Question about Whirlpool GS6SHAXMQ Side by Side Refrigerator
Side by side keeps popping breaker
I have unplugged the defrost coil and still pops breaker
  • 2,006 Answers
It is very doubtful that a defrost heater would do anything by open (NOT short) so that is not a likely cause of you popping the breaker. I would look at the compressor relay and capacitor as more likely areas that would cause it. UNLESS the compressor is locked up and that would cause it everytime.
Posted on Jan 02, 2012
  • suprjagfan Jan 03, 2012
    It ended up being the defrost heater. Thanks for the feedback.
Pops Circuit breaker when plugged in
Have you tried plugging it in to a different outlet? You may have too many things using that same circuit. Seems worth a try - hope it helps. We found that our fridge was using the same circuit as our washer and microwave and this kept it from popping the breaker after we used another outlet.
Nov 23, 2013 | Hotpoint HSS25GFP Side by Side...
Electronics breaker keeps tripping switched
write down all auxs then unplug all then turn on and plug one at a time till it pops probably heater ignitor if ok bad pump motor
Aug 18, 2013 | Pentair Intellitouch Power Center Includes...
The freezer side is not keeping food frozen. Every three minutes I hear something turn on and it runs for about xx seconds. The model number is ASD2626HES. The refrigerator side seems fine.
Check the temperature setting
Assure that there is enough room for air flow in the freezer or freezer
Check for air flow restrictions in vents
Test the temperature control
Clean the condensor coils
Check the door seals
Test the door switch
Test defrost heater
Test defrost timer
Test evaporator fan
Check for a clogged drain tube
Check for refrigerant leak
Freezer is too cold
Freezer is noisy
Hissing and popping is normal, it is the defrost heater.
Check that the freezer is level
Check the drain pan
Check the condensor fan
Check the evaporator fan
Inspect the compressor mounts
Freezer runs continuously
Defrost the freezer
Freezer starts and stops frequently
Check the outlet voltage
Test the condensor fan
Test the compressor relay
Test the overload protector
Test the compressor motor
Freezer does not defrost automatically
Test the defrost timer
Test the defrost heater
Test the defrost thermostat
Freezer has an unpleasant odor
Remove spoiled food
Clean freezer interior with a solution of h
Clean freezer interior with a solution of hot water and baking soda
Clean the door seals
Remove breaker strips and check for wet insulation
Water on floor outside of freezer
Check the drain pan
If you have an ice-maker, check the water supply hose going into and coming out of the water inlet valve
Water inside the freezer
If you have an ice-maker, check freezer and ice-maker for level
Hope this solved the problem, Take care....
Sep 19, 2010 | Amana ASD2626HE Stainless Steel Side by...
GE side by side keeps frosting up and fridge is not very cold
It sounds like you have a defrost system problem. most commonly its your defrost heater on most GE ref. It can be located by removing the back panel of the freezer. If you remove the heater it can be tested for continuity at any parts distributor. I would also look for the quarter sized thermostat mounted at the top of the coils to see if it looks "popped" at the top. If it is then replace the thermostat. Hope this helps MJ
Jul 28, 2010 | GE GSS20IEP Side by Side Refrigerator
Message ER DH continues to pop up on the door. If
ER =ambient temp sensor failure
DH= defrost heater
Defrost heater, temperature fuse short
circuit, unplugged connector(indicated
4 hour later after trouble)
You is gonna have defrost problemas!
Feb 24, 2010 | LG LRSC-26922 Side by Side Refrigerator
Ge refrigerator is not cooling
you have a defrost system problem. first thing you will want to check is the defrost heater. remove two screws holding it in at bottom of evap coils. You will need and ohmmeter to check resistance through the heater. (be sure to unplug unit first) Also look at your defrost termination (located at the top of evaporator) and see if it looks popped out. 19/20 times one of these two things will be the problem.
Jan 10, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
My refrigerator keep popping the electric outlet
What do you mean by "popping"? If you are plugging it into a GFI receptacle it will do that. Use a different receptacle. If it is popping the circuit breaker, you may have an electrical problem in your house.
Dec 30, 2009 | Roper RS22AQXKQ Side by Side Refrigerator
Breaker swith for freezer keeps popping off.
it can be the defrosting element or a fan if frost free or a motor down to earth disconnent one by one
Jun 17, 2009 | Sub-Zero 685/S Stainless Steel Side by...
GE side by side GSS20IEP Refrigerator freezer freezing
this is a problem that is no stranger to most GE side by sides; GE has used a glass type defrost heater in the freezer which often fails. If you manually defrost your appliance (unplug and leave doors open for 24 hrs) then plug back in, it will appear to work normally for a few days and gradually build up frost on the evap panel (back panel in the freezer) and eventually the refrigerator side will seem to loose cooling due to frosted damper, or lack of cold air transfer over the evap coil. The fix for this is to replace the defrost heaters (s). While not as common, defrost thermostats can open causing the unit to skip defrost, and even less likely is the defrost control (either mechanical timer or adaptive defrost). First, defrost your appliance, then remove the evap panel and ohm out the heater(s), if open, replace. If they check ok, check your defrost thermostat (small disc like object attached by a clip on the evap. coil itself) for signs of popping open or open ohm readings at normally closed temperatures. Its a good idea to change this anyway when replacing defrost heaters as the two work hand in hand. Last, check the defrost timer by manually advancing the screw advance clockwise until you hear the first click, then check voltage to the defrost heater and thermostat, if no voltage present replace timer. If your appliance is equipped with a adaptive defrost board, refer to the schematic for proper diagnostics.
Jun 11, 2009 | GE GSS20IEP Side by Side Refrigerator
Whirlpool GS6SHAXMQ Side by Side Refrigerator Logo
76 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
