Question about Zenith B27A11Z 27" TV
Where can i find a new power cord?
Hey I found this modelo television out by the dumpster looked like it was ok noticed it wouldnt turn on. Then i noticed the power cord was frayed. Figured i might try to fix it but need to find a cord.Any ideas?
  • 84 Answers
REPAIR OLD WITH ECETRICAL TAPE IF THE WIRES TOUCHED TOGETHER THEN IT PROBERLY BLEW A FUSE
Posted on Oct 18, 2008
My unit does not power up when the button is pushed. Power is at the receptical.
As I recall, I found a unit in the dumpster and took it home to check out. I turned it on and had power display but no heat. Started looking around for model number and other info.
As I was moving it I heard oil sizzling. The unit has worked since then. There are bimetallic switches inside of them. They tend to stick. Moving it around (dumpster trip, my trip home) allowed it to return to its proper position (normally closed).
I have ran into this with many coffee makers, bounce them around a bit and the sensor will reset.
Hope this helps you!!
Aug 06, 2014 | Honeywell HZ-709 Oil Filled Radiator...
T.V. WILL NOT TURN ON.
my t.v. didn't have a blown fuse, so my fix may not work for you. mine would turn on and read "digital television" then go into "calibration" or "service" mode where the screen shows changing colors without ever showing a picture. by chatting online with the service department (something you may want to do), i found that by using the original remote for my t.v. i could easily hit two buttons on it to bring it out of that mode. i found one after searching extensively on amazon, bought it for $20 and this t.v. found in a dumpster has been working like new ever since. more serious problems with an emerson t.v. may not be worth putting money into as they're a low end brand of electronics.
Mar 28, 2014 | Emerson LC320EM9 32 in. LCD HDTV
HP5066 flickering
Return it to the dumpster. It is a lost cause.
May 03, 2017 | Televison & Video
Device will not power on
I found a Magellan Roadmate in the dumpster when I was dumping the trash off my truck.They were even so kind to leave the charging cord.I figured out that the charging cord wasn't connecting to the unit when plugged in.It took 20 minutes to figure out how to pop the case open(retainer tabs on all sides in addition to the screws).Once opened up,it took 5 minutes to repair the solder connections from the power socket to he circuit board.Works like new!
May 31, 2012 | Magellan Roadmate 2035 4370 2036 4040...
Lamp light is yellow. Replaced bulb still not working1
CHECK AND MAKE SURE THAT THE LAMP DOOR IS SECURE ON THE BACK OF THE TV.
Dec 16, 2010 | Mitsubishi WD-57733 57" HDTV
Pheonix gold amp bass remote
i just had the same amp and tried using my buddies bass knob from a different model wouldnt work so i called company they said you have to have the cord that came with the amp
Jan 14, 2009 | Car Audio & Video
8 Flashes, Changed Flyback... still no good.
Try the High Voltage block first. Very common failure.
Jan 04, 2009 | Sony KP-57WS510 57" Rear Projection HDTV
Same problem as others have had but with a twist
SOUNDS LIKE IT WAS (FIXED) PUT BACK IN THE BOX AND TRIED TO SHUCK IT OFF ON SOMEONE YOUR BEST BET WOULD BE SENDING IT TO GATEWAY MAYBE JUST MAYBE THEY WOULD HELP YOU EXPLAIN WHAT HAPPENED
Oct 09, 2008 | Gateway FPD2185W 21 in. LCD Television
Lightning strike
there is usually about 3 fuses in mitsubishis many models have more than 3. Look the bord over good where the power enters especially in the center of the board.
Jun 11, 2008 | Mitsubishi WS-55315 55" Rear Projection...
No picture
I would pull the cover off to see if the tube and the board on the CRT are not damaged. If it looks ok, turn set on and observe if there is any activity visible at the neck of the CRT (light). Wehn a set with a large tube starts-up, it wil make a fuzzt crackle noise fro the high voltage charge in the tube. If non of this is happening, check main board for cracks. Unit is probably salvageable for point to point solder job, but as far aspart replacement for HV power supply, I would not do it. It is not cost effective.
Aug 01, 2007 | RCA 32V550T 32" TV
Zenith B27A11Z 27" TV Logo
47 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
