Audio driver problem for asus P5PE-VM motherboard
The motherboard mentioned above is not compatible for vista ultimate but everything seemed to work fine except for the audio driver. please help.... i don't install my sound card driver
my chipset is asus p5pe-vm
  • 781 Answers
Try the Microsoft UAA drivers install them first then go to device drivers and right click sound driver and update driver will go on net to find driver (it should find it) and then install it
The M/soft UAA driver unless installed first cause a lot of trouble with normal sound drivers
Posted on Oct 18, 2008
My problem is my VGA card is not working on window 7 & for ASUS P5PE-VM. Can you give me a link for this VGA download or solutions
Ron, I found this posted somewhere:
Users running ASUS P5PE-VM on Windows 7 having difficulty looking for compatible drivers, especially on graphic card and onboard sound card. The graphic card is old NVIDIA GForce 3 TI (AGP) and the sound on-board is SoundMax which is listed as SoundMax Integrated Digital Audio (TCSUS_CH5) F5410AMR. The driver which comes with the motherboard will not install the sound drivers because it doesn't recognize the OS even though it listed the sound card but only Realtek and analog devices.Trying to resolve this problem using Compatibility mode doesn't do the trick as there is no Vista compatible for GF3 driver. Windows 7 apparently won't recognize GF2 series and older ones. You will have to upgrade the video card. Try using Windows Update. If it doesn't find the driver online, then it means the driver is not supported by Win7. No luck for NForce 3 motherboards either, or NF 1/2 motherboards. Another workaround you can try is by installing NVIDIA's legacy driver 66.93 which was reported doing good on GeForce 3 TI 200. You will have to disable all directX hardware acceleration, but OpenGL works. It looks like upgrading is the last resort you can try after you try all above solution.
I hope this helps & good luck!
Apr 01, 2011 | ASUS P5PE-VM Motherboard
Where can i find audio drivers for vista 64-bit
"Cut and Paste to your search engine": OfficialPCDrivers.org/ASUS
Feb 01, 2010 | ASUS P5PE-VM Motherboard
Asus p5pe-vm audio driver 4 windows 7
the audio for asus p5pe is soundmax ad1888 as of now there no driver that supports win7 you'll just have to wait until the product manufacturer releases a driver that will support win7
Nov 20, 2009 | ASUS P5PE-VM Motherboard
I Have Asus P5PE-VM motherboard and windows vista ultimate 32 bit installed on my pc. My SoundMAX Audio Driver didn't support this OS version plz help me
In this case if your sound max did not support your OS you need to Install the lower version of OS which is compatible to your soundmax driver, because higher version did not support the other driver,
Jun 30, 2009 | ASUS P5PE-VM Motherboard
I have installed vista ultimate but the drivers specially the sound card driver isn't working.. My motherboard is Asus P5PE-VM series.. Help me out
download driver utility from this link and install it, hope your problem will be solved.
http://www.lostmydrivers.com/driver/download/19336/ASUS/Mainboard-Drivers-and-Utilities-Drivers/ASUS-PC-PROBE-II-V1.04.68-WINDOWS-2000-XP-2003-VISTA-ALL-X32-X64-V1.04.68-WINDOWS-2000-XP-2003-VISTA-ALL-X32-X64-.
Jun 23, 2009 | ASUS P5PE-VM Motherboard
P5PE-VM asus board audio driver
Hello there.
Please click here to download the drivers for your audio chipset. You may note that Vista is not listed but the driver version for Windows XP works in Vista, there was a problem with the installer cd on Vista but apparently manually running the installer for the audio card, from the cd works fine. Click here to see what other users of the same motherboard said.
Hope this helps.
Apr 19, 2008 | ASUS P5PE-VM Motherboard
5.1 Sound AVailable for Vista???
aw.. audio drivers? or audio cards? i you want audio drivers try search engines..
Feb 26, 2008 | ASUS P5PE-VM Motherboard
can u dl lates one from website do custum update windows look for more updates enbaled it in bios ac97
Jan 21, 2008 | Microsoft Windows Vista Ultimate Edition
Computers & Internet Logo
253 people viewed this question
David Payne
David Payne
