Question about Whirlpool Duet GHW9150P Front Load Washer
The ring that goes aroung to drum (i think it is plastic) is all chewed up and decaying is it a easy fix for homeowners or should we get someone to fix it
Same as above
  • 927home Oct 21, 2008
    Same type of problem, whatever "ring" is around the drum, when you peel back the rubber seal. It's almost feels like hardened cardboard, comes off in pieces into the drum. It appears at one time it was glued to the drum, is this insulation or what? The washer does not display any codes and will work, except for this gunk getting into the drum.
  • jcoates325 Oct 26, 2008
    call a repair I did and had to get a new outer drum
Yep, thanks, repairman says it was the outer drum, under warranty except for labor, although he's never seen the outer rubber gasket disinegrate like that...
Posted on Oct 28, 2008
    President:
  • Whirlpool Master
  • 2,651 Answers
Theres arubber "boot" connecting the tub to the outer wall of the unit. if your seeing "bone colored" plastic rubbing off and onto the soft rubber boot assy, that sounds like the outer tub itself somehow wearing down, , that snot an easy repace ment at all, you would need to replace the entire outer fornt tub.
Posted on Oct 26, 2008
Kenmore Elite H3 washer's loud in spin cycle & smells burnt.Debris & plastic in well inside washer.Pushed aside rubber ring & saw lg. gap btwn. metal drum & surrounding plastic.Parts needing replace?
It sounds like the drum has broken from the rear mount. This will chew up the outer shell. This is a very labor extensive job. The parts are expensive also. You will probably need a new outer shell and inner drum.
May 29, 2015 | Kenmore Washing Machines
Burnt smell bits of plastic found inside
A WM1814CW does not have a built-in water heater, so I think your
load may have gotten trapped between the spinning tub and plastic
front tub cover..Roll back the gray gasket to expose and check the
plastic ring for signs of 'friction' burn..As long as the splinters are
trimmed away and doesn't leak water you should be OK..Watch your
loads..Don't Overload!
Aug 18, 2014 | LG WM1814CW Front Load Washer
Clothes getting caught in Kenmore dryer
The bearings under the drum may have failed, making the drum drop, so the gap is bigger. Replacing drum or bearings is a lot of work, cheaper to replace the dryer. Or you could make a plastic ring yourself that is thicker to fill the gap....
Dec 27, 2013 | Dryers
My Porter Cable FN250A only shoots nails sporadically. When I lift up the nose piece, it appears that the "hammer" is not fully retracting.
Piston not retracting is caused by several issues. Bent or broken driver, worn piston oring or loose or broken check seal. Remove head and examine driver for bent or broken, adjust as needed. Check that piston oring fits snug, piston should not drop down cylinder under its own weight. Pull cylinder from body and check that black band (check seal) is in place around holes in cylinder. Good luck
Oct 26, 2010 | Porter Cable Tools & Hardware - Others
The drum got loose because the one of the top drum springs got unhooked. The spring holder on the plastic drum cover is broken. It was noticed in time and turned off. So it seems that nothing else is...
will the plastic ring in the second ring move to the other ring . the danger is if you put the spring in the second ring the drum may not be line up straight when you look from the top (the motor may be further back) causing the motor and back to rub on the back plate when loaded might be better to drill new hole ?
Feb 11, 2010 | AEG Lavamat 88840 Front Load Washer
Moen single lever kitchen faucet leaking at base and through spray. Can it be fixed? I lost my installation manual. Are there any online?
base leak is from bad o ring or loose spout very easy fix you can get a washer kit at lowes all you need is a allen wrench(sometimes comes in kit) a pair of channel lock pliers
May 09, 2009 | Moen 7840 Camerist Single-Handle Kitchen...
GLER642AS0 drum upper glide makes drum too tight
well you could .kenmore /whirlpool dryers only have a fat felt seal for the drum to ride on,but then the drum it's self is lined with a plastic ring.i have put many of those glide kits on a Frigidaire dryer.the drum goes over the glides,it can be tricky ..you can also have someone open the door while you try to work the glides into place with your hand from the inside.if you have any other questions please email thru fix ya. God bless ,tom
Jan 23, 2009 | Frigidaire GLER642A Electric Dryer
My washing machine is a Maytag Atlantis heavy duty, stainless steel. The machine is around 5 years old. Frequently we have to open the lid and distribute the clothes around, otherwise the drum spins out of...
this is a problem with these machiones. its drum rides on a ball and socket setup. with a plastic ring it rides on to cause the resistance when spinning. also centerd with big springs. its a job to replace . i would get about 200.00 to due.
if you use machine a lot then after another few years same thing again. poor design i think.
good luck.
batpup
Jul 28, 2008 | Maytag Washing Machines
My clothes are catching between the drum and casing(?), the drum seems to be loose. My dryer is a GE profile/prodigy
suspect front tub support/bearing ring worn remove top by removing screws under front edge of top lift top 1 screw each side of front on inside front ring attaches to front panel look for worn plastic ring and pads
May 31, 2008 | Dryers
Whirlpool Duet GHW9150P Front Load Washer Logo
286 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
