Question about Husqvarna Backpack Blower 25cc, 140 Mph, Model# 125bt
Leafblower husqvarna backpack leaf blower 150bt 50cc. it starts when you give gas to raise rpm it choksup . its getting fuel , the air filter its not cloged up, chocke is operational , fuel lines are clear. can you help me?
Carb adjustments weedeater gb1 22v
Posted on May 26, 2009
  • 163 Answers
Check the fuek lines for hole and leaks, check the fuel filter and clean if necessary. remove the carbuerator and inspect the gasket; it should be soft and flexible, if it seems hard or brittle replace it. clean the carb with carb cleaner sray (available at any local auto parts store) and compressed air. make sure you get inside the small fuel rail holes. check the primer bulb for pin holes and seating/sealed properly. if that doesn't work have the carb repaired at a service center or replaced.
Posted on Nov 30, 2008
  • Antonio Boscia
    Antonio Boscia Nov 30, 2008
    check the fuek lines for hole and leaks, check the fuel filter and clean if necessary. remove the carbuerator and inspect the gasket; it should be soft and flexible, if it seems hard or brittle replace it. clean the carb with carb cleaner sray (available at any local auto parts store) and compressed air. make sure you get inside the small fuel rail holes. check the primer bulb for pin holes and seating/sealed properly. if that doesn't work have the carb repaired at a service center or replaced.
  • Rick Nov 06, 2011
    There is also a screen inside the bottom of the carburator where the fuel line goes in. Make sure that screen is also clean.
Why won't my Husqvarna 150 BT blower shut off? It starts and runs great, but won't kill with the switch.
Kill switch most likely has broken wire between switch and engine. When in "kill" position, it should connect the top of the sparkplug to the rest of the engine. If it doesn't, either the switch is bad or the wire is.
Jun 15, 2015 | Husqvarna 150BT 50CC Gas Leaf Backpack...
How to disassemble the throttle/trigger assembly on at Husqvarna 150BT blower.
Internal or external snap rings usually require a special pair of pliers to remove. In absence, you might try a very pointed pair of needle nose pliers or even a pair of dental tools or similar. Once the ring begins to dislodge from its groove you should be able to work it out. Reinstallation might require the specific tool.
Oct 03, 2014 | Husqvarna 150BT 50CC Gas Leaf Backpack...
Why is it failing?
open gas cap and see if it will run again. m,any times the gas tank vents clog and the engine can't draw gas after a few minutes.
another thought is the oil mixture.. 50:1 with oil made for air cooled engines....not boat engine oil
Apr 02, 2014 | Husqvarna 150BT 50CC Gas Leaf Backpack...
My Husqvarna 150BT leafblower was running great then started to loose power like when I run out of gas, I shut it off check fuel level which was fine, cleaned the air filter, added more fuel and pulled the...
Pull the muffler and look for scoring on the piston. I think you cooked it my friend. You may have a bad coil or fuel cap, but it's more likely you ran the mix too lean.
Nov 04, 2013 | Husqvarna 150Bt Leaf Blowers
If i pull back the trotal on my husku boy 50cc to fast it just bogs out and will cut out it never uste to do this it was siting it my shed for about 6 moths ive cleand the fiter and put fress 2 stroke...
With todays gasoline it turns to what is called varnish very rapidly and more than likely some of the fuel that set in the carb over those 6 months has turned into a gummy varnish so the carb probably needs cleaned, If it is not to bad you can probably adjust the carb with the air/fuel mixture screws and keep it running well till end of the season, shouldn't take more than 1/8 to 1/4 turn though. I hope this helps
Oct 03, 2013 | Husqvarna 150BT 50CC Gas Leaf Backpack...
Plastic tube for blowing the air keeps falling off the blower. The clamp won't keep it in place
easy solution....just screw 2 small sheet metal screws into the tube to hold them together
Sep 06, 2013 | Husqvarna 150BT 50CC Gas Leaf Backpack...
Start
They are refering to the 'fuel primer bubble' located on the bottom of the carb.
Jun 23, 2013 | Husqvarna 150BT 50CC Gas Leaf Backpack...
Husqvarna Backpack Blower 25cc, 140 Mph, Model# 125bt Logo
1,217 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
