Question about Xerox XA7-172i 17" LCD Monitor
XEROX LCD flat screen monitor
Everything on my monitor is turned side ways! It happened when I went to pick up the keyboard while it was standing on the floor leaning against a table.I touched something on the key board that made the picture on my monitor turn upside down.After trying various things I got it turned sideways and that's it don't know what else to do.
Please can you help me? Rach
raha@suddenlink.net
  • Xerox Master
  • 19,396 Answers
Hold down the combination of keys "CTRL"+"Alt"+ "arrow keys" to change picture orientation on Windows, this will sort out the problem.
Posted on Nov 27, 2008
This worked great. Thank you!
Posted on Feb 16, 2009
How can I check my dell d820 screen? It stopped working
Hi, first:
try to connect to a VGA Monitor (it has DB15 Connectors(bing or google it) and usually in blue or black colors) and press and hold windows key then press P on your laptop keyboard or (peripheral PC keyboards) tap these shortcut for 2 or 3 times and see what happened, if you see any changes on monitor or see your screen on the VGA monitor your Graphic card is fine so go to the next step if not
maybe you have chipset problem or bios (UEFI) problem so go to the certified Repair shop,
next step:
some laptops have a shortcut key to turn your LCD off in expanding screen mode for decrease power consumption. try press (fn + keyboard key that sometimes has a rectangular icon with x icon on top of it) if you try but nothing changes or see white screen or glitch
screen pixels then 2 possible things happened,1- your LCD flat cable or 2- may be your Screen LCD damaged in this case go to certified repair shop center
best regards
Jun 16, 2014 | Dell Latitude D820 Notebook
LCD screen totally white when turn on
The HP is a flat screen monitor used with many desktop computers. When the LCD on your HP monitor goes white, it is an indication that your monitor's inverter board has gone bad. The inverter board is a small circuit board that transfers power from the monitor's main circuit board to the LCD screen. Replacing the inverter board means dismantling the HP monitor.
1. Power down your computer and unplug the HP monitor cable from the back of your desktop. Disconnect the power cable from the back of the monitor. Relocate the monitor to a flat work surface. Place the monitor with the screen facing downward.
2. Remove the Phillips-head screws from the monitor's base stand and from the back cover. Lift the base stand off of the monitor and remove the back cover. Peel away the foil from inside the monitor around the internal circuit board.
3. Locate the inverter board near the bottom of the monitor's casing. Unplug the power cables from either side of the inverter. Loosen the Phillips-head screws from the inverter board. Lift the old inverter out of the monitor's casing and set it aside.
4. Place the new inverter inside the monitor. Replace the Phillips-head screws and fasten it in place. Reconnect the power cables to the connectors on each side of the new inverter. Replace the foil around the outside of the main circuit board.
5. Replace the back panel and base stand, and their retaining Phillips-head screws
I hope you find it very helpful.
Thank you for choosing fixya.com
Aug 11, 2011 | HP Computers & Internet
In moving to a new apartment I flattened the neck of the circular stand with the monitor LG flatiron slim 19" into the box. Went very easily. Now when I put up my computer the stand of the monitor...
On my HP monitor on the stand, I have a locking mechanism that doesn't allow the display to be raised. I need to press a button on the stand while pushing down the display, then the button is possible to be pressed down. then while holding it down, I can pull the display upwards as much as it comes.
the stand locks in my case when pushed all the way in.
Maybe this is the same thing on yours? Maybe not?
Oct 03, 2010 | LG Flatron L1951S-SN 19" LCD Flat Panel...
I have dell 98 windows xp that connected to the dell LCD display the other day i just turn on my computer everything was ok till windows xp came out on screen and suddenly screen went black i could...
you have a problem on your operating system...try to run sytem restore or repair your program...
if the two cannot fix it format is the only way...
Feb 12, 2010 | Dell E173FP 17" LCD Monitor
Okay im having a probblem with my lcd monitor and when i press the button on the tower to turn everything on and then press the on button on the lcd monitor it says minitor is going to sleeep and ive tried...
Sounds like the monitor is not getting a signal from the tower.
Do you have another monitor/LCD screen that you plug into your tower? That will tell you if the LCD is the issue or the tower.
If it is the tower that is at fault, then you need to try and figure out if your video is separate from your motherboard. Hopefully it is separate, that way you can get that replaced. If not, then it means that your video card is integrated onto your motherboard which is much expensive to get fixed.
Hope this helps.
Dec 08, 2009 | HP W2007 LCD Monitor
Dell Monitor 15"flat panel-2 Horiz. black lines
HAS IT HAPPEN ANYMORE OR IS STILL THERE.
CHECK YOUR DRIVERS, UPDATE THE DRIVERS, CHECK THE CONTROL PANAL IN THE FOLLOWING FOLDER DEVICE MANAGER, PROBLEMS REPORT, SYNC CENTER
OTHER THAN THAT TECHN SUPPORT OF YOUR VENDER WHERE YOU BOUGHT YOUR MONITOR FROM OR GO ON LINE AND TYPE THE FOLLOWING INFORMATION EXAMPLE:
DELL E151FP FLAT PANEL LCD MONITOR 2 BRUSH STROKES ON SCREEN
ENTER
SEE IF ANYONE ELSE MAY OF HAD THE PROBLEM OR TO COME FIND OUT THAT THAT WAS A RECALL ITEM FOR THAT MONITOR, JUST KIDDING, ITS WAY OUT THERE
ROD
Feb 09, 2009 | Dell E151FP 15" Flat Panel LCD Monitor
Need to know how to Disassemble AL1912 19" LCD Monitor
The ones I take apart have a snap on front bezel.
gently pry at the lcd edge with fingers in center left or right to get it to bow , dont damage the lcd with too much pressure.
it will start to separate ,put a plastic knife or such in the outside crack and work your way around once you have one side the rest will be easier. you have to bow the inside edge out(away from the lcd) because of the plastic clips.
luck.
Apr 17, 2008 | Acer AL1912 19" LCD Monitor
Xerox 19i screen going blank
Does look like a back light or inverter problem Have you got a TV repair shop that can take a look Although your warranty may have gone you can still seek technical support on the web site,
May 27, 2007 | Xerox XA7-192i 19" LCD Monitor
Green power light blinks every 3 seconds with the word Xerox on the screen, with just a black screen. Could this be a bad Switching Power supply cord?
open it up... whats the worst that could happen... see if the caps are fine... if they are bloated exchange them... if you need help doing so hit me up at abelino24(at)sbcglobal(.)net... I've repaired like three of these in the past few months.. its always the capacitors. they either get really hot and bloat or don't function if it gets too cold... so the solution if to get the right caps at 470uf / 25v and 220uf / 25v... hopes this helps...
Nov 18, 2006 | Xerox XG-71D 17" Flat Panel LCD Monitor
Xerox XA7-172i 17" LCD Monitor Logo
376 people viewed this question
Top Xerox Computers & Internet Experts
Jack McCann
Jack McCann
matt
matt
k24674
Are you a Xerox Computer and Internet Expert? Answer questions, earn points and help others
