Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Cannot program additional remotes to new door opener
The drive/worm gear somehow got "chewed up", so I replaced the motor unit only. The new unit came with a one function remote, with a door control button. I left the old premium control console from the old unit attached to the wall. The remote that came with the new unit is programmed fine. The problem is with programming the two (2) old 3-function remotes to the new unit. I followed the programming directions for additional remotes and cannot get the two old ones to work. When I press the "LEARN" button, the LED light comes on for approximatey 30 seconds and then goes out. The light doesn't blink, nor does the opener light blink. I even tried to erase all codes and still didn't work.
THe old transmitters have a differnt code...more than likely your new one is a riolling code and the old ones are not. They are not interchangeable.
Posted on Feb 28, 2009
I have a Craftsman 1/2 hp, mod # 139.53603. When I press the remote or the panel button there is a humming sound from the motor. I opened the panel on the back and did not see anything out of line, etc. ...
Is the trolley jammed against the bolt just in front of the motor? If so, loosen the chain until the tension is off the trolley and then run the motor until the door is closed. Now locate the up limit on the side of the motor unit and turn this control 2 full turns in the opposite direction of the arrow printed on the cover. Tighten the chain.
Jan 25, 2011 | Sears Craftsman LiftMaster Chamberlain...
Drive/worm gear on liftmaster garage door opener is worn out and no longer driving the chain to open the door. Apparently this gear is a common part and looking for detailed steps on how to replace it...
You did not specify the model of your door opener: However if you got the LiftMaster website you should be able to locate an Owner's Manual for your door opener.
Go here, select your model or series and then on the next page at the bottom right should be a link to the Owner's Manual.
The manual includes schematics, including the assembly of the motor unit.
You might find these illustrated instructions on similar product to be of use.
Jan 15, 2011 | Computers & Internet
My Craftsman garage door opener is not working - I opened the inside of the opener and motor is humming but gears are like jammed....when I prod the gears with a screw driver they do spin for about 3...
I had the same problem. In my case the bushing for the main drive gear was worn out. This is just below the sprocket that connects to the chain.
What you should do is remove the chain and see if that sprocket shaft is loose in the bushing. The motor should turn without the chain on.
If this is the case check the plastic gears within the case. If there all chewed up and the bushing is shot you most likely need to replace the unit. If the gear's are still good you can replace the bushing.
I'm not sure how much Sears would charge to rebuild it but it is very possible it would be cheeper then buying a new one
Jan 04, 2011 | Sears Craftsman LiftMaster Chamberlain...
Garage door does not open or close.motor makes a brief noise and chain doesnt move at all
QTIR,
YOU MGHT BE IN FOR A NEW OPENER OR AT LEAST A REPAIR BILL. IF YOU CAN CLIMB UP AND TAKE YOUR REMOTE WITH YOU. LOOK ON TOP OF THE OPENER AND LOOK WHERE THE CHAIN WRAPS AROUND THE DRIVE SPROCKET. STAY BACK A LITTLE AND PRESS THE REMOTE AND SEE IF THE SPROCKET MOVES A LITTLE. LISTEN FOR THE NOISE YOU TALKED ABOUT,IF IT'S COMING FROM INSIDE OF THE HOUSING OF THE OPENER IT'S PROBABLY THE DRIVE GEAR INSIDE THE OPENER. THEIR IS A WORM GEAR INSIDE THE OPENER THAT SOMETIMES IS MADE OF A PLASTIC RESIN OF SORTS. IT'S NOT REAL HARD TO FIX IF YOUR MECHANICALY INCLINED. IF NOT THEN YOU WILL HAVE TO CALL A REPAIRMAN. TO FIX IT YOURSELF IS A MATTER OF TAKING THE OPENER UNIT DOWN AFTER DISCONECTING IT FROM THE TRACK AND OPENING IT UP. YOU WILL SEE THE DRIVE SHAFT AND GEARS. YOU'LL HAVE TO TAKE OUT THE PARTS DAMAGED AND GET NEW ONES FROM THE MANUFACTURE. I HOPE THIS HELPS EWE OUT,MAY GOD BLESS YOU AND GOODBYE.
Nov 14, 2010 | Garden
Chamberlain Whisper drive remote control unit not working
THE NEW REMOTE MAY NOT BE THE CORRECT SYSTEM FOR THE UNIT YOU HAVE.
THE ONE THAT DOESN'T WORK MOST LIKELY NEEDS A NEW BATTERY.
NOTE IT MUST BE REPROGRAMED AFTER CHANGING THE BATTERY
HOPE THIS HELPS
May 14, 2009 | Chamberlain 950CB Remote Control
Craftsman Garage Door Opener - Gears need to be fixed
Unplug the unit and remove the cover, usually eight screws, if you see a lot of white dust in the cover check the nylon drive/worm gear, they will need to be replaced.
Apr 10, 2009 | Sears Craftsman LiftMaster Chamberlain...
Lift master garage door opener. Motor makes noise when switch is hit likes its running but chain/sprocket doesn't move and the door is stuck open. Chain is on sprocket. Not sure if the motor is frozen? ...
I had the same problem. Took the cover off of the opener and found that the gears were stripped on the unit. Motor was fine. You can order gear replacement kit for the unit. They are a plastic type sprocket and worm gears. The kit comes with spindles and all necessary clips. You have to take the unit off the ceiling to replace the gears, but the process if very easy to do. Parts kit about $40 on line, much cheaper than a new door opener. Total process took less than 2 hours, including getting the unit down and back up again.
Jan 24, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage opener cannot close, just replaced gears.
If the unit has photo eyes that could be your problem. not reattching the 4 wireing harness from the limit assy. can cause a similar issue.
Dec 13, 2008 | Chamberlain Powerdrive PD422D 1/2 HP...
Chamberlain Power Drive 1/2 HP - motor runs but does not move chain
I have the same problem. I just removed the cover and discovered a nylon gear had been worn out. I found lots of shavings inside the cover. The nylon gear is beneath the exterior chain gear. I am looking for information on how to replace it, if I can find the part. If you decide to look at yours, unplug the power and remove the sheet metal screws securing the bottom portion of the cener cover to the front and back covers. Then just remove the upper screws from the center cover. Good luck.
Oct 08, 2008 | Chamberlain Powerdrive PD422D 1/2 HP...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
246 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
