Question about Akai LCT2785TA 27 in. LCD Television
Will not power-on
17 months old, will not turn on via remote or TV on/off button. Sometimes it makes a sparking-type sound as if it's trying to turn on. Screen remains black as if off.
Not fair to spend $549.00 for a television that only lasted 17 months.
  • 1 more comment
  • icnse235 Oct 18, 2008
    How do I locate and identify the fuse and inverter? Where do I get diagrams?
    Is there one of each or more?
    How do I test them?
    Is this a common problem?
    Is this something a layperson can do?
    If not, what would be the estimated cost, is it worth fixing, and is there a high probability it will happen again?
    How do I test them?
    How do I test them?
    If not, what would be the estimated cost, is it worth fixing, and is there a high probability it will happen again.
    Please answer my response to your solution.
    New Friend:
Heating the back of the TV with a heater actually worked for me. For years I have suffered wuth this issue if I unplug my Bush LCD TV I have to leave it unplugged from 1 to 10 days before it will work again. Today I read this forum and put a heater pointing at the back of the TV for 10 minutes whilst the TV was unplugged from the mains. When I plugged TV back into mains it came to life. I am amazed!
Posted on Oct 07, 2014
  • Akai Master
  • 5,138 Answers
So far all of the LCD that has came in my shop has been minor problems poor connections and Bad capacitors. charge 190.00 225.00 unless you know what you are doing take to Repair Shop .Good Luck with your set. Resolder pcb,s. Look for bad caps.
Posted on Oct 18, 2008
    President:
  • 2,712 Answers
1. Try this - hold the menu button down for 10 seconds. TV should power up; you will have to turn off front panel buttons on menu.
2. You can also try a hard reset: Unplug TV from AC mains and remove all cables from TV. Wait about 30 minutes and re-plug to AC power and redo the cabling. Switch on the TV and see if it works..
3. Powering down the set or putting it in standby may have allowed the power supply to cool. Weak capacitors often go out of spec when they cool, thus preventing a section of the power supply from firing up properly again. There is a simple trick...just warm the back of the TV with a hair dryer for 5-7 mins after you have unplugged the TV. Look for the little areas of holes in the back panel of TV. Use these as your guide at where to use the hairdryer, but don't hold the dryer too close (say 5-6inches away). (Make sure the dryer is on High heat). If the TV doesn't turn on after you have heated it up (like it tries to come on but then turns off) you need to unplug the TV again, this resets it. And repeat those steps till it works. Resetting the TV after it fails to turn on is the key. Also, just leave the TV on. Don't turn in off. Since it is LCD, it doesn't take much power...only a few bucks extra a month for your utility bill.
4. A circuit board may crack about some of the larger components mounted on it. Try the slap test – Hit the TV firmly on the side. If there is any change in the picture, it could indicate a possible solder problem / connections. You can inspect the PCB's for fractures, and then repair them. It may also be poor soldering that has failed. I would be checking for these things first.
  • 1,031 Answers
Its a power supply problem,check the fuse and the breaker also try plugging it in another electrical outlet if this fails the you know that the inverter board must have being damaged. The best thing to do will be to get a replacement part .thanks and Godbless
  • Starnley Johnwells
    Starnley Johnwells Oct 18, 2008
    the power supply board replacement should be best done by a repair technician its not a lay mans job.it will cost about $150 to replace .goodluck
    these power supply problems were often caused by failed electrolytic capacitors
    . The power supply PC board contained several different individual different voltage power supplies.may be the electrolytic capacitors located on the PC board had obviously failed. The tops of these capacitors may be puffed out. Often when electrolytic capacitors fail they get over heated and the top of the capacitor is puffed out displaying an over pressurized appearance. The power supplies on the board is of the switching type
    The suspect capacitors can easily be removed.
    The New Electrolytic capacitors:
    President:
  • 1,952 Answers
  • Lack of startup horizontal drive - see the section:Startup problems - nothing happens, click, ortick-tick-tick sound. The main regulator is cycling on overvoltagedue to lack of load.
  • Excessive load or faulty power supply cycling on its overcurrent protection circuit.
  • High voltage shutdown, or some other system detecting an out of regulation condition. However, in this case, there should be some indication that the deflection and HV is attempting to come up - momentary whine, static on the screen, etc.
  • A dried up main filter capacitor or other filter capacitor in the low voltage power supply that is producing an out-of-regulation condition until it warms up. A bad filter capacitor on the output of a series regulator may result in excessive voltage and subsequent shutdown.
  • A problem with the microcontroller, relay or its driver, or standby power supply
  • mohammed marika thambi
    mohammed marika thambi Oct 19, 2008
    i think fuse may be present in the main board...check it up..
    Genius:
  • 1,550 Answers
Check the fuse and inverter ?
  • SAM ANDERSON Oct 18, 2008
    You download the manual from the link below if you dont have one
    Manual for akai
    From the manual you can get idea about the correct location for fuse and inverter for this particular model . Generally fuse will be at the back cover of the tv .
    This problem is common in most of Akai tv .
    This steps can be performed by any one .
    If your problem still exists then you need to call technican for checking the power board .
    The cost will be around $50 for service charge for technican .
    Since it is 17 months old it is worth repairing it . It will be mostly the fault of inverter or power board .Once you repair it you will not have problem for atleast 2 - 3 years .
Ah59-02342a doesn't control tv anymore
Hi I had exactly the same problem with mine it worked the DVD player fine but not the TV even though previously it had worked both .......... Manual Guide In the manual guide I managed to dig out it says to do the following to set up the remote to work the TV
Press the TV button on the remote
Then whilst holding down the power button you need to enter in the samsung TV codes until your TV turns off (I only got to the first and it did it)
The numbers are 00, 15, 16, 17, 40, 43, 46, 47, 48, 49, 59, 60, 98
Hope this helps
Feb 24, 2012 | Samsung TV Remote Control
I have an LG TV 17 months old, sometimes the picture is perfect then it goes all differenct colours and the people have white hair and mouths and you cannot really make the people out. The sound is...
This type of issue is not that really simple. Internal parts are problematic or worse could be busted and needs replacement. Since it's only 17 months old, Warranty is the best solution. Contact the manufacturer of your TV and let them handle it. Provide them with all the details they will ask you, you will need to be patient on this one, like i said, it's not a simple issue...
Nov 03, 2009 | LG 32LG40 32 in. LCD HDTV
Magnavox 20MT4405/17 Error and remote control problem
what you describe sounds like you have a short inside the safe bet is take it to a repair shop.
Oct 05, 2009 | Philips Magnavox 20MS233S 20" TV
Blue light on, no bckgd light, picture, sound, or remote HELP!!!
The indications that the power supply is going is when you start noticing flickering and sound like shorts when you watch TV...
I do not know how to answwr this without looking at it but first I will check again and follow how far you are getting electric to the board
Sep 06, 2009 | Insignia 37" LCD Flat-Panel HDTV
My television won't come out of stand by
Basically it sounds like you have no power otherwise because I am assuming you have also tried the power button on the TV itself. Does the light on the TV do anything at all when the power button is pressed?
Feb 06, 2007 | Sharp 32F-830 32" TV
Akai LCT2785TA 27 in. LCD Television Logo
182 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
