Question about Husqvarna 23 Hp 48" Deck Yard Tractor
Husqvarna LT2042 Working on a Husq.LT2042. won't start. Replaced battery. Solenoid clicks, engages starter but won't start. How do I know if starter and or solenoid needs replacing.
  • alandidak Nov 03, 2008
    I ahve exactly the same problem,i replaced the battery and spark plug but the engine will not turnover
  • Anonymous Mar 27, 2014
    let me tell u i will never buy another husqvarna anything again . after 3 mons. starter that engages starter to turn starter had dirt in it so it didnt engage since it work perfect it is now oer 2 yrs. old .now it is leaking oil bad. my mechanic tells me the oil pan is cracked.has to be a flaw .im 65yrs. old unheard of
  • 16 Answers
The soneloid switch sends power to starter . check power on red wire on starter when key on full .if no power must be soneloid switch problem even though it clicks
Posted on Nov 11, 2008
Why does starter hesitate to engage until I try 3 or 4 times?
your starter or solenoid is on its way out probably, if you know the battery is good, then this is a tell tale sign of a worn starter or solenoid on starter. press the helpful button and check link below
Why car won start troubleshooting tips
Jan 30, 2016 | 2006 Dodge Grand Caravan
Starter solenoid was just clicking but not starting, replaced solenoid but have the same problem, could it be the battery?
Certainly. Battery voltage causes the starter solenoid to move out to engage the starter. If you do not have enough voltage and battery amperage, the starter will not engage. Charge or replace the battery and check your battery connections. They need to be very clean as well.
Oct 10, 2014 | 2005 Honda VT 750 DC Shadow Spirit
Why won't husqvarna z4217 starter engage after replacing the battery and solenoid
The starter itself may be bad. Are you getting 12 volts to the starter? Does the solenoid "click" when turning the key.
Jul 03, 2014 | Husqvarna Lawn Tractor - 54in. Deck, 26...
Motorcycle solenoid just clicks
Hi, Trevorelgram you turn on the ignition switch press the starter button and all you get is the dreaded "CLICK" now before testing any electrical component in the Starter System it is "IMPERATIVE" that you have a fully charged battery of 12.5 volts or more and be able to pass a proper "LOAD" test if necessary, you may have a preliminary reading of 12.5 volts or more but little or zero amperage, the battery is faulty and must be replaced. AGM type batteries fall into this scenario more so than lead-acid batteries and the usual suspects are:
1. Battery terminals have loose or corroded connections.
2. Battery cables faulty due corroded or broken internal wiring at the cable connector especially the "NEGATIVE" cable which needs to be checked at "BOTH" ends.
3. Battery voltage, must be 12.5 volts or better, voltage from the battery to the main circuit breaker to the ignition switch to the security/ignition fuse to the TSM/TSSM module to the engine stop/run switch to the starter button to the starter relay to the green wire that connects to the starter solenoid must not drop more than 1/2 volt of battery voltage.
4. Disconnect spark plug cables, with a voltmeter connected to the battery, the ignition switch in the on position, the kill switch in the run position, the starter button depressed, starter engagement should not bring voltage below 9.6 volts DC. If the voltage is below 9.6 the battery is faulty and must be replaced. I "HIGHLY" recommend a maintenance free AGM battery typically they have more amperage for cranking.
5. Faulty starter relay, check continuity.
6. Faulty starter solenoid, check contact plate and shoes for excessive electrical erosion/etching, refurbish as necessary or invert contact plate and use the virgin backside. Check contact shoes for being loose. Replace solenoid if the negative function is still a final outcome.
7. Faulty starter, bench test starter with a 12-volt battery if negative function check, decontaminate and undercut armature commutator segments as necessary, check segments with an ohmmeter probe each one and the segment next to it for shorts. Have the armature tested with a growler and field coils, and brush plate with an ohm-meter for opens, shorts or grounds. Replace brushes if less than .438" It is generally cheaper to overhaul/refurbish a starter motor than buying a new one.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
Motorcycle not starting Clicking noises FIX
starter relay clicks bike won start
Starter Relay solenoid Clicking NOT the battery Suzuki GSX Motorcycle...
So Your Starter Is Just Clicking
My bike won start and makes fast clicking sound
Oct 12, 2017 | Motorcycles
Moto Guzzi breva 1100 won't start clicks at relay.
Take a look at the starter solenoid. There are two larger wires, on the back. One from the battery positive, (main hot wire), the other goes to the starter motor (If you jump these terminals the starter will spin but will not engage the flywheel). Look at the wires and nuts on the solenoid, especially the starter motor side make sure they are clean and tight, have not gotten hot and started rusting. Also check the voltage on the solenoid wire, (smallest) wire from the start button. In some cases there is a voltage loss on this wire. Next time it will not engage the starter right away, make a jump from the main power battery terminal on the starter to the solenoid wire. If it starts right up every time, you need to add and wire in another relay to carry the voltage to the solenoid from the start button, (a relay to work the solenoid, lol). If that test does not work or help.. Tap on the starter motor with a hammer. if it catches and turns the engine then, the motor brushes are worn and need to be replaced.
Sep 25, 2011 | 2005 Moto Guzzi Breva V 1100
Van won't start. Only have clicking noise. Have a new battery and had the starter checked.
I know you had the starter tested but i still thing you have one of two things going on here, first acid damage to the Positive battery cable at the battery, if this is present you will notice the outside of the cable seems swelled yo under the red insulator, this causes low voltage, enough to click the starter solenoid but not enough to turn the starter motor. The other problem is burnt contact inside the starter solenoid itself, this problem will cause a clicking noise from the solenoid with no starter engagement, it very common. The starter solenoid is near the battery just follow the Positive cable from the battery to it, carefully jumper across it, does the starter engage? Here is a picture of the starter solenoid.
Aug 30, 2011 | 1993 Ford Econoline
2004 ion won't start. Lights work. When I turn key don't get series of clicks, get one snap.
That symptom usually means the solenoid on the starter is bad and no longer is completing the circuit to engage the starter. A new starter will likely solve that issue. A series of rapid clicks would indicate a week battery. You can try repeatedly turning the key to the start position rapidly, sometimes the starter wil start working. You can also try tapping the starter while somebody holds the key in the start position, if the starter engages place it.
Jul 16, 2011 | Saturn Ion Cars & Trucks
My 1993 mercury sable has been sitting an a garage for four years the battery was bad so I when I go to start it it Wil clik one time but it won't turn over. Why won't it start?
Sounds like the starter is bad. The one click would be the solenoid on the starter engaging but the starter does not turn. If it does not click the next time you try to start, then that would indicate the solenoid is sticking. Also ensure that the cable to starter is good and the connections are tight. The starter will have 2 wires. 1 heavy wire that runs the starter itself and a lighter wire that runs the solenoid. The second wire seems good. Also ensure there is not an inline fuse in the starter cable. Some cable incorporate the inline fuse in case the wire shorts out to the chassis.
Jul 02, 2011 | 1993 Mercury Sable
Replaced starter relay and stater in yamaha 1100 2001 v star
Charge battery to full, start in neutral, still clicks? Bad ground, or bad connection. Jump starter solenoid with screwdriver,etc. if motor turns over the relay is bad. Chaz Moto DC
Jan 22, 2010 | 2001 Yamaha V Star 1100 Classic
Husqvarna 23 Hp 48" Deck Yard Tractor Logo
859 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
