Pin code for wharfedale tv
I am looking for the pin code for me wharfedale tv so it will work on my sky controls
1 am looking for the sky remote code for a wharfedale ltf42k1cb teley
Posted on Nov 11, 2008
The code for WHARFADALE LTF42K1CB is 0206, please make sure your remote version by taking the battery cover off, more info is on this website.
http://www.sky.com/portal/site/skycom/skyhelpcentre/producthelp?nodeId=73a6e9e0-0ade-4eed-810b-cec670799bcc&articleId=11320303
Posted on Jan 14, 2009
Depends on your rev number , since I have a rev 8 version remote control, I tried the manual with the remote, sky interactive help (proper slow) then I tried the link above and this is what result I get:
Two codes: 0206 and 1293.
Instructions to enter remote (from sky)
Cover the end of your Sky remote control and press the tv button.
Remove your hand, then hold select and the red button together until the light at the top of your remote blinks twice.
Enter your four-digit setup code and press select.
Cover the end of your Sky remote control and press sky.
If this works, test the remote by changing your TV volume. Please remember that some TV functions may not be supported by your Sky remote, but the basic standby and volume functions should work once you've put your code in.
For me 0206 worked , but with a genuine original sky remote, I tried these codes with a replica cheap replacement remote and was unsuccessful with the codes, even with the manual code of 0450 .
Thanks to this thread my old sky remote is synced with TV , to change volume and turn on/off I need just 1 remote now!!! Hope this helps you!
Posted on Nov 12, 2012
Wharfedale m2126 tv
Yes. Of course there is a code. 0382,0388,0381 are the codes to check. If you wish to get some details, check the site linked here. Pull up older posts. Check the site in 'Mosaic' view. It will make search easy. http://electronicshelponline.blogspot.com/
Jan 16, 2014 | Televison & Video
Sky tv remote codes for wharfedale tv model L32ta6a
Hello
Sky remote code for Wharfedale TV are:
065
584
699
OK.
Jun 26, 2011 | Emerson LC320EM9 32 in. LCD HDTV
Unabel to use sky control for sound
You have to programme the correct code for your TV into the Sky remote.
You can get these via "Sky Active" (if your box is connected to a phone line) or from the Sky website, or google search: "Sky remote codes".
However your sky remote wont necessarily control more recent televisions unless you have a REV8 remote control. You can check this by taking the battery cover off your remote and looking at the sticker inside. If it says RC1600/00 you're probably not going to be able to control your TV. REV4 and REV6 are more likely to work - but not guaranteed. If it says REV8, then you are probably not using the correct code or you're not programming the remote correctly.
If you have REV8, the correct code for your TV (according to Sky) is: 0678 or 1678 or 0254
Sky remote code finder page is here: http://sky.uebv.com/
Sky guide to finding your remote code and programming remotes is here:
http://www.sky.com/helpcentre/tv/sky-remote-control/program-your-sky-remote-control-to-work-with-your-tv/
Please rate my solution if you find this helpful. Thanks.
Oct 13, 2010 | Panasonic Viera TH-42PX80U Plasma TV
What is sky remote code for wharfedale tv
Hi there try one of these 065 or 574 let me no how you get on...roots
Mar 06, 2010 | Televison & Video
Sanyo ce32ld47-b code for sky+ remote
  1. Turn your TV on.
  2. Press tv on your Sky remote control.
  3. Hold down select and the red button together for about two seconds, until the red light on the Sky remote control blinks twice.
  4. Press tv on your Sky remote control again.
  5. Key in the code 0157. The light on the Sky remote control blinks twice. If the light blinks once only, recheck the code you entered and start again at Step 1.
  6. Press the standby button on your Sky remote control. If your TV switches off, press select. The light on the Sky remote control blinks twice (code stored). If your TV does not switch off, press tv, then press the standby button. Repeat this (press tv, then standby) until your TV turns off, then press select (stores code).
Oct 12, 2009 | Sanyo Televison & Video
Code to programme Sky Remote to operate new TV?
i have the same problem with the codes 0035 0125 0049 everything works except turning the volume up. have you found a solution yet???
Dec 31, 2008 | Televison & Video
Remote control codes
codes for orion tv
Jun 07, 2008 | Televison & Video
Sky code for Wharfedale L26TA6A
I found a code that will turn the tv on and off and work the volume, but will not change channels. However it gives me full access to all sky funtions and I am happy with that, the code you need is 1246 Regards b Weston wstbri@sky.com ps let me know if it works for you
Apr 19, 2008 | Televison & Video
Tv wont switch to Sky when remote control is pressed
Hi.
On the sky box do the following.
Check scart to tv is in the correct socket marked TV.
Try pressing services
then system setup
then picture settings.
Then try switching scart control to on or off.
If this sorts it great. If it doesnt check scart lead has all pins wired & not only A few.
http://dysonmanuals.llc.nu
Chris..
Jan 19, 2008 | Televison & Video
Sky code for tv
Hi.
Try this,
It involves finding your make & model number from Sky.
Press INTERACTIVE BUTTON., then SKY CUSTOMER SERVICES,
then TECHNICAL ASSISTANCE, FOR ALL SKY REMOTES.
Now follow the on screen instructions.
http://dysonmanuals.inc.io/
Chris.
Jan 12, 2008 | Televison & Video
Televison & Video Logo
1,104 people viewed this question
Top Televison & Video Experts
Electro Med Services...
