Home | Toshiba | RS-TX20 DVD Recorder | Toshiba RS-TX20
Toshiba RS-TX20 DVD Recorder
Problem for Toshiba RS-TX20 DVD Recorder
Toshiba RS-TX20
By vwdzl on Oct 18, 2008
Hi
I'm trying to delete everything on my DVD and start again however it is "frozen" and won't go to the next stage. It displays "CLEARING AND DELETING EVERYTHING. THIS MAY TAKE UP TO AN HOUR."....
Well 18 hours later no change. Do you know how to rectify it. Thanks very much.
Mike Ficker
Comments:
Oct 20, 2008
- My Toshiba RE-TX20 DVD recorder is stuck still on the same screen. Deleting Everything. This may take up to an hour...I called toshiba and they couldn't assist with the problem. They gave the phone # for their authorized repair place. The screen has been like this for over 3 days now.
Solution #1
posted on Oct 18, 2008
Somewhat Helpful)
ginko
Rank: Guru  Toshiba Expert Televisions & Videos  Expert
Rating: 89%, 4917 votes
If you brake power you may damage irreparably the unit, you will need to call Toshiba tech support by phone.
Comments:
Oct 18, 2008
- If you interrupt power, trying to restart the unit, you can damage the unit irreparably, check the user manual, and call immediately Toshiba customer support number listed.
Follow instruction from Toshiba Tech support, so that they take responsibility if the unit is damaged during update procedure. They will probably suggest you to start pressing the power button for 5 seconds and to unplug power cord.
If unit gets damaged, ask a replacement.
In USA call the number on the owner manual, or call the general Toshiba customer support at (800) 457-7777.
Oct 20, 2008
- Well, in this case all you can do is unplug power cord , and pray.
If the unit does restart just do again software update.
If the unit does not restart, that means that the firmware is corrupted, and you will need to take it to an authorized toshiba repair service.
Solution #2
posted on Oct 20, 2008
Not Rated)
electech1
Rank: Guru  Televisions & Videos  Expert
Rating: 88%, 615 votes
unplug it! this will not hurt the unit , if all electronics was dammaged from loss of power then no one would want to buy any electronics!
the next thing to do is get a cleaning cd that will clean the laser eye. as these collect dust and other stuff. and it is most common for them to get dirty and start messing up. so clean the laser eye first!
then if that don't work then it will have to be cleaned manually
it is froze up and if you leave it like that your going to have more problems then it not erasing disk's!
do not do a firmware update , the disk's that update sometimes are messed up and can ruin the unit
it's not worth it!
if you need more help , just ask!
Popular Solutions for Toshiba RS-TX20 DVD Recorder
Questions and Unsolved Problems for Toshiba RS-TX20 DVD Recorder
Do you recommend Toshiba RS-TX20 DVD Recorder?
Answer
Answer
intermittantly freezes on playback of recorded shows.
Answer
this is not the first time this has happened. toshiba rs-tx20 dvd recorder - it will work fine for a... (More)
Answer
the same picture appears on the tv screen but at the unit, I get no lights for power, and I can't... (More)
Answer
I've been moving my home movies to DVD's and after several discs successfully downloaded, 2 discs... (More)
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Toshiba RS-TX20 DVD Recorder:
Top DVD Player Experts
Rank: Guru Guru
Solutions: 1454
Experience: I run a Full-time Appliance Service Co.with HVAC/Auto Air Conditioning and Small Engine Service.
Ask Me
Find more DVD Player Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
