Question about Kenmore 88752 Top Load Stacked Washer / Dryer
Kenmore elite drum baffle dryer
How do they screw off. There is a coin in one of them.
  • 71 Answers
Remove the top panel and each fin has 2 5/16 screws holding them to the drum. turn the drum so the fin is on top and remove the screws then remove the coins
Posted on Dec 20, 2008
Kenmore elite steam dryer replacing a baffle
Remove the top and you will be able to see the side of the drum- rotate it until you expose the screws to the loose baffle.(tighten them all while you are in there) Drum Baffle WPW10112972
Jul 09, 2016 | Kenmore Dryers
Fix rattly noise in gas dryer
could be coins in the baffles, sometimes coins make it into your dryer, and they slide under the baffles, remove or open the top of your unit and you will see the screws that hold on each baffle, remove the screws and the baffle will come off inside the dryer with whatever is in there. then re-secure the baffles..
Oct 24, 2015 | Kenmore Dryers
We have a dryer fin with something rattling around in it. Do the fins come off?
Need a model number for the dryer for a more definitive answer--usually you would have to open the top cover to expose the drum. Depending on the model dryer, some baffles(proper name) are screwed onto the drum, some have plastic tabs which must be carefully pushed in order to remove the baffle. Most likely, the rattling is caused by coins left in pockets--they won't damage the dryer but can be irritating to listen to. Front load washers are notorious for trapping coins in the baffles of the rotating baskets--and that is A VERY EXPENSIVE REPAIR if you want to have the coins or objects removed.
Aug 14, 2015 | Dryers
Mod 110.67741600 ser mu2020976 dryer drum is makeing a lot of noise
Check the baffles in the dryer drum to see if any are loose. If they are not loose, spin the dryer by hand to see if noise is from inside the drum. Sometimes you will get coins caught in the baffles and all you have to do is loosen the screws, and rotate the drum a little so the coins will fall out. Then tighten the screws up and replace the cabinet. You may also have a bad drum roller inside the machine.
If you could describe the sound to me, I will be able to help you a little more.
Jan 06, 2011 | Kenmore 700 6973 Dryer
I know that I am asking this for the third time; however, on the other two I forgot to notate the make and model. Again, after I opened the top of the dryer, there were no coins, it seems to be the screws...
If the screws holding the baffles just came out of the baffles or if the baffle broke they can be reinstalled. If the screws have ripped though the drum, the drum will need to be replaced. The screw part number is 33002973. The short baffle part number is 33001755. The tall baffle part number is 33002032. If you need the complete drum it is part number 33001889. Below are the instructions on how to replace the drum. Parts can be ordered from this link.
below is a link to the service manual for the info u need to take aprt or replace the dryer drum on a Maytag Neptune, I suggest u print it and then enlarge it if u can read it.
http://media.fotki.com/1_p,swdbrqkqdgssrtkxgtqsskgwtqkq,vi/stkwfgbrgxkgtddqfqs/1/1303472/5961857/image7951020310251998097img-or.gif
Apr 06, 2010 | Maytag Neptune MDG5500AW Gas Dryer
GE dry is making a noise like loose change is rolling around
There may be change rolling around in it.
Remove the top. Take the screws out of the drum baffles and remove the coins from inside the dryer drum baffles.
When replacing them, tighten them well to help prevent coins from getting in there.
Mar 23, 2009 | GE Dryers
Replacing the drum baffle in kenmore elite he3t front loading washers
The baffle basket, I ordered from sears for my Kenmore Elite he3t washer was a "new" design but the screw holes lined up. My baffle basket did not come with the screw either. I took out the screw from an existing baffle basket and found something close. Test it in the baffle basket before you try to install it. Be careful not to drop the screw or bit.
To replace the baffle basket. Remove top of washer using a screwdriver with a T20 torque bit. There are three screws at the rear. The top slides back about an inch and lift up. Place aside. Then you will see a hose going into the drum. Ignore the clamp, just squeeze the end going into the drum and work it out. Now you need to insert the baffle basket in the drum through the front door. It is easiest to rotate the drum so you are inserting it on the bottom. It slides in with the small end toward you and you must pull it forward. Hold the drum for leverage. Now rotate the drum so the new baffle is on top. You need to line up the screw hole and screw in a small screw. Replace the hose and top of washer.
Good Luck...
Aug 09, 2008 | Washing Machines
Coin stuck in the tub baffle
on top of the machine where the filter is there are 2 screws`remove.gently pry up on the top front of machine.it should pop up. rotate tub till your coin gets to the top .you should see the screws you need to remove .
Feb 24, 2008 | Kenmore Elite HE4 Electric Dryer
SOMETHING stuck inside the dryer body - something like a coin... let me knwo
ok here is the best way to describe it you will need to get around the back there are two torks screws remove them and slide the top panel back to you ..OH I FORGOT unplug the machine first !!!....Ok now with the top off you will see the drum.. slowly hand rotate it until you see some screws that are lined up with the baffles inside the drum You will need to remove just a few screws on one side (the baffle that has the coins) dont take them all out or the baffle will fall inside the drum and it will be a pain to get back on9u will need 2 people) and that should do it you will need to rotate the drum around until the correct baffle ...ie ..the one with the coins in on top at the 12 o'clock position.. let me know if this works our for you
Feb 16, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore 88752 Top Load Stacked Washer / Dryer Logo
288 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
