Question about Sony Handycam DCR-TRV740 Digital Camcorder
Tape ejects a third of the way and stops
Everything is functioning ok on the camera, but I cannot get the tape to eject all the way out. The tape comes about a third to a half way out, stops, then retracts backinto the camera. Any suggestions?
  • 1,476 Answers
I believe that you have a problem where the tape is not being taken completely back into the cassette housing. Either the tape is bad and jammed or the idler is slipping. As it starts to eject pressure is put on the eject mechanism and it stops and reverses (as it is suppose to) to keep from damaging the camcorder. Unless you are familiar with camcorder repair you could do more harm than good forcing the unit open or trying to get the tape out. You should take it to a repair shop and let an expert take care of it. It shouldn't cost much to remove the tape and check for damage. Perhaps $50 to $100 US. Good luck.
Posted on Jul 20, 2006
CCD-TRV32 won't eject tape
Its better if you get it serviced by an authorized service center,If its not in warranty then try for any local mechanic.If you try to manually open it there is a very possible chance of any kind of damage.
Jul 29, 2012 | Sony Handycam CCD-TRV32 8mm Analog...
Cannot get tape to eject
It could be a couple of different issues. These things could help.
(1) Power OFF the camera, remove battery then replace the battery, power up the cam and try to eject tape again. Nothing? try...
(2) Gently press inward on the tape cover with both thumbs a few times. Then, while pressing gently inward with one hand, press the release/eject-tape function until you hear a click or release sound. Then, if it doesn't open automatically, gently "help" open the hatch.
If it remains stuck, after follwing these steps a few times it would be my guess that perhaps the camera has been dropped in a way that jammed the mechanism controlling the eject function.
TIPS that may prevent having eject problems: When loading tape, be sure to insert the tape correctly and slowly, makeing sure the tape is placed properly. Gently press on the specific location indicated to close the tape holder, and wait for the tape to "seat" properly before closing any other part of the tape cover or hatch mechanism. Taking a few extra seconds when loading the tape can save extended frustration later.
May 16, 2011 | Samsung SC-D363 Mini DV Digital Camcorder
My Canon Elura 80, digital camcorder, has been acting up for the past year. First, it went through a period where it refused to eject the tape. In this, I mean I could open the side panel, but it would...
Tape mechanism problems are quite complicated but they can usually be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be diagnosed by a qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
Oct 06, 2010 | Canon Elura 80 Mini DV Digital Camcorder
Panasonic Palmcorder PV-43D cannot get door open
Hi there.
Sometimes a gentle slap with the palm of your hand with the door facing towards the ground does the trick, make sure you power it off then on press eject while you gently slap it.
Good luck and thanks for using FixYa!!
Apr 21, 2009 | Panasonic Palmcorder VDR-M50 DVD Camcorder
Tape will not eject
I had the same problem and I switched to smaller tapes. I had been using the 120 minute tapes. It seemed like the tape would lock up after a short while with the larger tapes.
Apr 05, 2009 | Sony Handycam CCD-TRV21 Camcorder
Tape will not eject / Battery full
while the eject process is trying to happen remove the battery and replace it. keep initiating the eject process and removing the battery and it should finally eject. If you attempt to use the camera again put in a new tape so you don't lose a tape that contains footage you may want to save.
Dec 07, 2008 | Canon ZR100 Mini DV Digital Camcorder
Tape will not eject
If you open the eject thingy like normal then look for a small white plastic tap. its located right underneath the "start/stop" text you see on the back end of the camera (where the record-button is). You´ll need something like a small screwdriver or similar. Press it and and the tape ejects like normal. Worked for me. Saved me the repair bill :)
Jul 22, 2008 | Sony Handycam DCR-HC40 Mini DV Digital...
Flashing code C:32:11
USE THE MAINS ADAPTER....TAKE THE BATTERY OUT, AND CONNECT MAINS ADAPTER THEN IT SHOULD WORK THEN TRY EJECTING THE TAPE AGAIN
Feb 23, 2008 | Sony Handycam DCR-TRV103 Digital Camcorder
Panasonic PV-GS150 wont eject
Defective mechanism, a stucked mechanism is present. camcorder are smart it can detects error and shuts down itself for safety. earlier models dominoes the defect if the user is not quick enough to react when something goes wrong with the camera. You need professional service to fix it.
Sep 17, 2007 | Panasonic PV-GS150 Mini DV Digital...
Sony Handycam DCR-TRV740 Digital Camcorder Logo
177 people viewed this question
Top Sony Video Cameras Experts
Parshiv Luthra
Jose Ma DM.
Jose Ma DM.
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
