Question about Canon ZR25MC Mini DV Digital Camcorder
Regarding cassette mechanism problem
I have Canon ZR 30Mc mini dv camcorder since last 3 years. Player mode and camera mode all functions are working well. But the problem is that the cassette mechsnism does not go inside with or without cassette. When I close the compartment cover without cassette the cover opens out after 5 seconds. The mechanism does not go inside. Please help me in this matter. Reply soon. Thanks
SOURCE: Cannon ZR 60 camcoder Cassette copartment does not open
Try these steps: 1. Open the tape cover fully until it clicks open. 2. Turn the camcorder on to "VCR Mode." 3. With the cover still open and the camera in "VCR mode," take out the battery. 4. Put the battery back in--out should pop your tape. Although this worked for me, I then inserted and used a head cleaner tape which then became stuck as well. Tried the same trick to eject it, and it did come out after several tries. I will take it for a repair estimate before inserting any other tape.
Posted on Mar 25, 2007
SOURCE: REMOVE THE CASSETTE message
They all use the same transport mechanism, which is flawed. I sent mine back under warranty as this is a well-known issue with certain Canon camcorders from their cheapest ones to their most expensive ones (like the GL2). It is a common error. Do a search on Google for "Canon Remove the cassette" and you'll see lots of entries.
See http://mysite.verizon.net/resohb20/
Posted on Dec 05, 2007
SOURCE: MV530i Mini DV
clean the head
Posted on Mar 18, 2008
MrsJGreen
  • 130 Answers
SOURCE: software for the canon zr300 mini dv digital camcorder
You will likely have to order this through Canon.
Posted on May 30, 2008
old marine
  • 2039 Answers
SOURCE: FireWire for camcorder mini dv
Go to this link. Click on "Frequently Asked Questions" and then click on the appropriate link (#4). Basically, once the firewire cable is connected, make sure that the camcorder is in the playback mode, is turned on, and you see "DV IN" on the LCD. If all that is happening, your computer/software should be able to "see" the camcorder and download the video.
Posted on Aug 21, 2009
I got the problem with my canon XL2 since last 3 months ago. The tape cannot unload sometimes. During recording and run out with tape, try to change with the new one but the cassette compartment cannot...
that is could be the cassette in switch or door swith inter mitent contact, or the mode switch for the mechanism position....
or a good clean up of the mechanism...
hope that will help you
regards allan
Sep 02, 2010 | Canon XL2 Mini DV Digital Camcorder
Canon ZR-800 Mini DV Camcorder tape stuck
The way I can get a tape unjammed on my Sony camera is to remove the battery, plug the camera into the AC charger that is plugged into the wall outlet. Then power the camera on, wait a few seconds. Then unplug the charger from the outlet, wait a few more seconds (camera still in "on" position) and then plug it back in. I have used this method at least 3 times to get the camera to release the tape and finally eject. However, the tape is usually pulled or stretched and I use a small flat head screwdriver to wind the tape back in, but expect that portion of the video to be ruined.
Feb 23, 2009 | JVC GR-DV800U Camcorder
Cassette Loading Problem in Canon ZR200
My Canon ZR 200 was electing all cassettes new and old alike. On FIXYA I forum I found a superb solution. That is just SRTIKE at the cassette side of the camera twice. YES I did it and it PERFECTLY OK now.
Can anyone say the actual mechanism behind this fixing?
Aug 29, 2008 | Canon ZR200 Mini DV Digital Camcorder
Mini DV Cassette won't come out. Cassette case moves up and down but doesn't open.The display keep on saying Cassette is ejecting.I don't use it as often.
I AM HAVING THE SAME PROBLEM. HAVE NOT USED THE CAMCORDER FOR A YEAR AND A HALF. IT MECHANISM MOVES IN AND OUT BUT WILL NOT OPEN UP TO PUT A TAPE IN. VERY FRUSTRATING.
Feb 21, 2008 | Canon ZR65MC Mini DV Digital Camcorder
Cassate tape will not eject from my Canon ZR85 Mini DV Digital Camcorder
I found a temporary solution for this problem. When the tray with the cassette tape comes out remove the battery so that the tray will not go inside again. Now on top of the tray it will be written as "PRESS" just adjucent to it you can see a spring connected to the tray just press the string down wards and the tray opens and you can replace the battery. Hope this can help.
Feb 01, 2008 | Canon ZR85 Mini DV Digital Camcorder
MV530i Mini DV
The mechanical part of the camera is gone. You better replace the camera with a new one.
Dec 06, 2007 | Canon MV530i Mini DV Digital Camcorder
happened to me too.. only with a sharp vl z3. It happened to me because it was filming while the battery ran out so the film is still in the camera!!! noooo!!! dang it!
Nov 20, 2007 | Video Cameras
Canon ZR100 Mini DV Digital Camcorder Problem
I have a Canon4.gif ZR 10 And it does say remove cassette often and recently it eat the tape and destroyed our recordings.
Does this have something to do was the round small battery1.gif in the front part of the camcorder?
Is this a consumer complaint I feel uncomfortable because we have alot of Cassettes recorded and we are afraid to play them because it might chew them up.
There is a mini cassette player2.gif that can play the cassetes ????
Need Help!!!! What am I going to do ??? PNicioli@sbcglobal.net
Sep 24, 2007 | Canon ZR100 Mini DV Digital Camcorder
Loading unit problem is a common mechanical problem in camcorders. To remedy the problem, trained tech need to disassemble the mechanical system around the loading and replace few broken gears (plastics) and adjust it. Repair cost may run close to half of the new camcorder. If you really got to repair this camera for some sentimental reason or for special needs otherwise better to invest the repair charge into a new camcorder.
Mar 15, 2007 | Canon ZR60 Mini DV Digital Camcorder
Canon ZR25MC Mini DV Digital Camcorder Logo
88 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
