Question about Linksys (WIFIDESKTOP) Wireless Adapter
Ami - speed touch router
I have a labtop to be connected automatically to router, but connectoin is lost evry now and then, sometimes connectivity reamins for 5 minutes, 2minutes then disconnected, and asking me to reconnect
  • 94 Answers
Try changing channels on your wireless router. Routers have configuration page where you can change the channel. Refer to your user manual on how to change the channel on the device.
You may also try moving the router to a different location or maybe on a higher location. To avoid interference.
Posted on Oct 18, 2008
Bad xbox 360 connection
You have two options to improve connectivity:
1) Move your XBox closer to the router. If you are connecting wirelessly, move your XBox as close as possible to your router. The farther away they are, the slower your connection speed.
2) Purchase an ethernet cable and plug it in. An ethernet cable can connect to your router and be plugged into the back of your XBox. This is the best way to utilize as much juice as possible from your router and get you the connection speeds you need to play online. Ethernet cables run about $20 depending on the length and quality, but its a great investment if you are doing a lot of online gaming.
Hope that helps!
Dec 12, 2011 | Microsoft Xbox 360 Console
Tip
How do I Connect my iPod Touch to a Netgear WNR2000 Router
<p>Netgear WNR2000, a wireless-N router, you can connect to the Internet without the hassle of cables. IPod touch supports Wi-Fi (wireless) connections. If you're within range of the router, you can connect to the wireless network. Once connected, enjoy a fast transfer speeds that allow you to quickly scroll pages and run the programs enabled network. <br /> <p><br /> <p>1. Connect the iPod Touch. Tap Settings on the Home screen settings of media player to start. <br /> <p><br /> <p>2. Scroll through the settings when you come to "Wi-Fi, tap to activate the feature. IPod touch detects networks in range. <br /> <p><br /> <p>3. Select the Netgear WNR2000 Wi-Fi network can include the name has been set, so it helps to know the name. If a secure network, enter the password. If you do not know the password, your iPod Touch cannot connect to the network. Once selected, your iPod automatically connect to the network. The Wi-Fi icon in the status bar at the top. <br /> <p><br /> <p>4. Select "ON" next "Ask to Join" if you want your iPod touch to ask you to connect to wireless networks within range. <br />
on Aug 05, 2011 | Apple iPod touch
I had this router connected to my desktop so my grand daughter could use her labtop,my desktop crashed and I had to replace my hard drive and my memory and lost all information on the router and I lost the...
You actually don't need a setup disk for setting up a router. Try the following steps.
  1. Reset your router to default configurations by holding the reset button for 15 seconds.
  2. Make sure your desktop is set to "obtain an ip address automatically."
  3. Connect an ethernet cable between your router and desktop.
This should get you connected to the router. If you want to make any configuration changes, perform the following steps.
  1. Open up a web browser.
  2. Type in the address bar 192.168.1.1 (Default IP address of Linksys routers)
    This will connect you to the router.
  3. It will prompt you to login. The default username is blank (no text at all) and the password is admin.
Feb 26, 2011 | Linksys WRT54G2 Wireless Router
We keep losing connection to internet when playing xbox 360 live. will be playing and screen freezes up for 15 to30 seconds then kicks us from xbox live.have a router with 3 xboxs hooked up.its unsecured...
If it's unsecured, there is a possibility that other people nearby are logging on to your internet connection through your open router. The more connections through the router, the slower it becomes. And the Xbox will drop is the connection becomes too slow.
As for a better answer as to why your losing your connection, try relocating the router. Often moving it higher up will allow a better signal. Other times a wall or shelf which contain metal objects is the cause. The signal weakens as it passes through construction materials, and nearby metal objects will definitely cause signal degradation. Try moving the router, sometimes only a foot or two is sufficient.
You should definitely learn the process to secure your router. It's like connecting your computer with a network cable to all of your neighbors computers and inviting them to see what you have stored on your machine. If their computer savvy, they can even watch what your doing in real time and even activate your camera and microphone! (It's been known to happen).
Securing the router involves the use of a network key (think of this as a password). Most modern routers have the default password printed on the body of the router. Using a special program installed when you installed the router, you can access the router and set the password. For example I use a Netgear router and the program that it installs is called "Netgear Genie". You access the router through the program using the routers user name and password (default as shipped is usually "admin" for both. Then set up the router to use security. After this all of your devices you authorize to connect to this router will also need to use the same Network Key (password). It's actually an easy process. For example, after you set the security, the labtop will attempt to connect and finding the system secured, ask you to enter the "network key" or password, to allow it to connect. It should ask you to remember this password so it can connect without assistance in the future
If your still uncertain, try running the router's setup program again. Most are designed to walk you through the process quickly. Just remember that all your devices will need to use the same password, the one that is printed on the side or bottom of the router. Usually it's something silly like "wonderfulwater456879" or whatever. Good luck and be more careful with your data in the future.
Jun 16, 2017 | Microsoft Xbox 360 Console
I have connection problem,,the connection go evry 10 minutes,,i change the router and the same problem,,the light of internet shut down evry 8..10..15 minutes
You can try reset the router if you are using one by pressing the reset button on the back or bottom of the router which might be in a little hole in which case you will need a pen or paper clip or something. If the issue persists, restart your modem, get a solid state and restart your router, get a solid status and restart your computer is necessary. You can check the settings of your router and see whether it is using DHCP, make sure your computer is not running a DHCP server kind of application. You might also need to contact your ISP and make sure your account and their connections are fine. Sometimes it may happen for high volume of users or some firmware installation on your modem.
Oct 24, 2010 | Toshiba Satellite A100-S8111TD Notebook
I unable to connect my desktop through cable but same time i can connect wireless connection with my labtop...now i request you please advise me n help me asap.....
Make sure your ethernet cable is connected properly into lan port and it is working fine.
Make sure in desktop networka dapter driver installed and enable.
ALso check ip settings in network adapter property it must be in your router network settings range.
Set gateway as your router ip in desktop .
if you want ip automatic from router then enable DHCP in router.
Let me know if you need further assistance.
Thanks for using FixYa.
Jun 27, 2010 | Computers & Internet
How do i play online wireless on my ps3 i have dsl connectoin but my router is in another room
Goto Network settings on the PS3 and Internet Connection Settings> then choose wireless > Scan > easy setup > automatically get Ip> Enter password for network > Test
Aug 29, 2009 | Sony PlayStation® 3 (80GB) Console
Lost connection
what u need to do is go to the interface of ur thomson speed touch through writing the ip address of that modem on the address bar of ur internet browser then go in that setup....Choose router instead of bridge.
Jul 14, 2009 | Computers & Internet
IPod connection to Zoom ADSL X65590 router
you have to log in http://10.0.0.2 at the button/under of your router tells you the generic name and password you need to enter, just follow the instructions, you'll be able to change your settings
Dec 26, 2008 | Zoom X6 (5590) DSL Modem (55900003)
Linksys (WIFIDESKTOP) Wireless Adapter Logo
76 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
