Question about Eureka Vacuums
How to change a belt....rollers are not working...model #4337 eukeka 11 amps
  • 84 Answers
TAKE THE SCREWS OFF THE BOTTOM AND PULL THE ROLLER OFF INSTALL NEW BELT
Posted on Oct 18, 2008
Brushes don't rotate on proheat2X,
How to Replace the Belt & Brushroll on Bissell ProHeat 2X ...
? 2:11
https://www.youtube.com/watch?v=Jj_43IHz9U4
Dec 28, 2012 - Uploaded by eVacuumBags
How to Replace the Belt & Brushroll on Bissell ProHeat 2X Series Carpet ... How to Replace Bissell Deep Cleaner Pump Belt orBrush Belt - Duration: 1:44. ... Won't SPRAY solution Rollers spin Fixing Bissell ProHeat Carpet ...
Brushes Will Not Rotate Deep Clean Essential - YouTube
? 0:53
https://www.youtube.com/watch?v=gbEXY5jkWSc
Apr 9, 2015 - Uploaded by BISSELL
If your machine is turned on and in the upright position yourbrushes will not turn. ... How to Replace the Belt & Brushroll on Bissell ProHeat 2X Series Carpet ... Won't SPRAY solution Rollers spin Fixing Bissell ProHeat Carpet ...
bissell pro heat 2x brushes wont spin Questions & Answers ...
www.fixya.com > Forum > Tags
... bissell pro heat pet 2x and my brushes won't turn or operate... check the belt belts ok brushes won't turn/rotate turn dial on bottom front on the water tank to ...
Feb 03, 2016 | Vacuums
Brushes don't move. vacuum motor works
The brushes on the roller are driven by a wide, short rubber belt. These belts get old, worn, overheated, and break periodically.
It should be a fairly simple matter to unscrew & remove the plate, revealing the belt and roller assembly. You can get a replacement belt at Sears or nearly any vacuum shop.
While replacing the belt, it would be a good idea to take scissors or a knife (careful!) and remove the hair & other material that's wound around your roller. One thing that can cause a belt to break is when you're vacuuming & accidently pick up a string, a shoelace, a piece of cord... you know how fast that gets wound around the brush roller and locks it up? At that point, the belt is still trying to rotate the roller (which won't rotate)... and within seconds, the belt will get extremely hot. This can cause it to break, or reduce its life significantly.
This should be an easy fix, requiring nothing more than a replacement belt and a screwdriver. Good luck!
Mar 03, 2011 | Kenmore 31913 Progressive Direct Drive...
Dc 24 roller brush quit working....belt is okay & there are no obstructions on roller or in head compartment & suction at head is strong
Hi there, sometimes a stretched belt will hamper the vac. from picking up. he best way to test this is to turn the machine on, then carefully put you hand on the roller. If the belt is stretched the roller will stop turning when you apply pressure. Hope this helps, Chris
Feb 09, 2011 | Dyson Ball DC24 Bagless Upright Vacuum
How do I change my belt?
1. Turn vacuum over so base of powerhead is facing up.
2. Remove the two screws near the roller.
3. Release the two hooks over the brush by pushing outward.
4. Gently lift and remove the plate.
5. Lift and remove brush roller.
6. Remove belt.
7. Place belt over roller in the area with no bristles.
8. Insert brush back into holder and loop belt over motor shaft.
9. Rotate the roller a few times to make sure the belt is properly positioned.
10. Replace the plate over roller, making sure the front tabs line up with the slots on the base.
11. Flip down to secure hooks.
12. Press down on plate to secure it.
13. Replace screws.
14. Turn roller a few times.
And you're done.
The manual with illustrations and instructions can be found using the below link.
http://www.dirtdevil.com/search.aspx?q=UD40135&type=3
Jan 21, 2011 | Dirt Devil Featherlight Bagless Upright...
HOW DO YOU CHECK OR CHANGE THE BELT?
remove 4 Phillip screws from the bottom one near each corner pry up the bottom panel then just pull the brush roller up . put the belt over the roller push the roller back in place and flip the belt over on the shaft replace cover & screws.
Dec 23, 2010 | Euro-Pro NV31 Infinity Vacuum
Anyone know why my Bissell Proheat 2X Turbo Model 9300's brushes won't turn anymore
If the Brushes don't rotate, & you have two brushes; 1). Turn unit on side. ( Make sure unit is up-pluged) 2). Rotate the front brush roller, if the second roller moves at same time, 3). Locate a small ribbed belt that goes from the further back roller, to a small ribbed pully. (Gates belt #177-3m5) ( on side under a clear cover) The belt may not be broken, but may have carpet fuzz / lint covering the belt ribs, causing the belt to slip. If that belt is OK and you find that the small pully doesn't turn the belt/rollers, the problem is with a small internal direct drive motor, that drives the brush rollers. At this point return the unit, as Bissell has a design defect & is using cheap parts.
Nov 04, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
How do I to change the belt on an eureka altima 12?
the belt is on the bottom right (looking at it from the front). the Eureka website does have the manual for download, http://www.eureka.com/service/manuals/80244.pdf
With the vacuum flattened (straightened) out, turn it over and remove the back roller cover, (2 screws) once off, the roller should just pop out on the opposite side (opposite from the belt). Don't forget to turn the roller to center the belt once you have it on.
Jun 14, 2009 | Eureka Altima Upright Vacuum Model 2996AVS...
I have a Hoover WindTunnel, Self-propelled model, and it was working great until I ran over a portion of the cord, then it started making a bad noise and I noticed the roller is not moving consistently...I...
The V belt usually wears down first. Remove the roller and belt to visually check for wear and belt material in the roller pulley. I would change the flat belt as well. Also, replace the cord if any wires are exposed
Mar 08, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
Eureka, whirlwind 12 amp vacuum does not pick up anything
That problem can be caused by the belt being stretched out and even though it is spinning when you look at it, with the resistance of the carpet it will stop.
With a model number I could tell you exactly how to change the belt, but most of the whirlwinds I've seen are similar.
You need to gain access the belt and roller. On most models there are two screws on the top of the nozzle inside one of the four indentions that run along each side. Once you take those out it allows you to take the hood off.
Remove the brush roller and old belt. Wrap the new belt around the motor shaft and place the roller through the belt loop and use the roller as leverage to stretch the roller back into the roller housing. It will take a little muscle. Give the roller a spin by hand before putting the hood back on. It should spin easily. If it doesn't then you might have pinched the belt and need to free it or the belt will just burn up when you turn the unit on.
A clog in the hose going down to the nozzle would also cause this problem, so check that hose when you take the hood off.
Nov 30, 2008 | Eureka Vacuums
How to change the belt on a eureka 11 amp model #4337
There are two screws on the hood of your vacuum that you will find inside those decorative holes on either side of the top. Use a phillips head scredriver to remove them and the hood will come off. You can then change the belt.
Oct 18, 2008 | Eureka Vacuums
Vacuums Logo
65 people viewed this question
Top Eureka Vacuums Experts
Jim Parker
Jim Parker
charlesjo336
Level 1 Expert
Are you an Eureka Vacuum Expert? Answer questions, earn points and help others
