Question about Bosch Nexxt Premium WFMC6400UC Front Load Washer
Please help My bosh wont drain is gives me a message saying e4 what does this mean and how can I fix it
  • 2 more comments
  • crystallo721 Oct 18, 2008
    no where can I find the filter and how will I check it
  • heritag Oct 30, 2008
    do you  mean the round disk at the bottom right of the outside or the hoses at the back of the machine?  help!
    Is it the round flat disk thing on the bottom right of the front of the machine, or do you mean the hoses at the back of the machine on the top?  E4 appears on my machine and it will not rinse or drain. thanks!
  • douglas smith May 11, 2010
    have you checked filter??
Thank you, thank you, thank you just saved me $$$'s in a service call. Rebeab, The while cover you take off by rotating about 10 degrees counterclockwise then pry off . The black round cover you rotate counterclockwise till it seems to spin in place then pull it out. You might need pliers to get a grip. Under that is a white divert-er thingie (technical term). Pull that out with pliers and then clean out the obstructions (keep all the money you find). If you have a shop vac have it handy for you WILL have a flood.
Posted on Mar 31, 2010
I have the same problem but i cant "unscrew" the round cap- any ideas?
Posted on Feb 23, 2010
Filter is the round cap in the front at the bottom. unscrew it (carefull, water may come out). unscrew filter and pull it out and clean
Posted on Oct 20, 2008
Logik dishwasher E4 error message
I am having difficulty with my logik slimline dishwasher. E4 message about 30 minutes into cycle. Where the salt goes is always full of water. Please can someone help me
Nov 17, 2012 | Dishwashers
CODE E4 ELECTROLUX EWT64S FULLY AUTOMATIC WASHING MACHINE
In my experience, E4 is appear when spin is starting. Then I check the 'magnetic door safety switch' and gotcha, I find the problem --> 'magnetic door safety switch' is damage (always open). Because some reason, I am short-circuit it. Fixed.
Oct 11, 2012 | Washing Machines
NOMA air conditioner/dehumidifier/fan model 043-5441-8 gives E4 error message and shuts down. This is a new unit and the owner's manual and Hisense USA company are useless! Help, please!
the unit is full of water, carefully lift unit into bathtub and drain all the water, both top and bottom corks removed. Usually caused by airlock in drain hose
Jun 29, 2011 | Heating & Cooling
My dishwasher says E4
The error code E4 means selector switch pads is stuck.
First try a hard reset. Unplug the unit for 10 minutes and then switch on the dishwasher. Most cases you won't get the error message.
If you still get the error message then you need to take to service center to get it repaired. Mostly, the inner connectivity between the pad and circuit board is loose/bad.
Hope this helps.
Shane
Feb 27, 2011 | Kenwood KDW243A Builtin Dishwasher
Error code E4 is on our display of our KDW243A dishwasher - what does this mean please?
Error code E4 means there is an overflow. Water is probably trapped. If you get error code E4, just tilt the machine back about 45 degrees and let the water drain out. It should come out on both sides. Then, you should be good to go.
Dec 14, 2010 | Kenwood Dishwashers
The washeer machine give a error code E4
A code of E4 means that there is to much suds or the pump is blocked. use less detergent and get detergent with he in the title. turn to off and try to restart the drain to correct problem.
You will find the code in the manual. If you do not have let me know I will send you one here.
Good Luck And Please Rate FixYa!
Dec 19, 2008 | Washing Machines
BOSH SHU43 dishwasher
From my experience.. usually when a motor is humming it could be something is stuck in your impeller.. if your can get to your drain pump to check it out.. and getting to your drain pump can be a pain.. good luck.. hopefully that works
Jul 17, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Kenwood dishwasher kdw8st2a
I had E4. Initially couldn't get it to clear.
In desperation, switched it off, turned it on it side and drained it onto the floor.
The E4 disappeared and the dishwasher is working normally.
Jan 22, 2008 | Smeg 24 in. DWF614SS Stainless Steel...
E4 error message
take off two black covers on bottom front of machine and mop up or soak up any water you feel or see at very bottom of machine by a polystyrene float this will fix it
Dec 27, 2007 | Baumatic 23 in. BDW13 Built-in Dishwasher
Bosch Nexxt Premium WFMC6400UC Front Load Washer Logo
158 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
