Question about Kyocera Slider V5 SE47 Earbud Hands Free Headset
My Phones Statics
When I turn on my phone is has static is a Kyocera Slider
0 characters
1 Points
Have 3 0f these phones bought new charger and still will not come on
Hi Stella, I would take all 3 phones and new charger to a cell phone store and get some advice from a store person... I'd say faulty new charger.....CHEERS..
Mar 27, 2016 | Kyocera Clip S2100 Paylo Prepaid Phone...
Static t305 paired to iphone
Do you get static paired to other phones?
Motorola Support
Apr 12, 2014 | Motorola Mobility Bluetooth Hands-Free...
How do i hard rest my phone
  1. From the main home screen, tap menu
  2. Tap Settings, then Privacy
  3. Tap Factory data reset
  4. Tap Reset phone
  5. Enter your password if required, then tap Erase everything to confirm. If those steps don't work perform the following steps:
  6. Turn the power off. If your Kyocera Echo is frozen, pull the battery out and reinsert it
  7. Hold the Volume Down button
  8. Press and hold the Power button until the device turns on
  9. You are now presented with a menu that allows for Fastbook, Recovery, Clear Storage, and Simlock
  10. Select Clear Storage by pressing the Volume Down button
  11. Press and release the Power button
  12. Now simply confirm your decision: Volume Up for YES and Volume Down for NO
Dec 24, 2013 | Kyocera Echo Smartphone Sprint
When i turn the volume up or down i get a static noise, and when I try to use the microphone i get no response. I know the sound is working because i can hear music with static, but the microphone doesn't...
The static noise may be caused by dust! To clean it out spray some Servisol video 40 into the volume control and move it up and down. If it goes away it was just dust.
The mic is another thing. The only thing I can think off ist that it's got switched off somehow on your laptop. Or either the control panel slider for microphone input is set to low?
You can get Servisol from Radioshack USA or Maplin UK or that type of shop.
Nov 28, 2009 | Razer Barracuda Gaming Headset
Lost instructions on how to sync bluetooth to new phone
If you go in to your phones menu you will find a bluetooth snyc tool. The phone should pick up the signal if the earpiece is turned on. One thing this multifunction button does NOT do is turn the unit on and off. The entire switch itself slides up and down. There are times when you simply don’t want to bother with the earpiece, change wireless headphones, or don’t want to risk accidental calls. So the slider switch is a much easier way to keep track of whether or not the H670 is on or off than waiting for a blinking blue light that may never come.
Have a great day.
Jun 29, 2009 | Motorola Mobility H670 Wireless Headset
Ventrilo static weird occurance
First, make sure your mike/headphones are plugged in all the way to the correct jack port.
Then, re-download and install vent.
Also, go to "setup" in vent, then make sure the inbound and outbound are either set higher or lower than the default.
Hope these help, and please rate ^_^
Mar 07, 2009 | Dynex Stereo Headset with Noise-Canceling...
Check this link - i think your question is answered quite well; Sorry if not great news - these are the guys to contact for more info or to complain - please do or we will never stop this sort of thing; Hope it helps some :)
Apr 13, 2007 | Kyocera Slider V5 SE47 Earbud Hands Free...
Headsets Logo
14 people viewed this question
Top Kyocera Headsets Experts
Brian Sullivan
Brian Sullivan
Are you a Kyocera Headset Expert? Answer questions, earn points and help others
