Question about Gateway GTW-P42M102 Television
Gateway GTW-P42M102 / Won't come on
Won't come on.. hear a click and it never comes on... Have tested power supplies and they are working properly. Green light in rear panel is blinking 5 times! Does anyone know what has to be replaced.... What is the answer for a 5 blink code? And where can I get parts. Thanks... JD49
  • b_boyuka Oct 22, 2008
    hi im from monterrey mexico i have the same problem but i dont know were is the m105k
    any help please
    muchas gracias guys
    this is my mail b_boyuka@hotmail.com
  • Robtickedoff May 21, 2009
    Having the same problem here with the unit powering on you can hear it power up and the internal led on the board lights up but the unit will not turn on? this is a GTW-P45M103 model.
    Champion:
  • 217 Answers
Check the panel voltages, and start unplugging the cables to each PCB and check the voltages each time, if the voltages come back up the its probably the PCB that is disconnected, in most case its the logic main board. Hope this helps
Posted on Feb 17, 2007
Had the same problem... drove me nuts... I figured what the hell!!! I started pulling boards out, and on the main power board I dicovered a visual indication that one of the main capacitors "M105k" took a ****. Ordered it for $1.29... presto, works like a charm! I had to remove both relays and manually rig them to the on position for troubleshooting purposes. I'm replacing them with new ones. Let me know if this helps!
Posted on Apr 20, 2008
Power Problem with 2Wire 2701HG-B
Sounds like a startup self test. All wireless devices go through a power on self test. Does it connect? You can connect to it and go online? I rarely turn mine off, only in a electrical storm.
Nov 22, 2012 | 2wire (2701HG-B) Wireless Router
I have a RCA 32" Flat Screen TV that shut off and
The sound was came from the clicking of the relay. This kind of symptoms is an indication of out-of-regulation condition on the power supply section. This is caused by faulty electrolytic capacitor. It will dropped the supply voltage and will trigger that kind of symptoms.
Faulty electrolytic capacitor mostly has a physical indication of fault like bulged/dome at the top and can be easily identified. See sample picture of faulty electrolytic capacitor below.
capacitor with bulged/dome at the top.
Check these parts on the power supply section. Once found, replaced it with same capacitance and working voltage which is printed on its body itself. Click this LINK for more info regarding electrolytic capacitor.
If you don't have necessary tools and test instrument and can't troubleshoot the unit yourself, I would advice you to look for a qualified TV Technician to isolate the faulty parts.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Aug 05, 2011 | RCA L32HD31 32 in. LCD HDTV
Wont turn on
Replace the power supply unit. www.shopjimmy.com my have the part.
Thanks
Nov 08, 2010 | Gateway GTW-P42M102 Television
The menu pops up on starting and continues to scroll. The front panel buttons on the TV do not do what they are supposed to do (i.e. Vol button changes input option, etc.)
i have the gtw-p42m102 and it did the scrolling thing and i had the image board dpwb11393-1g-l changed and it worked fine for 2 years.Now it made a pop like a firecracker and i am working in it now.
Aug 03, 2010 | Gateway GTW-P42M102 Television
I have a 37" Philips (37PF9431D/37) flat panel tv. It won't power on. When you plug it in you can hear a click the green light stays on for a few seconds then goes out. I've checked the power board for bad...
i am having the same problem. My Phillips 37" 37PF9431D/37I LCD High Definition TV won;t turn on. When I press the power button i hear a click and the green light comes on for a couple of seconds and then the red light appears. I can;t figure it out. Did you find a solution?
May 20, 2010 | Philips 37PF7320A 37 in. HD-Ready LCD...
Open Questions:
Televison & Video Logo
1,293 people viewed this question
Top Gateway Televison & Video Experts
Ronald
Level 1 Expert
Jerry Greenberg
Jerry Greenberg
Are you a Gateway Televison and Video Expert? Answer questions, earn points and help others
