Question about Maytag Atlantis MAV6260AWW Top Load Washer
Motor pulley how do you remove the motor pulley and replace on a maytag atlantis washer?
    President:
  • 878 Answers
Bshu, first get yourself a bunch of rolled towells or something of that nature to place between the tub and rear cabinet. This way when you lean it back the pulley will stay centered with the hole. Remove the cap to the thrust bearing, it just pops off. You will see a lock ring sitting on washers. You can remove this with a flat blade screw drive and the cam will come off. Pull down on the pulley but be carefull to remember the order of the washers and bearings. If you are going to replace the thrust bearing kit, the part number is 12500036 series 12. This kit will come with a new pulley. After you have installed the new kit, getting the last retaining clip on can get frustrating. It is tight and you may need a third hand...hope this gets you going.
Posted on Jun 12, 2006
SOURCE:
Maytag atlantis washer #mavt754eww washer starts fills up then the motor squeals and washer stop and would not agitate or run.
Your model has only one belt that goes around motor, transmission, and drain pump pulleys. Most likely it is the cam bearing kit that has worn. That kit includes the big yellow pulley under machine at center and btake cam and associated washers and bearing. It also could be drain Pump seized up or could be motor is bad.
Nov 01, 2017 | Maytag Washing Machines
What is blck powder under the motor of belt drive Maytag washer MAV4057AWW
The powder is belt wear. Not to worry though, they last a long time. There is always some wear on all belts as they slide into the channel on the pulley.
Jul 22, 2013 | Maytag Atlantis MAV7551 Top Load Washer
My atlantis do not spin and drain .
Check if the motor is running, then proceed as follows:
  1. If the motor is running, the washer has a frozen pump pulley or a broken pump belt. Remove the pump from the washer and try to rotate the pulley manually. If it does not turn freely, it is frozen or stiff, replace it. If the pump belt is broken or worn out , replace it. Check the pump pulley before you change the belt.
  2. If the motor isn't running, the lid switch is probably defective. If it is so, the washing machine cannot spin and may not function at all. The lid switch is inside the washing machine main housing near the door frame. Usually you have to raise or open the top or front of the washing machine depending on the model to get to the switch. If defective, you must replace it. Check it's continuity when activated using an ohmmeter. A defective switch does not have continuity when activated.
Nov 06, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Maytag Atlantis MAV6200AWW Washer Problem?
I HAVE AN ATLANTIS MAYTAG WASHER . I HAD THE SAME PROBLEM AND I SOLVED AS FOLOLWS. REMOVED THE MOTOR, I APPLIED GENERAL PURPOSE GREASE ON BOTH SIDES OF THE SLIDING MOTOR SURFACE PLATE (MOTOR BASE) . THE GRASE HELPS THE MOTOR TO SLIDE BECAUSE AS YOU KNOW THE MOTOR DOES NOT HAVE ANY ADJUSTMENT. TRY IT PLEASE . GOOD LUCK
Feb 20, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Maytag atlantis will agitate won't spin
I had the same problem with my Atlantis a couple of months ago. It turned out to be the bearing for the tub drive pulley. When you look under the washer there are three pulleys. The one for the motor is ont he left, the drain pulley on the right and the big one in the middle for the tub. What I found is that when the bearing went bad, the tub would fill and turn for washing, but it would not turn at all for spinning. I could turn the pulley by hand but the tub refused to budge. I removed the main pulley and could see that the bearing had exploded. You can't buy just the bearing but the whole pulley kit is like $35 so I got off easy. I put the machine back together (which is tricky) but it works fine now. The pulley kit comes with complete instructions but it's really straightforward. The tricky part is that you have to pull down on the end of the drive shaft in order to get the retainer ring onto the pulley. That can be difficult if you don't have a lot of room to work or have a partner to assist. You can replace the whole thing or just the bearing and save the pulley for a rainy day if you want. I opted for the whole replacement. But I saved the old. cause ya neva know!
Jan 13, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Pulley broke
i am instructing on the motor pulley.it is plastic,get it off any way you can with out hurting the motor shaft.i think somtimes i would use large channel locks.you dont need to save any of it.
Jan 08, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Hi..i have a maytag top loader washers that won't turn or spin...can hear belt squealing and smoking
tip machine machine back now access belt should have motor pulley, pump pulley and middle big yellow thrust bearing,, usually pump is broken
Jan 03, 2009 | Maytag Atlantis MAV7260B Top Load Washer
Maytag Washer will not spin
Pull the unit forwardand lean it back about 45 degrees. You'll have to play with it a bit, but once it's far enough out, it will lean back without you having to hold it. Remove and inspect the belt(s) are they in good condition? Next, check the pulleys (wheels) underneath. Do they turn? One is for your pump, one is for your transmission and one is for the motor. (in case one doesn't turn, you'll know what portion needs to be worked on). Also check the track on your pulley the belt sits in. Is it dammaged or worn?
Jun 02, 2008 | Maytag Atlantis MAV6451 Top Load Washer
We had the same problem and needed a new motor.
Apr 05, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Maytag Atlantis MAV6260AWW Top Load Washer Logo
160 people viewed this question
Top Maytag Washing Machines Experts
jimorris77
Sheldon Dedek
Bill Long
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
