Question about Valiant Remote Alarm System With Keyless Entry And Six Built-in Relays
Relays my car won't start because of ldp, abs, ptu, sol,eng, rlys, eng mod
  • 88 Answers
Need more info.cheers
Posted on Oct 18, 2008
a 6ya Mechanic can help you resolve that issue over the phone in a minute or two.
click here to Talk to a Mechanic (only for users in the US for now) and get all the help you need.
How can I be sure if my PCM is bad???
I would try disconnecting battery again. Disconnect both cables and touch them together for a few seconds. This will reset all modules. Wierd that you had so many codes after just disconnecting battery. Sometimes very hard to tell if ecm is bad.
Dec 01, 2014 | 2006 Pontiac Torrent
I have to error code with my jeep grand Cherokee Laredo 1999 the code are 1491,1495,753,136
P1491 Rad Fan Control Relay Circuit An open or shorted condition detected in the radiator fan control relay control circuit. This includes PWM solid state relays.P1495 Leak Detection Pump Solenoid Circuit An open or shorted condition detected in the Leak Detection Pump (LDP) solenoid circuit.P0753 (M) Trans 3-4 Shift Sol/Trans Relay Circuits An open or shorted condition detected in the overdrive solenoid control circuit or Trans Relay Circuit in JTEC RE transmissions. Was MIL code 45. P0753 (M) Trans 3-4 Shift Sol/Trans Relay Circuits An open or shorted condition detected in the transmission 2-4 shift solenoid circuit (4-speed auto. trans. only).P0136 (M) 1/2 O2 Sensor Heater Circuit Malfunction Oxygen sensor heater element malfunction.
Aside from getting into an accident and having your wiring harness severely damaged, the other likely suspect is your PCM. These codes are not related to each other and indicate a much larger problem.
Nov 02, 2013 | 1999 Jeep Grand Cherokee
I have a 1998 v 6 dodge dakota sport with a p1495 trouble code how do i fix it
DTC P1495 - Leak Detection Pump Solenoid Circuit
WHEN MONITORED: Immediately after a cold start, with battery/ambient temperature between 4.4 °C (40 °F) . F and 32 °C (90 °F) . Coolant temperature within -12 °C (10 °F) of battery/ambient
SET CONDITION: The state of the solenoid circuit does not match the PCM's desired state.
POSSIBLE CAUSES:
* Wiring Harness Intermittent
* Leak Detection Pump
* Fused Ignition Switch Output
* LDP Solenoid Control Circuit Shorted To Ground
* LDP Solenoid Control Circuit Open
* PCM
Leak Detection Pump System
The evaporative emission system is designed to prevent the escape of fuel vapors from the fuel system. Leaks in the system, even small ones, can allow fuel vapors to escape into the atmosphere. Government regulations require on-board testing to make sure that the evaporative (EVAP) system is functioning properly. The leak detection system tests for EVAP system leaks and blockage. It also performs self-diagnostics. During self-diagnostics, the Powertrain Control Module (PCM) first checks the Leak Detection Pump (LDP) for electrical and mechanical faults. If the first checks pass, the PCM then uses the LDP to seal the vent valve and pump air into the system to pressurize it. If a leak is present, the PCM will continue pumping the LDP to replace the air that leaks out. The PCM determines the size of the leak based on how fast/long it must pump the LDP as it tries to maintain pressure in the system.
SYMPTOM: P1490-LOW SPEED FAN CONTROL RELAY CIRCUIT
WHEN MONITORED: With the ignition ON. Battery voltage greater than 10 volts .
SET CONDITION: An open or shorted circuit is detected in the radiator fan relay control circuit.
POSSIBLE CAUSES:
* Low Speed Radiator Fan Relay Intermittent Operation
* Intermittent Condition
* Fused Ignition Switch Output Circuit
* Low Speed Radiator Fan Relay Resistance
* Low Speed Radiator Fan Relay Control Circuit Open
* Low Speed Radiator Fan Relay Control Circuit Short To Ground
* PCM
Notes
The Transmission/Transaxle Controller monitors the malfunction of sensors and actuators relating to Transmission/Transaxle Control. If any malfunction is detected, they inform the PCM by sending a signal - By illuminating the MIL and by setting the P0700 code.
P0700 means that a code has been set in the Transmission/Transaxle Controller. If P0700 is present, check for Transmission/Transaxle codes.
Hope helps (remember comment and rated this).
