Question about Motorola Mobility RAZR V3
Problems when it rings
When i get a call the phone does not not stay lit threw the whole call it goes black i hate it cause then u cant see whos calling anybody else have this problem? i also find the phone is to wide and long for me. I have small hands so its hard to hang onto.
  • lobo260 Oct 19, 2008
    I went to settings the backlight is set for 60 seconds and the display timeout is set to 2 minutes it did not change anything. Anybody find that the razr is to wide and thin? would the outer display bug someone going dark like that so soon? they say that it conserves battery life but i find it annoying exspecially if its night time.
  • 70 Answers
You should be able to control how long the display light stays on. Try going to the menu and select Settings. I don't have the exact phone, but in the Settings menu you should be able to select Display. This is typically where you can control the backlight and length of time it stays on. Good Luck!
Posted on Oct 18, 2008
Screen is blank, keys are lit up
Hi this means you have one of 2 problems if the phone switches on and you can ring the phone but cant see the display then this means its a simple fix and you only need to have the screen data ribbon replaced as it has got a broken single strand wire running through it and this has caused the connection with the screen to be lost.
If how ever you cant even ring the phone then this points to a more serious fault, it could mean it needs the firmware re-installing or it could point to the fact the board has got damaged due to over heating caused by faulty battery or the board could be warped caused by keeping the phone in your pocket and sitting on it
if it the first problem then this is an easy fix if its not then it will need sending off to be tested as the problem could be a number of things.
let me know if you need further assistance ok
plz rate this solution as i have a whole page of unrated posts, thanks
Aug 31, 2010 | RIM Research In Motion Blackberry Storm...
Screen cant open
it probably isnot a virus,the flex cable is probably cracked where it goes threw the hinge
Jun 07, 2010 | Motorola Mobility MOTOKRZR K1 Cellular...
Monitor screen will not stay lit. It will only stay lit for a second then goes black.rq
The problem can be caused by bad caps in the power supply, bad inverter backlights circuits, bad lamps. Look for bad caps first, then post back what you find so we can guide you further, see example of failed monitors due to bad caps here:
Jan 30, 2010 | HP w1907 LCD Monitor
My phone charges fully but lasts less than 24 hrs even if I don't use it. At the same time as this problem started I noticed the Motorola symbol on the front stays lit all the time, even when the phones...
mine does that to that is because it went threw water or something you cant really do anything about it besides buy a new batery pack or try to dry it out really good
Jul 07, 2009 | Motorola Mobility RAZR V3
Phone doesnt turn on, lights on but screen stays black
To easiest way to fix this is to go back to the company you brought the phone off as it is a problem within the phone hope this helps...
May 25, 2009 | Sony Ericsson K850i Mobile Phone
Backlight behind numbers
in the case of your phone, you have to replace the keypad membrane of your phone, if you cant find a spare keypad membrane, you have to replace the whole flex. you can buy a flex in motorolla service centers near your place.
Jun 12, 2008 | Motorola Mobility RAZR V3c Cellular Phone
Hi it sounds like your problem is that the call diverts are set to divert all calls what you need to do is goto settings then goto call settings then look for call divert settings what you need to do is cancel all diverts and then go through them one by one and just
activate divert if off (activating this one goes to ans phn if phn off
activate divert if busy ( goes to ans phn if your on phone call)
activate divert if out of reach (goes to ans phn if no signal)
After doing these settings then your phone should ring when someone calls you.
Before you activate any divert setting select cancel all diverts then get someone to ring you and make sure phone rings the screen will now display whos callind and the phone should also ring.
Let me know if you need further assistance ok let me know how you get on
Feb 15, 2008 | Pantech C120 Cellular Phone
Razr- turning on camera makes screen turn black but keypad stays lit
the easiest thing tpo do here is take it to a professional but if you want to try updating your software off the Motorola website. (this require a data cable or bluetooth in your computer) This fixes a lot of software problems with the razor. If this doesn't work then you will have to reflash your Firmware which is like the Windows Xp of the phone. This does require a professional as it can destroy the phone
Jul 05, 2007 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3 Logo
37 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
