Question about Electric Chainsaw Sharpener
Chainsaw electric motor jammed
Was sawing a root. Suddenly the chain saw stopped. The motor cannot be turned by hand.
  • 1 more comment
  • spndrft Oct 22, 2008
    Chain is removed. Cannot turn by hand. Cannot remove motor housing due to one security-type allen nut.
  • spndrft Oct 24, 2008
    The guard activates a switch that shuts off the motor. The guard was not involved when the engine froze. Moving the guard does not free up the motor.
  • lowthian Feb 18, 2009
    I have exactly the same problem. I can't turn the motor by hand (having removed the blade) and I have tried to push back fairly hard on the guard but it is totally stuck and doesn't move in either direction ( no play at all)
    Please,some advice will be very much appreciated.
    The saw has only been used twice (light cutting) last year as has laid in the garage through winter. It still looks in 'new' condition.
    Sergeant:
  • 314 Answers
Remove the chain, then see if it will turn over by hand. Does it have a chain-brake??? Frankster016
Posted on Oct 21, 2008
  • frankster016 Oct 22, 2008
    Your prob sounds like the safety brake! Push the guard back toward the front handle with a bit of force. You will hear a click when it is reset. Frankster016
First electric chainsaw. McCulloch MC2040E.PRETTY SURE WE FOLLOWED ASSEMBLY INSTRUSTIONS CORRECTLY BUT CHAIN WONT TURN, SEEMS TO JAM
The chain could be on backwards or too tight. The chain should turn freely by hand (with gloves). If not these, could be an internal issue with the saw.
Feb 18, 2017 | McCulloch Garden
Chainsaw starter rope won't pull
Pull your spark plug to ensure it isn't a compression issue or even piston/rod damage. If it still doesn't move, pull off your starter assembly and try to rotate the fly wheel by hand. If it turns, then your issue is in your recoil spring kit. You can replace the unit, or try to disassemble and reassemble.
Jul 30, 2014 | Echo Chain Saw. 18 in. 40.2 cc Gas Chain...
My 335 mcCulloch 14ins electric chain saw,motor is trying to go but it feels that there is a brake on,help
I recommend contacting your local authorized service center for assistance.
You may contact the manufacturer, download manuals, check fuel/oil ratios, order parts, find your local service center, and view other resources using these links:
Contact us
User manuals
What is the correct fuel mixture for McCulloch products Chainsaw Trimmer...
McCulloch Service
McCULLOCH PARTS ACCESSORIES
I trust this information has proven beneficial.
Feb 13, 2014 | McCulloch 16" Electric Chain Saw 35 HP
McCulloch ES335 electric chainsaw whilst cutting a fallen tree into pieces The saw made a load click like sound when restarted and them the engine run but no movement on the chain. I took off the cover and...
In front of the handle on top of the saw is a hand guard. If in the course of cutting wood you hit it or pushed it forward, it will lock up the chain drive system. It should pull back towards the handle until it again clicks to release the chain. It's designed to lock up the chain drive and stop the chain when the saw kicks back.
Feb 10, 2011 | McCulloch 16 In 4.5 Hp Electric Chainsaw...
Oil not feeding to the chain guide on the electric ryobi chain saw
Remove the cover on the right hand side of the saw and remove the bar and chain. Clean the oil port holes in the bar and the body of the saw. They get clogged with sawdust and chips. Also clean the groove in the bar and the sprocket at the end of the bar. Always use proper chainsaw bar oil.
Jan 12, 2011 | Ryobi 18-inch Electric Chainsaw Chain Saws
Electric chain saw, motor smoked, stopped running. Worth fixing?
Till you get the motor and get the new motor insatlled you will have more into it then a new one...
heatman101
Aug 19, 2010 | Remington Electric Chain Saw
Ryobi ECW 1836 electric chain saw. No drive
Check to be sure your chain brake is in the OFF position Pulled back towards the operator
Apr 01, 2010 | Ryobi 18-inch Electric Chainsaw Chain Saws
My chainsaw quite suddenly. i restarted it but
1. The kickback brake, if equipped, was triggered to stop the chain.
2. The chain is jammed with saw dust/debris (it doesn't take much)
3. the bar sprocket is damaged.
4. The chain guide teeth are damaged and not sliding through the bar guide groove smoothly
5. The chain is adjusted too tightly.
6. You are out of bar oil and friction has stopped it/damaged the bar and/or chain
7. The motor sprocket clutch is damaged.
That should cover all of the basics to look over.
Nov 04, 2009 | Husqvarna Craftsman 36cc, 16 In. Gas Chain...
New uc3520a chainsaw will not work
240VAC European Model
From the Makita manual:
If the saw does not start when the ON/OFF switch (1) is actuated, it will be necessary to release the chain brake.
- Pull the hand guard (6) firmly in the direction of the arrow until you feel it catch.
electric motor does not function
no power supply
cable defective
chain brake actuated
Mains fuse blown
HTH
Lou
If these don't work return it, maybe it is defective. Test the new one in the store.
Oct 18, 2009 | Makita UC3530A 14" Electric Chain Saw
Electric Chainsaw Sharpener Logo
210 people viewed this question
Top Electric Garden Experts
Steve Oakes
dannydoesita
ray gallant
Are you an Electric Garden Expert? Answer questions, earn points and help others
