Question about Sony DVP-S550D DVD Player
Sony DVP-NC600 Multi Disk DVD Player No Power
A sequence of event has made my dvd player completely dead. First my 3 year old inserted multiple dvds causing the carousal to get stuck. It would not rotate. I hold the unit down and gave a little shake and dvds started to fall, but the unit would still not close. The unit had power till now. It was displaying C 31 00 message, and it meant "disk is not inserted properly", that was true as it carousal was not going in. I shaked the unit a little and I heard a screw or something rattling, after that I lost the power in the unit. I opened the case and found that one lever (with spring attached) was slightly mislocated, I fixed that and I was able to push the carousal in, but still no power. I don't have a voltmeter, but I checked power to the click switch using regular line tester, it has power till there. What else can I do to revive this? Thank you very much
  • Shailesh Khanal Jun 12, 2006
    The fuse looks good, the wire inside is intact. I am afraid that the repair may cost as much as the new one. Sony has exchange program for this for $136.00
    President:
  • 3,130 Answers
Did you check the fuse on the main board?? Just be carefull when testing this unit with it open as it has line voltage on the power transformer. Unless you get a multi-meter and a diagram showing you the power supply your dead in the waterman. Sorry but you need the proper equipment to work on these things. This problem might even be a bit harder to find for A tech as its a man made problem I would advise at this point to put it together abd take to the shop. Good Luck
Posted on Jun 12, 2006
SOURCE:
My DVP-NC600 CD/DVD player will not recognize discs inserted. The carosel just spins freely and won't stop. HELP!
Welcome to fixya!
open up the screws , if you can check the tray if there is something inserted remove it and its ready to be used again ,
the reason is something is struck inside it may be a disk or something .
Check if helps you in any manner
Apr 30, 2011 | Sony DVP-NC600 Multi-disc DVD Player
My DVD got stuck in the five disk player. I took off the cover and removed the disk from the player and still get the e 27 00 message.
Hi, do a hard reset. Unplug from power, wait 10 seconds, plug back in and power up. That should clear the error message unless there is another disc in there somewhere.
Mar 01, 2011 | Sony DVP-NC600 Multi-disc DVD Player
PROTECT
http://www.usersmanualguide.com/
see if theres a manual here
May 04, 2009 | Sony DVP-NC600 Multi-disc DVD Player
I have a KD-27FS170 FD Trinitron Vega DVD/VHS player. The DVD disk will not eject. What is the solution? Manna
the assembly which moves the dvd door is either got stucked or the gears which moves the assembly needs replacement as they are cracked or worn out.
Mar 02, 2009 | Sony DVP-NC600 Multi-disc DVD Player
Sony DVP-NC600 Multi-disc DVD Player No Disc Error
The only other thing I can suggest, having repaired many Sony CD/DVD players, is to get a can of compressed air and try to blow any dust out from the laser assembly. Since you've already cleaned the lens (the most common problem), you also might have dust down inside the assembly. Try blowing with the air nozzle down inside, around the gap between the lens and the cover surrounding it. Do it from at least a couple of inches away, if the air is too powerful you can damage the wiring inside the assembly.
If this fails to correct the problem, your laser output may have diminished over time and the only repair is to install a new laser assembly. The cost of this part will most likely not be worth it to you since the unit is quite old now.
Sony DVP-NC600, CD/DVD Player
Hey llacy2,
There may actually be a number of reasons that this may be occuring, and there are a couple of things that you can try in order to resolve this type of problem.
You may wish to first clean the discs being placed in the DVD tray with a soft cloth. Any kind of dirt, scratches or cracks on the disc may cause the unit to immediately reject it. Once the disc has been cleaned, try to insert it again. If the disc is rejected a second time, you may need to try a different title.
If the problem still persists with more than one disc, the manufacturer has suggested both turning the DVD player off and fully unplugging the player (power cord, other connections and all). You may wish to allow at least 1 full minute before reconnecting the player and AC adaptor, but if the problem isn't resolved after doing so you may need to contact a repair facilty for further assistance.
Hope this helps you out.
Sincerely,
Aaron
Go Ahead. Use Us.
May 20, 2008 | Sony DVP-NC600 Multi-disc DVD Player
Sony DVP-NC600 Powers down during CD playback
The tray won't open. I took top off and dvd top side holder, but the laser mechanism won't disengage so the tray will open, even with no dvd in it. How do
I reset it. I power on, hit open key, it makes hum noise then goes by to
standby mode.
Jan 06, 2008 | Sony DVP-NC600 Multi-disc DVD Player
DVD player not working right
Check your cables between your DVD player and the TV, this play has component video outputs that could possibly cause this issue.
Dec 25, 2006 | Sony DVP-NC600 Multi-disc DVD Player
Sony DVP-S550D DVD Player Logo
113 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
