Question about Maytag MMV5207A Microwave Oven
Loss of power
My Maytag UMC5200AAW power went out. It happened when a clock fell of the wall and hit the handle on the lower oven, shattering the oven glass. I can replace the oven glass easy enough, but I need to know if there is a reset button for the micorwave?
Don
  • Maytag Master
  • 9,086 Answers
There would not be a reset button, but a hard reset can be done by unplugging it for a minute or so, then plugging it back in.
If that doesn't work, chances are you have a fuse blown in the microwave.
It's usually behind the grille, which is held in place by two screws.
Let us know what you find.
Posted on Oct 19, 2008
Intermittent Power Loss
Take the unit apart and carefully inspect the wires under the keypad...short of that..junk it and get a new one. It seems they just don't make things the way tey used to.
Nov 19, 2013 | Samsung SMH9187 Microwave Oven
I have a 1995 Sharp Carousel R-1440. Our power went out then when it came on our microwave it no longer working properly. the clock works but when the door is closed the cooling fan starts running- it...
Yes your oven's controller is probably malfunctioning you need to replace the SYSTEM BOARD but I personally suggest to buy an other oven.... the system board will be hard to find and expensive...
See if other electronics is acting funny since the power loss... you could CLAIM the damage from the insurance company
Good luck!!
Feb 28, 2011 | Sharp R-1460 Microwave Oven
I have an over the stove microwave. It was working and then went out. I changed the 20amp fuse and still nothing. there is power to it from the outlet. the clock and all the buttons do not work. model...
Dead appliance, power on wall outlet.
YOUR SAFETY IS PARAMOUNT!
Attempt this only if you are competent.
If your appliance has absolutely no functions at all, remove it from the mains supply, remove the case and see where the mains lead goes in to the appliance and follow the cable until you find the main fuse.
ONLY USE THE SAME TYPE AND RATING OF FUSE TO REPLACE IT.
The usual cause of this fuse failure is the door switches are contaminated or sticking. Check the door switches before putting power back on to the appliance.
Hope this helps.
Jan 17, 2011 | Maytag Appliances Over-the-Range Microwave...
Maytag UMC5200AAW SS # 51285923 Never had any problem until, today it sparked and a small fire out of the top of the cover on the inside top of the right wall panel. We have it built in to a cabnet...
That sounds like a wave guide cover that protects food splatter from getting into wave guide. will need to replace that cover and thoroughly clean inside of unit ans around cover. Those covers must be kept clean and dry!!!
Sep 10, 2017 | Maytag MMV5100A Microwave Oven
Went to use microwave and it just went dead. Household power is fine and breakers are good. Replaced main fuse behind switch panel and got power back for clock etc.. When I went to run it again, it went...
short circuit in high tension power supply
DUE TO THE VERY HIGH AND DANGEROUS VOLTAGE 4000( V) IT IS NOT WISE TO FIX IT YOUR SELF UNLESS YOU KNOW WHAT YOU ARE DOING
Apr 26, 2010 | Maytag MMV5100A Microwave Oven
GE Spacemaker Microwave Clock inop
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
You can download GE owner's manuals and installation instructions here.
Oct 18, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Maytag Microwave
Mine is a model UMC5200AAW. Same problem as above, no power. Is there a reste button?
Nubi541
Oct 07, 2008 | Maytag MMV5207A Microwave Oven
Power cuts out after about 5 seconds
Hi try unplugging form mains for an hour this will reset any settings back to factory settings let me know what happens after doing this then i can assist you further ok
Mar 19, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Maytag MMV5207A Microwave Oven Logo
115 people viewed this question
Top Maytag Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Maytag Microwave Oven Expert? Answer questions, earn points and help others
