Question about Kyocera Mita FS 3800 Laser Printer
Kyocera Printer C5030N
I have removed old waste toner box with a new one. It still says check waste toner bx. What can I do to solve this problem. I cannot use my printer.
Fred M. Danage, Jr. freddanage@att.net
Remove the developer and toner cartridge from the front of your unit. This will allow you to take out your drum where your waste toner box is. Once you have your drum with your waste toner box make sure to detach the waste toner box from the drum. Take a damp linen free cloth and wipe down the inside of the drum unit where your waste toner box goes in. Now take your waste toner box and make sure to secure the waste toner box really well to the drum. This has to be in very tight or else the printer will not think that there is a toner box attached the drum and this error will continue to appear. Important thing is to make sure that the toner box is attached really well to the drum unit.
Posted on Nov 05, 2008
How to empy waste toner box
if you buy a new toner it should have some waste toner box with it, all you need to do is just open the front cover of your machine,remove the used waste toner close the lid, make sure you don't breath the dusk. then just put then new waste toner box in.
Jan 28, 2013 | Kyocera Taskalfa 250ci Color Copier...
Tip
Toner Box full when its not - fault
Putting a small lump of bluetac on the inside of the door will push the waste toner collection box into the correct position and stop the empty the toner box fault.
As the toner box is not seating in the sensor correctly.
on Feb 13, 2014 | Kyocera FS-C5030N Led Printer
Fsc5030n waste toner box
seems vey used maybe you have to bring it to a check
Apr 26, 2012 | Kyocera FS-C5030N Led Printer
Kyocera km-2550 check toner container error
Set toner container. The toner container is not set properly. Set the toner container properly. See page 5-5 of the operation guide.
Replace Waste Toner Box The waste toner box is full. Replace the waste toner box with a new one. See page 5-5 of the operation guide.
Jun 13, 2011 | Kyocera Mita KM-2550 All-In-One Laser...
Self test says 'check waste toner box'
It looks your waste toner box is full. Waste toner box collects toner drawn during printing. You have to remove waste toner bottle and empty it.
Follow the instructions to clean up toner bottle
http://www.kyoceramita.co.th/news/products/img_promain/20091141129533.pdf
Hope this helps
May 21, 2010 | Kyocera FS-C5030N Led Printer
Check Waste Toner Box message
Clean the neck of the bottle and the black sensor the neck sits in.
Feb 04, 2009 | Kyocera Mita FS 1900 Laser Printer
Kyocera FS-C5030N
Replace the developer unit and that will fix it.
Aug 22, 2008 | Kyocera FS-C5030N Led Printer
Kyocera Printer error - Help!
The code is for a defective cyan motor. So its either the cyan toner motor or a lump of toner inside the cyan toner container.
Feb 29, 2008 | Kyocera FS-C5030N Led Printer
Kyocera 3820DN
If the neck of the waste toner box has toner on it it will think it is full wipe inside of neck stem with tissue.
Turn off and on, does waste message disappear? If it does and you still have jam problem post back and I will help you solve it too
Dec 02, 2007 | Kyocera Mita FS 3800 Laser Printer
Kyocera Mita FS 3800 Laser Printer Logo
1,772 people viewed this question
Top Kyocera Mita Office Equipment & Supplies Experts
Kyocera HP Expert
Adorjani Laszlo
AAAA262430
Are you a Kyocera Mita Office Equipment and Supply Expert? Answer questions, earn points and help others
