Question about Frigidaire GLTF2940ES Front Load Washer
I press the start button and it says error.
I think my wife opened the door during a wash cycle without knowing and now the washer says error when I press the start button. Is there a reset button?
  • 1 more comment
  • Anonymous Dec 25, 2007
    Won't drain, says LOC
  • Anonymous Sep 09, 2008
    dr light on machine not working
  • need-a-wash Sep 17, 2008
    Tried the select + options and unplugging it. Neither work - door light will not come on and err message is "dr". Doesn't make the sound of locking when I push start. How do I check the door lock switch? Know where it is located and how to get to it?
    Thanks. Washerless
    Problem Solver:
  • 5 Answers
Had the same symptoms. Tried unplugging power for 5 minutes, no change. Did the Select+options button for 5 seconds, the column of lights flashed once, and then I hit the Start, the door locked, clean clothes followed shortly thereafter :)
Posted on Jan 27, 2008
Select and option for 5 seconds worked for me. Thanks all!
Posted on Nov 06, 2011
Rokkr 101 - Thank you, thank you, thank you. We just had the same problem with an ERR code and LOC. I did the Select+Options buttons and it now works
Posted on Apr 12, 2008
  • 641 Answers
Try to disconnect washer's main power cable for a minute and then connect it back, it might reset the program. In case it will not help, you should check the door switch. A defective door switch, will prevent washer starting the process. Good luck !!
Posted on Jun 12, 2006
Kid 60 s10 please give fault codes
Hi Roger, Hope this helps......CHEERS..
KENMORE DISHWASHER ERROR CODES
Kenmore Dishwasher Error Code = Start Resume light blinking slow
When the dishwasher door opens or electrical power is removed during the cycle then the dishwasher will not start again. The door is detected as being closed and the Start Resume button is being pressed
Kenmore Dishwasher Error Code = Clean light is blinking 7 times
Heater circuit fail. Control panel did not detect the water getting hot. Did not detect heating element was energized to heat the water during the wash cycle
Kenmore Dishwasher Error Code = Sanitize LED blinking at end of cycle
Control panel could not detect if sanitation has been achieved
Kenmore Dishwasher Error Code = Console light blinking rapidly
There is a stuck button on the control panel
Kenmore Dishwasher Error Code = Clean light is constantly illuminated
Dishwasher cannot start a wash cycle until it sees that the door has been opened after the previous washing cycle
Kenmore Dishwasher Error Code = Control lock LED is ON but not responding to pressing of the keys
Turned on by accident or there is a control detected key pad problem
Mar 31, 2016 | Kenmore Dishwashers
Oko 72630. Why is it stuck on rinse cycle?
Could be several reasons:
- Selected the "Night cycle" program (means standing with the drum full of water, reason: too much noise in the spin cycle)
- Set to the "Rinse hold" (means standing with the drum full of water, reason: wrinkles on the clothes)
According to your description I think that this is not a failure otherwise error E20 will be appears on display.
Once the washing programme has come to an end, END illuminates on the programme progress display.
If RINSE HOLD was selected, the display beside the START/ PAUSE button flashes.
1. After a rinse hold, the water must first be pumped out:
- Either press the START/PAUSE button (the water is pumped out and the washing is spun according to the completed programme;
After the START/PAUSE button is pressed again, the spin speed can still also be changed during spinning), or
- Turn the programme selector to PUMP OUT and press the START/PAUSE button (the water is pumped out without spinning),or
- Turn the programme selector to SPIN or SHORT SPIN and press theSTART/PAUSE button (the water is pumped out and the washing is spun or gently spun).
At the end of this programme step, the END indicator will illuminate.
2. Open the door.
As soon as the DOOR indicator lights up green, the door can be opened.
Dado
Aug 15, 2015 | AEG Washing Machines
Motor won't turn on Samsung VRT Plus WF433B*GJ**
When washing heavily soiled loads, do not overload your washer in order to assure good cleaning results.
To add a forgotten item:
1. Press the Power button.
2. Press the Start/Pause
3. Wait for the door lock light to go out (Immediately).
4. Add the item, close the door, and press the Start/Pause
The door safety state continues for 15 seconds and the cycle is restarted.
ensure thorough cleaning,
To
Try washing bedding, towels, undergarments,
contact using the ActivFresh
GETTING STARTED
1. Load your washer.
2. Close the door.
Z_
Push the laundry into the drum completely to prevent the laundry from being caught in the door or
....... from falling out of the drum.