Aug 02, 2010 | Dodge Dakota Cars & Trucks
Chk eng, abs and tract /control light remain on
A blown fuse in the Maxi Fuse Relay section labeled ABS Motor or one next to it ABS Cntrl. I thnk that names. But ABS for sure. Thats what mine was. one or other. Big fuse 40 amp. Check all vacuum hoses and wire conections for check eng. Or go autozone they tell u for free
Feb 02, 2010 | 1997 Oldsmobile Regency
Honda Del Sol wont start-I need to test the Main Relay
Are you aware that there is also a problem with the ignition starter switches in this model?
Apr 17, 2017 | 1994 Honda Civic Del Sol
1996 honda del sol abs light stays on
1 or more speed sens gone need scanner chek code
Dec 10, 2009 | 1996 Honda Civic del Sol
If the ABS light is on, you have either a failing ABS (wheelspeed) sensor, or a bad ABS control module. You'll need a diagnostic scan to find out which it is. As for the owner's manual, there are a number of online owner's forums that will probably have the manual or at least the same information posted, or you can search eBay for one - they're common finds there.
Dec 10, 2009 | 1997 Honda Civic del Sol
Eng mod fuse keeps blowing
Not sure what you mean by eng mod fuse. What's the year, make and model? What's the description of that fuse in the owner's manual?
Oct 02, 2017 | 2005 Dodge Neon
I have a 95 mec sable wgn 3.8 and it wont start turn key and nothing happens no sound and the lights dont dim like if bat is weak also radio and dash clock shut off but when back on stilcorrect settings im...
try to check if the starter relay clicking while you start.If no maybe bad connection from ignition key. If the relay clicking maybe the connection to starter or the starter itself is damaged. try to direct the sol. of starter to batt. positive if it kick your starter is good.
Jun 08, 2009 | 1995 Mercury Sable
My 1990 Olds Cutlass Calais is missing the fuse box cover and therefore has no diagram for fuse placement. Is one available online? Copy I can print or just refer to in order to replace correct fuses?
I have always had a place in my heart for the Olds Cutlass. I own a '90 Olds Cutlass Calais--WITH the fuse box COVER. I went out to the car and removed the cover and have it next to me so that I can type the EXACT fuse order as they appear on the inside cover.There are 2 col. When I've finished the l/h side, I'll make a line to indicate the start of the r/h side. I will also put the Circuit on the left & fuse on the right. If you are ready, HERE WE GO:
-----CIRCUIT----------------------------------FUSE------
Air Cond/Heater HTR A/C
Audio Alarm CTSY LPS/GAGES
Driver Info System CLK-CIG/GAGES
Cigar. Lighter CLK-CIG
Clock (Radio) CLK-CIG
Cruise Control RADIO (LD2/LG7)
ECM RLYS (L68)
Eng Controls ECM RLYS
Eng Cooling Fan HTR A/C
Fuel Injection F/P INJ
Fuel Pump F/P INJ
Horn CLK-CIG
Ignition IGN
Instrumentation GAGES
Light-Lic Plate TAIL LPS
Light-Underhood TAIL LPS
Light-Glove Box CLK-CIG
Lights-Backup TURN B/U
______END OF 1ST HALF FUSE DIAGRAM______
-----CIRCUIT-----------------------------------FUSE-----
Lights-Brake STOP HAZ
Lights-Courtesy/Intr CTSY LPS
Lights-Hazard Warning STOP HAZ
Lights-Instrumentation INST LPS
Lights-Park/Side Mkr TAIL LPS
Lights-Tail TAIL LPS
Lights-Turn Signal TURN B/U
Power Antenna CTSY LPS
Power Door Locks CLK-CIG
PWR (CB)
Power Seats PWR (CB)
Power Windows CLK-CIG
PWR WDO (CB)
Radio RADIO
Rear Defogger GAGES
PWR (CB)
Torque Conv Clutch ECM RLYS
Trunk Release HTR A/C
Wiper/Washer WIPER
----------------END OF FUSE DIAGRAM----------------
Did my Best. Let me know if you need anything else. I have shop manual for this Yr, Make & Model. Best of Road to You. How'd I do? Have a Great Day!
Jan 03, 2009 | 1990 Oldsmobile Cutlass Calais
Valiant Remote Alarm System With Keyless Entry And Six Built-in Relays Logo
77 people viewed this question
Top Bulldog Security Vehicle Parts & Accessories Experts
John
John
baire
john h
Are you a Bulldog Security Vehicle Part and Accessory Expert? Answer questions, earn points and help others
