Question about Canon PowerShot A75 Digital Camera
CANNNON POWER SHOT A75
WHEN I TURN ON MY CAMERA THE LENS ON THE FRONT DOES NOT OPEN SO THAT I CAN SEE THE IMAGES THAT I AM TRYING TO SHOOT. EVERYTHING ELSE WORKS ON THE CAMERA EXCECPT THAT. CAN YOU PLEASE CALL ME BACK AT 415-574-6765. YOUR HELP IN THIS MATTER IS GREATLY APPRECIATED. IF I DON'T ANSWER PLEASE LEAVE A NAME AND NUMBER WHERE I CAN RETURN YOUR CALL THANK YOU VERY MUCH.
GLEN E. RIVERA
415-574-6765
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Canon Master
  • 102,366 Answers
Try the procedures in this tip.
Posted on Jul 31, 2012
SOURCE: Canon Powershot A75 won't power up (dead)
Have you tried cleaning the contacts
Posted on Mar 10, 2007
  • 1894 Answers
SOURCE: My Power Shot A75
for these type of problems battery has no role to play in it. it is a problem in camera. the camera lens system must have got damaged. else the settings in camera must have got changed.
Posted on Dec 21, 2007
taki99
  • 112 Answers
SOURCE: Display of my Cannon Power Shot SD 630 Digital ELPH: NO IMAGE
i think you camera,s software is corrupted
go your canon customer center for repair it
Posted on Dec 14, 2008
t00nz
  • 4738 Answers
SOURCE: canon power shot g9 lens
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Posted on May 10, 2009
t00nz
  • 4738 Answers
SOURCE: have canon Powershot A75 3.2 Mega pixel camera .. Now it is having display issue. Once i open my camera lens come out power come but unable to see the image in lcd to shoot.. Can you assist
First try pressing the DISPLAY button. If that doesn't fix it then this sounds like it might be a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check the following two links for more info:
http://camerarepair.blogspot.com/2007/11/canon-digital-cameras-showing-black.html
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=225&modelid=13390&keycode=2112&id=29819
Applicable cameras include:
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110, IXUS V2/300/400/430/500, IXY Digital 200a/300a/400/450/500
Posted on May 17, 2009
The pictures and screen are blury on my canon power shot a75.
WITH THE LENS IN THE OUT POSITION. CHECK TO SEE IF THE FRONT GLASS ELEMENT IS CLEAN !
Jun 19, 2009 | Canon PowerShot A75 Digital Camera
Have canon Powershot A75 3.2 Mega pixel camera .. Now it is having display issue. Once i open my camera lens come out power come but unable to see the image in lcd to shoot.. Can you assist
Apr 16, 2009 | Canon PowerShot A75 Digital Camera
Zoom lens will not retract.. Canon Power Shot S21S
the block is damaged ...see if the lens barrels are a little bent or something....
Mar 06, 2009 | Canon PowerShot A75 Digital Camera
Wont turn on
I don't know if this will help, but try it. Install new batteries. You may have enough power to view the images, but not have enough power to operate everything. There are also microcomputers in the camera. You can also try removing batteries, WAIT 1 FULL MINUTE, then reinstall (making sure the polarity is correct). Hopefully either of these simple solutions help.
Nov 29, 2008 | Sony Cyber-Shot DSC-S60 Digital Camera
Sony Cybershot Lens Stuck inside!!!
I have the exact same problem with my Cyber-shot; the lens is stuck inside. After trying everything to loosen it (like wedging a razor knife between the sections, even dropping it or banging it against a book, etc) non of which I recommend, I finally got it open by PUSHING on the black telescoping section surrounding the lens itself. For some reason, this worked!
Nov 18, 2008 | Cameras
Camera just froze up.
Try Rebooting the camera. Take out the existing batteries and insert some new ones. Then, turn it on and the lens should go back inside!
Hope this helps.
Jan 29, 2008 | Canon PowerShot A75 Digital Camera
Digital camera
The following blog outlines some repair options for a lens error. They won't work for all cases, but they're worth a try:
Dec 28, 2007 | Cameras
My Power Shot A75
Dec 14, 2007 | Canon PowerShot A75 Digital Camera
Camera Motor running
your lens is possibly damaged or seriously out of alignment - replacing lens is easier , than opening the camera ( hard to believe how many tiny screws etc . are in the way ) plus if you do open it . . . ? few technicians will work on it , after .
Aug 08, 2007 | Sony Cyber-Shot DSC-S40 Digital Camera
Spots on image when using built-in Speedlight flash
As is common in many compact digital cameras where the built-in flash is very close to the lens strange reflections can appear in images under certain conditions. Particulate matter in the air in front of the lens (between the camera and subject) such as water vapor (as in a cloudy day), smoke, dust or other items can reflect light directly into the lens causing neutral colored white/grey semi-transparent spots to appear in the image. In extreme examples there may be many of these spots in an image or there may be only one per image. Also, since these spots are completely random they will move or disappear from image to image. For example, if two images are shot consecutively with the same camera settings one image may have spots while the other is clean. To avoid these spots: When possible, avoid photographing in smoky, dust, or cloudy areas Do not use the camera's flash in locations such as above Use an external Speedlight flash if a flash is needed Review images on the camera and re-shoot if spots are visible Cleaning the lens will not have an effect on these spots, as the particles that cause this are not on the lens itself.
Aug 29, 2005 | Nikon Coolpix 5700 Digital Camera
Canon PowerShot A75 Digital Camera Logo
35 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
