Question about Eureka Vacuums
How to change the belt on a eureka 11 amp model #4337
    Problem Solver:
  • 10 Answers
There are two screws on the hood of your vacuum that you will find inside those decorative holes on either side of the top. Use a phillips head scredriver to remove them and the hood will come off. You can then change the belt.
Posted on Oct 24, 2008
2 Suggested Answers
bobjrdns
  • 84 Answers
SOURCE: how to change a belt....rollers
TAKE THE SCREWS OFF THE BOTTOM AND PULL THE ROLLER OFF INSTALL NEW BELT
Posted on Oct 18, 2008
Eureka Optima 431x Belt replacement
Not sure if this is any good but here is a link to a youtube video showing how to remove the cover and change the brush and belt.
https://www.youtube.com/watch?v=JxoHDvr1ZJI
Apr 07, 2013 | Eureka 431A Optima Bagless Upright Vacuum
What belt do I purchase for eureka whirlwind litespeed
If you have the exact model Eureka that this repair was listed under, model 4388 then please find a link to the belt you need below. If you'd like to verify the model number, please check the back or the bottom of the vacuum for a sticker that also will contain the serial number, and look for the word Model Number. If you don't have the 4388, please just add a comment with the model you have and I'll be more then happy to verify these two models take the same belt, or give you a link to the belt that goes to your model if they are different.
Here's a link to the exact belt called for on the model 4388:
Eureka Extended Life Style U Belt, Part 61120
Here's step by step instructions on how to replace the belt:
How To Replace Brush Roll Belt
NOTE: Turn off the switch and unplug the electrical cord
before replacing belt. Belt pulleys can become
hot during normal use. To prevent injury, avoid
touching the motor pulley when checking the belt.
1. Lower handle to floor to change belt.
2. Loosen, but do not remove, two screws to release hood.
Lift hood to remove.
3. Lift left end of brush roll.
4. Remove and discard belt.
5. Place new belt around motor pulley.
6. Place belt around brush roll pulley.
7. Align left end cap with square in base. Push
end cap into place; see left side view.
8. Pull right side of brush roll to stretch belt.
Secure right end cap into base.
9. Rotate brush roll to seat belt.
10. Replace the hood. Make sure hood front is
behind furniture guard. Hood should seat
onto self-locating screw tabs.
11. Tighten screws.
I hope this information was helpful to you in changing the belt. If you have any questions about how to change this belt, please just add a comment here on the repair page of Fixya, and I'll be happy to answer any follow up questions you might have. If you found this helpful, please be so kind and rate my repair helpful and / or leave feedback for me.
Thanks so much,
Chris Jones
GoVacuum.com
Apr 21, 2010 | Eureka Whirlwind 4388 Bagless Upright...
What Model replacement belt do I need for the Eureka model 2961 BVZ?
Greetings,
According to the Eureka Part diagram for your particular model vacuum, your vacuum uses Eureka Style U Belts. Eureka makes actually 2 different styles of U belts.
The first style is the standard U belt, Eureka part number 54312. This belt is probably the one that came standard on your model. You may purchase this belt from the link below;
http://eurekaservice.stores.yahoo.net/uprightbelt.html
The other type of Style U belt that will fit your model is the Eureka Extended Life Style U Belt, Part 61120B. The Extended U belt is more durable, and lasts longer then the Eureka Standard U belt. You may purchase the Extended U belt here;
http://eurekaservice.stores.yahoo.net/exlifubel.html
Now, if you are quite sure how to change your belt, you may visit the link below to see the owners manual for your Eureka 2961BVZ that will give you step by step instructions on how to change the belt;
http://eureka.com/service/manuals/80244.pdf
I really hope that this was helpful to you in finding and fixing the belt for your Eureka. If you did find this helpful, please be kind and rate my repair solution as helpful by clicking the thumbs up icon in the lower right hand corner below. I really do appreciate it, thank you.
Feel free to request a repair clarification if you have any questions about the procedure of installing the belt on your Eureka, I'll be happy to help.
Chris J.
Mar 12, 2010 | Eureka 2961AVZ Bagless Upright Vacuum
How do you change the belt on a model 5856
here is a link to the manual which has instructions and to the belts you need
Eureka 5856 Belts
Eureka 5856 Owner's Guide
Nov 22, 2009 | Vacuums
How do I to change the belt on an eureka altima 12?
the belt is on the bottom right (looking at it from the front). the Eureka website does have the manual for download, http://www.eureka.com/service/manuals/80244.pdf
With the vacuum flattened (straightened) out, turn it over and remove the back roller cover, (2 screws) once off, the roller should just pop out on the opposite side (opposite from the belt). Don't forget to turn the roller to center the belt once you have it on.
Jun 14, 2009 | Eureka Altima Upright Vacuum Model 2996AVS...
Just need to know how to change the belt on my vacuum cleaner
Step 1: Lower handle to floor to change belt
Step 2: Remove the two screws from the top hood on the foot
Step 3: Lift hood to remove
Step 4: Lift right end of brushroll (the belt end)
Step 5: Remove and discard belt.
Step 6: Place new belt around motor shaft.
Step 7: Place new belt around brushroll pulley.
Step 8: Align left end cap with base. Push end cap securely into
place. Make sure the square on the brushroll cap is in
place
Step 9: Pull right side of brushroll to stretch belt. Secure right
end cap into base.
IMPORTANT
Step 10: Rotate brushroll by hand several full rotations to properly
position belt.
Step 11: Place hood back on cleaner. Replace and tighten
two screws.
Step 12: Return vacuum to upright position.
Dec 09, 2008 | Eureka Altima Upright Vacuum Model 2996AVS...
How to change a belt....rollers are not working...model #4337 eukeka 11 amps
Oct 18, 2008 | Eureka Vacuums
Vacuums Logo
85 people viewed this question
Top Eureka Vacuums Experts
charlesjo336
Level 1 Expert
JoeVacs
Are you an Eureka Vacuum Expert? Answer questions, earn points and help others
