normally comes from the electric sparking between the stator and the brushes. If it are not the brushes the best bet will be the bearing.
May 13, 2008 | Bosch Classixx WFO 2466 Front Load Washer
I have a beko WMA 1715s washing machine, it will not work, the pre wash light is just flashing on and off, it will let you select a programme but when you press start it wont work, please can you help, i...
Either the child lock is on - press and hold quick-wash and anti-crease, at the same time for three seconds.
Or your machine need re-seting
Turn power button off (not at wall)
Select 90 degree wash
Press Start and Cancel button down at same time for 3 seconds and turn power button on whilst still holding buttons down - Start light will flash.
Leave power on.
Select any Spin position.
Press Start and Cancel button at same time again for 3 seconds - other buttons may start to flash - if they do, press Start and Cancel button together again for 3 seconds.
Machine should be re-set ready for use.
Apr 26, 2008 | Washing Machines
Washing machine making crackling noise when spinning
check for some loose items underneath the unit. washing machines normally reverses its rotation when spinning. check if mechanical solenoids pulls the right levers as it starts to spin....
Feb 12, 2008 | Ariston Technologies AWD120 13 lb. Washer...
My washing machine has stopped spinning, for the last 4-5 washes it made quite a bit of noise when spinning the load and now it has stopped spinning completely. It makes the noise as if the motor is...
it sound like your belt has come off if not wait till its dark put it on spin turn the light off if you can see flashes coming from under the machine it your brushes that need replaced on the motor
Dec 31, 2007 | Hotpoint Aquarius WF215 Front Load Washer
Tricity Bendix AW1400W Won't spin or agitate.
this could either b the motor brushes or the timer check the brushes first they r mounted on either side of the motor unplug the machine b4 u start good luck
Aug 26, 2007 | Tricity Bendix AW1400W Front Load Washer
Hotpoint WMA35 Front Load Washer Logo
98 people viewed this question
Top Hotpoint Washing Machines Experts
vince
gbob59
James Hehling
James Hehling
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
