I plugged in the wrong transformer to my hard drive and now it wont turn on!
  • 4 Answers
I suggest seeing a pc consultant or sopmeone who works on pc. Just to make sure you didnt do further damage to your pc. Could be a Bad connection or even bad harddrive
Posted on Oct 18, 2008
Ps3 wont read any disk I replaced the drive and still wont work, what could be wrong
to solve this problem, you need to take out the hard drive. the ps3 hard dirve can be hot after you play games for a while. the DVD ROM probably won't function when the hard drive is over heated. the hard drive should be put in cool place. you should let the hard drive remain in a cool spot temporarily. the place where you put the hard drive should not be exposed in direct sunlight. you can open window and let the air come in while playing. you can switch on the fan and turn it against the hard drive. in this way, the heat in the hard drive will quickly dissipate away.
sometimes, the DVD ROM is not functioning properly because of loose cables. checked the cables to see if they plugged in properly. you can plug out the cables and replug them. after replugging them, you can turn on your console to see if it's working again. just make sure that the disc tray isn't overly dirty or filled with dust, this can cause the reader to not work. always wipe the disc tray and the disc that you're using before playing.
if this didn't work, you have to send it to sony. you have to pay delivery cost and repair cost. if it's still under warranty, you only have to pay the delivery cost.
Dec 02, 2011 | Sony Playstation 3 (PS3) Console
What plug can i substitute for a verbatim USB500 portable hard drive? I only need the wall plug.
I believe you also need a dc transformer that has a wall plug on one end and the plug for your USB hub on the other.
Mar 19, 2011 | Verbatim 500GB USB Desktop 500 GB Hard...
My computer do not turn on at all.. i got new bettery and got new ac adptor charger.. stil it wont turn on... when i plug the charger it shows the blue light .. but when i trun on the power button it turns...
Take your battery out and stick it back in... make sure it is locked and fitted in there properly.... nothing wrong with the hard drive or virus... maybe you have the wrong battery... or AC adaptor... hope this helps :)
Jan 09, 2011 | HP 435768-001 - Compaq Presario C300...
USB wont work
You arent doing anything wrong, might be the drive is faulty since no light comes. Get it replaced. :)
Jun 18, 2010 | Dane-Elec DaneElec 4GB USB Drive Copper...
My hard drive has stopped working! I checked power supply and it is working fine, when plugged into drive and turned on, the blue light flashes briefly on the drive then goes off again as does the light on...
Could be a bad transformer on the power supply or a bad drive. You could check the voltage coming from the transformer and verify that it is the proper voltage using a fluke meter. You could also dis-assemble the hard drive housing and try installing it in the computer and check if it is working. If you install it in the computer and the drive is not found then the drive is probably bad. If the drive works in the computer then get a new transformer.
Sep 24, 2009 | Western Digital Computers & Internet
WD ELEMENT DOESNT POWER UP. GREEN AND BLUE LIGHT FLASHES
Have you contacted WDE.. by email,or, phone? Seems like that the hard drive has had its bios info corrupted , due to possibly hooking it up to the pc(in the wrong order), or even, a power surge that you were not aware of... The Manufacturer can send you a link to upgrade/restore the harddrive bios...
Sep 01, 2009 | Western Digital Elements powered by WD 320...
Dell latitude wont turn on
If you hear the hard disk clicking, most likely you have a faulty hard drive.
Go into the BIOS configuration and see if the BIOS has detected the hard disk, if not this means the hard disk is faulty or the disk controller is faulty.
To determine if the hard disk is faulty, remove the hard disk and connect it to an US hard disk adapter and plug it into a working computer's USB port. If this computer sees this as an external hard disk/external storage device and you can open the various folders and files then the hard drive is OK.
If the hard drive is not detected then it is faulty and you need a replacement hard disk and Windows needs to be installed on this drive to get the Dell operating again.
Jul 18, 2009 | Dell Latitude 100L Notebook
Lack of power to a terrabyte WD external hard drive
Hi, mmm that's a curly one....possibly a faulty cable from the transformer to the drive or faulty connection. How does it connect to the drive itself? Does it have pins? If so maybe one is bent.
I am assuming that the transformer is the one that came with the drive also, else the voltage may be wrong.
Does the drive have like a lock mechanism like for transportation?
Also if it's new or under warranty returning it for replacement might be an option too.
Let us know how you go and if we can help further or if you get anymore information.
SeaJade
Dec 04, 2007 | Computers & Internet
Computers & Internet Logo
29 people viewed this question
David Payne
David Payne
