Question about Nextel Cell Phones
How do I turn off the quick keys option for my Nextel i570 cell phone when text messaging?
    Scholar:
  • 70 Answers
1. At a screen that requires you to enter text, press menu.
2. Select the text input mode you want to use. A
checkmark appears next to the current mode.
You'll want to choose Alpha. GOOD LUCK
Posted on Oct 18, 2008
Sequence of keys that need to press to enter the PUK code in a motorola i570 nextel
This was a nearly intractable problem. Tracking down the PUK in the first place was hard enough, and then finding this code in order to enter the PIN was just as hard, since Nextel is now black-ops within the Sprint labyrinth of tele-representatives. If ever you need, call Sprint and ask to be immediately connected to the Nextel Devices Department. After many hours, I discovered both my SIM card's PUK and the following sequence that brings up a menu which allows you to enter the PUK; for the Nextel i570, when the SIM card is locked, push in rapid sequence * # (menu) 1
You should then be able to enter the PUK
Good luck.
Feb 13, 2011 | MYBAT Cherry Phone Protector Cover for...
Direct Connect feature is hard to engage(Motorola i570 Nextel)
Compare the pressure required on your phone with someone else's i570 phone. If yours is harder, you will need to replace it with another phone. (You can just swap the SIM card). If yours is the same, you will have to live with it. This button is not a user-servicable component. I have used about 8 or 9 different types of Nextel phones, and I have not noticed any difference in any of them.
Dec 29, 2009 | Cell Phones
How to take t9 off boost mobile i570?
There is no option on the i570 to actually " Turn off " T9, but there is the option to switch from "Word" to "Alpha" with eliminates the annoying T9 from interrupting your text message. The way you do this is by creating a new SMS text message or "Reply" to an existing message in you inbox. Either way works. Once in the new message window you want to press the "menu" key you will see "Entry Method", you then just want to select "Alpha" instead of "word" and the T9 will no longer be active.
Nov 16, 2009 | Cell Phones
Trying to send a text message from the nextel I710 motorola phone but text message is not an option under messanger center list how do i send text?
To send a text message for the i710, you may need to go to WEB, and go to send text message, there should be an option for this. Recommended that you get a texting package, due to it may run $0.15-0.20 per text. Let me know how it goes,
Thanks
Justin
Please Rate Me :)
Jan 09, 2009 | Nextel i730
How to take off text message signatures nextel i710
I have seen this issue MANY times before, what I can recommend for this exact problem, is to Reset to Defaults. Which will delete all your Downloads/contacts/saved info. This option should be located in menu-settings-security, password should be 000000 unless you have modified it. the option will either be, Restore Defaults, or Reset to Defaults.
Let me know how it goes, thanks
Justin
Please Rate Me :)
Nov 23, 2008 | Nextel i730
Quick Notes
This can sometimes depend on your phone. You can often go to your settings to change this. Once in your settings go down to messaging. Once in the messaging tab there should be an option that says text entry. There you can change your entry back to ABC mode.
Aug 15, 2008 | Nextel i850
I have a nextel I730
If you have a texting package, it is simple * even if you don't, it is the same options, just keep in mind, it is $0.15-.20 Per Txt * Menu - Web - Send Message Or Text Message
Thanks
Justin
Please Rate Me
Apr 03, 2008 | Nextel i730
How to text message on a i730 nextel
i cant text at all on the nextel i730.idk how to get started on it
Feb 20, 2008 | Nextel i730
I530 text messaging issue
To be able to send and reply to text messages you must have NOL net access. Press menu(left of the left arrow key), scroll to net, press ok(if an error message appears contact nextel for internet service), scroll to text messaging, press ok. From there you can write, read and reply to text messages. The reason for having to do it this way is because this phone as well as others with nextel were being produce when text was first being introduced to nextel, at that time motorola wasn't making nextel phones with the option of text, so it was up to the provider to give text access(via. net).
Sep 25, 2007 | Motorola Mobility i530 Cellular Phone
Cell Phones Logo
Top Nextel Cell Phones Experts
Rommel Balcita
Shehu Pro
Shehu Pro
Computer Repairing
Computer Repairing
Are you a Nextel Cell Phone Expert? Answer questions, earn points and help others