3. Press the Power button.
4. Add detergent and additives to the dispenser (page 20-21).
5. Select the appropriate cycle and options for the load (page 14-16).
6. Press the Start/Pause
7. The Wash Indicator light will illuminate.
8. The estimated cycle time will appear in the display.
The time may fluctuate to better indicate the time remaining in the cycle.
The actual time required for a cycle may differ from the estimated time in the display depending on the
water pressure, water temperature, detergent, and laundry.
9. Before your washer starts to fill, it will make a series of clicking noises to check the door lock and do a
quick drain.
When the cycle is complete, the door lock light will go out and "End" will appear in the display.
DO NOT attempt to open the door until the door lock light is off. To add a forgotten item, see
"Loading your washer" section (page 13).
When your washer is restarted after a pause, expect a delay of up to 15 seconds before the cycle
continues.
Pressing Power button cancels the cycle and stops your washer.
The pre wash, wash, rinse and spin indicator lights will illuminate during those portions of the cycle
Nov 28, 2013 | Samsung 4.3 cu. ft. VRT Plus , Steam and...
My wife hit pause during the wash cycle to remove BBs from my sons pocket. She opened the door removed the BBs closed the door and hit Play/Start when she got the error E27. I have unplugged the unit for...
  1. Hold down the "Allergy rinse" button, "Spin Selection" button at the same time.
  2. Turn the Wash selection knob to the left on "Cold". Result: You should see different codes flashing on screen, this is resetting the machine's error, and is exactly what we want.
  3. After a few seconds turn Wash selection knob to "Off".
  4. Turn machine back on.
Result: Your mashine should work
cheers
Aug 31, 2017 | Bosch WFVC5440UC Washer
LG WM1814CW Front load Washer dE error? I get the dE error everytime I push the start button. The door wont open or close. I can hear the latch moving inside but nothing will happen. The "Door...
A dE error code indicates that the washer door was unable to lock. This can normally be resolved by performing a simple reset on the washing machine.
How to reset the washing machine:
1.
Press POWER to turn the washer off.
2.
Unplug the washer from the power outlet or turn the circuit breaker to the unit off.
3.
With the power disabled, press and hold the START/PAUSE button for 5 seconds.
4.
Plug the washer back in, or turn the circuit breaker back on.
5.
For more information about how to reset your specific model, please refer to the owner's manual.
Press in on the door firmly and select any cycle. The washer door should lock, and the cycle should begin without an error code appearing on the display. If the cycle does not begin and the dE code appears again, repair service is required.
Feb 03, 2018 | LG WM1814CW
Washer loader door is locked and i cant open it
this kind of door lock is called PTC door lock.It is designed for protecing you from opening the dooe during the washing and spining cycles which may hurt you.So, if you want to open the dooe during cycles,pls press "stop",then ,wait 2 mins,you will be able to open it by then.the other situation is that,the power is cut off during working cycles,solution is:re-start the washer and directly open the door.Pls note that this kind of lock has to work under power.
Mar 14, 2010 | Kenmore 3.8 cu. ft. HE4t Front Load Washer
I am getting a f26 code and my washer wont start when I press start
DOOR SWITCH ERROR
If the door has not been opened for 3 consecutive cycles or the door switch is open while the door is locked for more than 5 seconds.
Possible Causes/Procedure
-Door not opened during 3 consecutive cycles.
1. Open and close the door.
2. Verify CCU operation by running a Diagnostic Test or any cycle.
-Door switch open while door is locked.
1. Push the door and check if it is completely closed.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 23, 2010 | Kenmore Elite HE5t Washer
F-26 flashing
DOOR SWITCH ERROR
5 seconds.
Faulty door Switch or CCU board or door not closed during run cycle.
Starting Diagnostic Test and bypassing
the Service History Mode:
Execute this procedure with an empty drum. All
of the steps below must be done in sequence
in order to reach the Diagnostic Test. This
executes the automatic test but does not show
the error history.
Close the door.
Push POWER.
Select the CLEAN WASHER cycle.
Press EXTRA RINSE four times within
5 seconds.
Press EXTRA RINSE to advance to the
next step of the test procedure.
If the starting procedure fails, push
PAUSE/CANCEL, then repeat the starting
procedure.
Nov 01, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Maytag Neptune Leaking From the Door
possibly door lock not latching could be a bad wax mtr (within door lock asm) or control board
Dec 12, 2008 | Maytag Neptune MAH5500B Front Load Washer
Washing machine door blocked
Try to unplug the unit for 10 to 15 minunets, the washer may reset its self to default mode.
Feb 13, 2008 | Whirlpool AWM6120 Front Load Washer
Frigidaire GLTF2940ES Front Load Washer Logo
259 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
