Question about Poulan/Weed Eater No. Bvm200le 711482 24cc Gas Blower/Vac
Poulan PBV200 LE
Blower starts with new plug and cleaned air filter. Loses power after starting.
  • Anonymous Dec 07, 2008
    What else is new I've had three The first was free and used but given to me.
    It worked quite well better than most in my opinion.
    So I bought a brand new one that broke after two days of using it. I might add that I used Poulan brand 2cycle oil mixed according to their directions.
    Two days later it burned up.... Seized the piston! no less. Home depot replaced it right away no questions asked.
    So by now the new one has about 10 hours on it and it is starting to have the same type problems. Oil running out the side by the carburator. Lack of power, etc. Remember still using their oil mixture according to their directions! It does not come up to full speed and yes the spark plug is brand new.
    I'm a licensed Aircraft mechanic and can't keep a leaf blower running more than ten hours... Hmmmm perhaps you should take the train.
    My opinion is starting to lean toward thinking Poulans leaf blower is a piece of ****.
    Problem Solver:
  • 6 Answers
Probably a low compression problem.
Posted on Nov 19, 2008
I have a 2004 Poulan Pro PBV200 leaf blower, and have purchased a new ignition coil. My question is, how do I install it?
you have to pull the whole unit apart
air gap is important so note the gap on the coil before undoing the old one
exploded views
Poulan PBV200 Pro Leaf Blower Parts
you tube link
Poulan pro leaf blower no spark
POULAN PRO PBV200 INSTRUCTION MANUAL Pdf Download.www.manualslib.com > Brands > Poulan Pro Manuals > Blower > PBV200
Oct 13, 2016 | Poulan Garden
Howdy I'm unable to keep my Poulan Pro PBV200 leaf blower running unless I keep the choke three quarters of the way closed. Gas and oil mix is new and changed spark plug. Could the exhaust be blocke
Yes, There is a spark arrestor screen on muffler. It could also be a carburetor that needs rebuilding or a simple fuel mixture adjustment.
Jan 01, 2015 | Poulan Garden
Gas blower engine surges and shuts off when engine gets hot
check your fuel lines for cracks, could be sucking air or could be your carb needs cleaning, make sure you clean the screen inside the carb, if you run it with the choke on partially does it smooth out and quit surging, if so it is definitely a fuel problem. Hope I helped you. 2StrokeJim
Nov 27, 2011 | Poulan 25CC Gas BlowerVac
Is getting air in gas line, will not start
If the hoses are connected right and they are in good condition, it could be bad gas,sparkplug or carburetor needs cleaned and/or a rebuild kit. Check the link below for parts:
http://www.ereplacementparts.com/poulan-fl1500-type-blower-parts-c-16962_31724_31725.html
Feb 02, 2011 | Weedeater Featherlite Blower 18 Cc 150 Mph...
One year old Poulan weedeater starts right up but will only run with choke about half way on. Warm it up that way but it does not run any better. New gas, new spark plug, clean air filter. The weedeater...
CHECK THE SCREEN ON OUTPUT OF THE MUFFLER. ITS CALLED A SPARK ARRESTOR, THESE GET OIL FOULED AND MAKE EM A BEAR TO RUN . CLEAN IT UP AND SHE WILL RUN LIKE A CHAMP, THE CARB MIGHT NEED REBUILDING ,FUEL FILTER AND A SPARK PLUG IS THE FIRST THING TO REPLACE .. IF'N I WAS ANY HELP VOTE FOR ME ...THANKS.. JAY
May 25, 2010 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
My Poulan Pro 200 model #200pbv200le will not start.Replaced the carb, fuel, fuel filter,plug. When I pull the cord sometimes I see a spark, sometimes- most of the time I don't see a spark.Replaced fuel
Check your compression...if it reads anything less than 100psi you need to tear it down and replace the piston ring. Looking for the spark is unreliable, get an in-line spark checker and check for spark. Loss of compression due to a stuck piston ring is very common in the pbv200 series.
Aug 31, 2009 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
Echo trimmer won't start, gasoline flows out of exhaust
look at choke and air filter. ensure choke is operating and clean air filter.
May 24, 2009 | Poulan/Weed Eater No. Te475 952711797 17"...
Poulan weedeater will only run with choke half way on
this could one or a combination of a few things
1 check inside the tank for dirt 2check that the filter screen inside the tank is not plugged3 make sure the gas feed tube is not restricted pinched in the case or kinked also you can try a simple carb adjustment.also check to make sure the plug is gapped to the right specs good luck and i hope one of these suggestions do the trick
May 02, 2009 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
Poulan/Weed Eater No. Bvm200le 711482 24cc Gas Blower/Vac Logo
733 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
