Question about Kenmore 659 Electric Dryer
Kenmore cloths dryer will not heat up
Kenmore cloths dryer does not heat up
  • 1 more comment
  • lostgirl77 Nov 05, 2008
    thermostat i have the same problem
  • Anonymous Dec 31, 2008
    cloths take three cycles to dry
  • Anonymous Feb 14, 2009
    clothes wont dry
  • 734 Answers
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Note: It is recommended by most dryer manufacturers to replace a hi-limit thermostat when replacing a thermal fuse.
3. Igniter
Igniter may burn out or break. Replace the igniter if found defective.
Note: Igniters are very fragile and break easily. It is recommended to handle the igniter only touching the ceramic part of it (usually white in color).
4. Flame sensor (or radiant heat sensor)
Replace the sensor (located near the igniter) if found defective.
Posted on Dec 02, 2008
I have a Kelvinator cloths dryer about 15 years old takes to long to dry even smaller loads, gets very hot at back end of dryer it is free of lint
Posted on Apr 13, 2009
Kenmore dryer will only work on no heat cycle...any other heat cycle will give pf code. md number 417.84092500
The Kenmore H5T is an electric clothes dryer meant for residential use and manufactured by the Kenmore Company, which manufactures a wide variety of appliances for the home, including refrigerators, dishwashers, microwaves, stoves, and clothes washers and dryers. While most Kenmore clothes dryers work well with only basic care and maintenance, certain problems, such as the dryer not heating, occasionally occur. Troubleshooting this issue may solve the problem without the help of a service technician.
  • Ensure that the dryer is properly connected to a working grounded power supply. Confirm that the power cord is plugged firmly into the dryer and the power outlet. Reset household fuses or circuit breakers if necessary.
  • 2 Remove the lint screen from the bottom front of the dryer. Pull off all lint so that the filter screen is clean, and replace the lint screen in the dryer.
  • Run the dryer for 5 minutes on a normal cycle and hold your hand under the outside exhaust hood to feel for air movement. If there is no air movement, turn off the dryer and unplug the unit. Disconnect the exhaust vent and clean out any possible obstructions, such as excess lint. Reconnect and confirm that the vent is not kinked or crushed and preventing proper heated air flow.
  • Ensure the dryer is not in a room or outside with ambient temperatures below 45 degrees Fahrenheit. The dryer will be unable to heat properly if the ambient temperature is too low.
  • Avoid overloading the dryer with too many clothes, which will limit proper heat and air flow in the dryer. Make sure the dryer is not set on an "Air Only" dry cycle, which does not provide heat.
  • Contact an authorized service technician if the preceding steps do not resolve the problem.
  • Dec 20, 2010 | Kenmore Dryers
    Kenmore gas dryer will not heat when i place clothe. runs fine without clothes
    If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
    if you dryer is gas check out this gas no heat tip....
    If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
    check out this electric no heat tip...
    Aug 28, 2010 | Kenmore 74672 Gas Dryer
    Kenmore Gas Clothes Dryer does not heat sufficiently
    Ok, first and foremost, make sure your vent is clean and clear.
    If the vent is clean and free of obstructions the most likely culprit is your gas valve coils. When they fail the typical symptom is heat at the beginning of the cycle and no heat about 20 minutes later.
    If you can, post the complete model number from the dryer and I will give you step by step tear-down and replacement of parts instructions.
    Jun 27, 2010 | Kenmore 63942 Dryer
    My dryer runs but does not heat up or dry clothes. What could be the problem?
    I have a Kenmore dryer and it runs but won't heat up and dry the clothes. I don't hear the ignition even turn over. Please help. I can't afford to buy a new dryer at this time.
    Feb 16, 2010 | Kenmore 62602 Electric Dryer
    Gas Dryer drying clothes cold, no heat...
    if it heats for a while and then no heat you have bad gas coils,when the coils are on there way out they work until they heat up then they cut out,see if you have heat when the dryer is cold,if it is change out the gas coils
    Jan 25, 2010 | Kenmore 63942 Dryer
    My kenmore 70 series dryer will not heat upa nd
    bad ignitor
    or bad solonoids on your gas vale
    check your lint filter
    and exhaust outside to be clear of cloggs with good airflow while running
    Oct 05, 2009 | Kenmore 73952 Gas Dryer
    Dryer is hot, clothes arnt getting dry. blower? less that 1 year old Kenmore
    Remove the vent hose from the dryer and dry a load of clothes . If they dry , then dryer is pushed too far back , kinking vent hose , or the vent from the dryer to the outside is blocked somewhere . A dryer either heats or doesn't heat (except for maytag associated dryers ) in which the blower wheel could be stripped out . But Kenmores don't have blower problems .
    Aug 09, 2009 | Kenmore 600 7965 Dryer
    Dryer heats, tumbles clothes, blows air out exhause vent, but wont dry clothes
    what type is this electric or gas? have you removed the exsaust from the wall and ran a load like this? if you have heat and this is an electric dryer it sounds like you have a blockage in your house. if the dryer runs fine without the exsaust attached then that is your problem. let me know
    Jun 02, 2009 | Kenmore Dryers
    Dryer no longer has heat to dry clothes
    The element gets brittle and breaks. The element is in the rear of the dryer under the dustcover.
    May 06, 2009 | Kenmore Dryers
    Kenmore Elite dryer heats but does not dry
    Make sure that your vent tube is not kinked or crushed behind the dryer and it all this is ok then you need to change your cycling thermostat. is it gas or electric
    Mar 12, 2009 | Kenmore Dryers
    Kenmore 659 Electric Dryer Logo
    407 people viewed this question
    Top Kenmore Dryers Experts
    Dan Webster
    Dan Webster
    Sal De
    Tim Whalen
    Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
