Question about Sylvania 6842PE 42 in. HD-Ready Plasma Television
Power Supply Do the 6842pe m and the 6842pe a versions have the same power board? They seem to be having the same problems.
  • Anonymous Dec 21, 2008
  • 26 Answers
No. They are entirely different. Panasonic was the supplier of the 6842PE and Funai was the supplier of the 6842PEM.
Posted on Oct 27, 2008
My power comes on for about three seconds then shuts off. do you know what might be causing this?
The power supply of yur television have problem.Theres some leak or shorted parts in the power supply.Need for repair the power supply.
Jul 04, 2011 | Sylvania 6842PE TV
My 6842pe does not turn on. when I turn on it goes green light for couple of seconds and then red light
Hopefully only your power supply is to blame. Then you can repair it or get it repaired for a little more than $150 or get it replaced for about twice as much plus the cost of labor. If you or a repair person start testing the boards and see that one or more of them have also failed then the cost of parts and labor will go up. It looks like Encompass Parts has parts still available for this television and the power supply is $194.
Jan 27, 2011 | Sylvania 6842PE 42 in. HD-Ready Plasma...
I turn on tv and two second later it turns right off. no picture when this happens
I have the same exact TV and the same exact problem it seems pretty popular, but there also seem to be different answers to similar questions. Some sort of problem with the Power Supply Unit. Maybe a blown fuse or bad capacitor, thats what i am about to check for, ill be coming back here in hope of finding a solution.
Sep 30, 2010 | Sylvania 6842PE 42 in. HD-Ready Plasma...
Sylvania 6842pe blew fuse, replaced fuse, and nothing,no lights, noise, nada. replaced power supply board with the chord attattchment and still no power, no lights, and no noise. Was wondering could it be...
Yes,replaced all the boards that related to the power supply.Useally completely dead,it effect all the ICS in the boards,never able to tell which boards.U are not a tv tech.don't do this everyday's will not have skills or any idea which board is dead.
Apr 06, 2010 | Sylvania 6842-PEM 42 in. EDTV-Ready Plasma...
We turn on our tv and it turns itself back off immediately, what can be done?
its the problem of overheating in the power supply board of the TV.on the power supply board of the tv there are few capacitors and IC.any of this ic is got short or may be weak.so due to this when you start the TV the current passes from electric outlet to the power supply board of TV.but when the current passes from that weak/faulty part at that time current gets stopped or slow and the board overheats and TV shuts off. this is a common problem faced by many other users too.the possible option to solve this issue is to check the power supply board by a meter and continuity tester and replace the faulty component on the board which is short due to which power supply board is getting overheated.its bit technical job but yes its not at all a costly repair to do or get it done by the technician. for required parts it can be easily available from local electronic hardware shop.] This will help. Thanks please keep updated.please please do rate the solution positively .thank you for using fixya
Mar 20, 2010 | Sylvania 6842PE 42 in. HD-Ready Plasma...
When i turn my 42 inch plasma sylvania on, it makes a sharp high pitched squeal, then shuts off. it does this repeatedly, whats the problem, and how do i fix it?
You have a short on one of the drive boards making the power supply squeal. You will have to unplug each board until the squeal is no longer there. Which ever board it is will have to be replaced. Thanks for using fixya.
Nov 26, 2009 | Sylvania 6842PE 42 in. HD-Ready Plasma...
Sanyo clt 2054 dead.just a clicking sound, no picture no sound no power light. replaced main board same problem.
As there is no Power, there seems an issue with Power Supply. Might be a blown capacitor.
Do you hear any sound when you Plug on the LCD and the Button?
What i assume, it has to be the Faulty Power Supply Board. As you are not getting any power , you should have check the power supply board followed by main board .
Check the Power supply board and invertor circuit and replace it, if Faulty.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Aug 02, 2009 | Televison & Video
I was watching t.v. and the screen turn black and the sound was gone as well.and has no power at all
hello, you need to check the power supply board,check for any blown fuses or burned parts.that should be your first step. and if you don't have any repairs skills call the serviceman.
good luck
caypianan@yahoo.com
May 11, 2009 | Sylvania 6842PE 42 in. HD-Ready Plasma...
Switches off
You have a power supply problem ,most likly the main board will have to be replaced, My best advice is to call out an authorized Sylvania dealer because if you make a mistake on what board is bad, they will not take it back. Play it safe. Good Luck
Mar 23, 2007 | Sylvania 6842PE 42 in. HD-Ready Plasma...
Sylvania 6842PE 42 in. HD-Ready Plasma Television Logo
347 people viewed this question
Top Sylvania Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
