Question about Air Tools & Compressors
D:\ application can not run in Win32 mode
After i right click the c or d icon of the hard disk, it states that the c: application cannot run in win32 mode win32appli not fiod
How to solve the problem
Posted on Jan 03, 2009
    Problem Solver:
  • 17 Answers
Habe you run a virus scan?
Posted on Dec 12, 2008
C:\ application can not run in Win32 mode
d:\ application can not run in Win32 mode
Solution
To correct and solve this error follow this procedure
Run Task Manager (Ctrl-Alt-Del or right click on Taskbar)
Stop wscript.exe process if available by highlighting the process name and clicking End Process.
Then terminate explorer.exe process.
In Task Manager, click on File -> New Task (Run…).
Type “cmd” (without quotes) into the Open text box and click OK.
Type the following command one by one followed by hitting Enter key
del c:\autorun.* /f /s /q /a
del d:\autorun.* /f /s /q /a
del e:\autorun.* /f /s /q /a
c, d, e each represents drive letters on Windows system. If there are more drives or partitions available, continue to command by altering to other drive letter. Note that you must also clean the autorun files from USB flash drive or portable hard disk as the external drive may also be infected.
Type “regedit” (without quotes) into the Open text box and click OK.
Navigate to the following registry key
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Winlogon
Check if the value name and value data for the key is correct (the value data of userint.exe include the path which may be different than C drive, which is also valid, note also the comma which is also needed)
“Userinit”=”C:\WINDOWS\system32\userinit.exe,”
Posted on Aug 28, 2009
(Win32), Version: 5.1.2600.5512 conecting problem
1st You download Webcam Driver.
After this install the Webcam driver in the system.
Installation of Webcam Driver
Go to the control panel
Click on the System Icon
Click on the Hardware Tab
Click on the Device Manager s
Select the Unknown Device or printer device where yellow Question Marks sign on it.
Right click on it and uninstall it.
After this go to the top of the device manager and click on scan for hardware changes.
Driver installation Wizard start.
Brows Your Driver from the Hard Disk and click on next.
Driver will be install.
Jul 20, 2011 | Sakar Mini WebCam 69352
C: application cannot run in win32 mode ...huh???
may be your system restore disk omnly supports system 64 .
Nov 14, 2008 | Microsoft Windows XP Professional for PC
Problem
some virus effect your pc you can load any update version anti virus
on your pc..............
Aug 16, 2008 | Microsoft Windows XP Professional for PC
Error: "The application cannot be run in win32 mode"
click on start>>all programs>>accessories>>communications>>network setup wizard. follow the online instruction to describe yr network to the end u can access yr hard drive
May 22, 2008 | Computers & Internet
hi
go to start-run c:
if u can open it your sys is malware infected if u hace winxp sp2 pro and fat32 or ntfs partition.
scan your sys with avast ,qiuck heal and symantec update
Mar 26, 2008 | PC Chips (M925G) Motherboard
Open my system, click mycomputer and then opening only c drive, but D,E,F drives are not opening, if telling application cannot be run in win32 mode ( how can i solve the problems.)
Jan 07, 2008 | Microsoft Windows XP Professional for PC
Open drive
Go to Start/Run and type :
reg.exe add "HKCR\Drive\shell" /ve /d "none" /f
then type:
regsvr32 shell32.dll
Dec 18, 2007 | Microsoft Windows XP Professional for PC
To correct and solve this error, follow this steps:
1. Run Task Manager (Ctrl-Alt-Del or right click on Taskbar)
2. Stop wscript.exe process if available by highlighting the process name and clicking End Process.
3. Then terminate explorer.exe process.
4. In Task Manager, click on File -> New Task (Run…).
5. Type “cmd” (without quotes) into the Open text box and click OK.
6. Type the following command one by one followed by hitting Enter key:
7. In Task Manager, click on File -> New Task (Run…).
8. Type “regedit” (without quotes) into the Open text box and click OK.
9. Navigate to the following registry key:
10. Check if the value name and value data for the key is correct (the value data of userint.exe include the path which may be different than C drive, which is also valid, note also the comma which is also needed):
If the value is incorrent, modify it to the valid value data.
Dec 15, 2007 | Microsoft Windows XP Professional for PC
Air Tools & Compressors Logo
194 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
