Question about Apple iPod MP3 Player
TURNING IT OFF
CANT TURN IT OFF
  • 3 Answers
It'll turn off by itself if you don't touch it for a while. Or press and hold the PLAY button until it shuts down.
Posted on Nov 01, 2008
How to turn on the jet sprayers on side of our pool?
turn each one of the auxs off one at a time remember which one it is then label it if the pump wont shut off then start turning off breakers until it goes off if you turn the breaker back on and it does the same bad relay
May 12, 2013 | Jandy Pool & Spa
Cant not get key to turn on igniton. it will only turn to the first position
Try turning the steering wheel while turning the ignition. The steering lock may be in a bind and have pressure against it.
Oct 15, 2011 | 2003 Volvo V70
Cant get the rear shocks out. can get to the nut but cant stop shaft from turning what should i do
use a large channel locks to grab the top part of the shock that protects the metal shaft from dirt and debris. You can then turn the nut with a wrench or turn the shaft with the channel locks. Turning the shaft is sometimes easier.
If you look closely at the top of the shock just under the bottom washer there is usually a hexagonal end that a wrench can be used on. sometimes it is not easy to get a wrench on because of clearances.
Aug 31, 2011 | 1996 Mercury Grand Marquis
The 32 inch TV started to have promblems turning on at first... then you had to unplug the unit to get it to turnn on, now you cant turn it on at all. Donthe 32 inch TV started to have promblems turning on...
Power supply board is dead.Replaced the power supply board will solved this problems.Tries Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Mar 03, 2010 | Akai LCT3285TA 32 in. LCD Television
Cant turn fan on with out turning the light on
Fan power is wired to light side of light switch. Move fan wire to other side of light switch.
Jul 11, 2009 | Hampton Bay 54 In. 5-Blade Fan, Chestnut,...
1983 monte carlo new starter cant turn flywheel i hear it an see it engage it but cant crank it over
try turning the engine by hand. to do this use a socket and ratchet on the big bolt on the bottom center pulley at the front of the motor, if you can turn the engine then you need to shim the starter.
Jul 26, 2008 | Chevrolet Monte Carlo Cars & Trucks
Hiphone
i already have the same problem- cant turn it on...is there any solution available?
Jun 27, 2008 | Lands Phones
Camera won't turn on
ok a little water spilled in my bag but i took my camera out and completely wiped it off ..but now my camera is not turning quickly then when it does i cant turn it off, before it even got to the stage where it cant turn off messages like acrd locked showed up or the message e18 i need help its not even my camera
Feb 24, 2008 | Canon PowerShot A410 Digital Camera
Apple iPod MP3 Player Logo
Top Apple Audio Players & Recorders Experts
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
