Question about Samsung PCJ614RF 61" Rear Projection Television
Samsung PCJ614RF-Picture alignment is off to the left.
Hello All: Would need to know how to access the service menu from the remote control to re-align my image- left to right, presently my image is to far to the left. Any help would be appreciated. Thank You snowman
  • 1,476 Answers
Www.servicemanuals.net would be able to supply the service manual for this unit which should tell you how to access the service menu. Their manuals are reasonably priced and you could probably use it later anyway. Good luck.
Posted on Jun 26, 2006
I need to access the service menu without the remote
You can't enter its service mode, without a remote control. To get some details, http://electronicshelponline.blogspot.com/ Pull up older posts.
Dec 03, 2013 | Samsung LN37A450 LCD TV
Need to access service menu
GO to All TV Service Menu Code to browse olmost tv factory mode.
You can find lot of service code for tvs, DVDs, Monitor and many more.
Mar 27, 2011 | Toshiba 26AV52R LCD TV
How do i unlock the panel lock on samsung portable combi tv vhs model no:TE-14N5
Hello
Unlocking your Samsung TV requires access to the Samsung TV service menu, which will allow you to reset or remove any previous lock in the settings. In order to unlock your Samsung TV you will need your remote control. All you have to do is simply follow the instructions provided below and you can use the service menu to guide you from there. Also note that upon entering the Service Menu, all User Menu settings will revert to factory default
Steps To Unlock A Samsung TV 1. Turn the power off.
2. On the remote, press Mute followed by 1, 8, 2, Power in sequence.
3. You should now see the service menu. To exit the Service Menu always select RESET.
You must have its orginal remote control with you to perform these functions. If you haven't it with you, contact Samsung Electronics at your country.
OK.
Jan 07, 2011 | Samsung CXJ1352 13 in. TV/VCR Combo
Convergence
It depends on what kind of convergence problem you got & what kind of universal remote you are using. If you mean aligning the crossline some
universal remote can be used to align the colors & on most TV you don't have to save it. Otherwise it will tell you what to do. If you are talking about aligning the convergence by accessing the service menu, you need the original remote control. Of coures this procedure is ONLY for the experience
technician. Good luck. AstroTech
Jun 02, 2009 | Hitachi 60DX10B 60" Rear Projection...
Need to access service menu/mode
To access the Zenith service menu: Hold down the menu button on the remote control until the menu disappears. Then type in 9-8-7-6-enter. This should do the trick. Be careful what setting you change. I would recommend writing them down before you change any. Hope this helps.
Apr 30, 2009 | Zenith IQC50H95W 50" Rear Projection...
Remote control key sequences.
That sounds like something that would be in a service manual. Now that your tv warranty is expired, you can probably buy the service manual off samsungparts.com. I wouldn't have suggested that if your tv was in warranty, because that procedure would be in the service menu, which only Samsung trained technicians have access to when the product is in warranty. Just remember, if you go in the service menu and mess things up and can't fix it, you would probably need service for the tv.
Jan 09, 2008 | Samsung BP59-00016A Remote Control
Need akai pt4799hd setup code
Do NOT attempt to enter the service mode to align convergence if you cannot align the convergence with the user's menu. If the convergence cannot be corrected with the user's menu, it means that one of your convergence IC's has burned out and possibly burned out the fuse next to it. If you change any settings without first replacing the bad parts, you will only make things much worse. I believe that set is actually a Samsung, and has the 2 convergence IC's on their own board mounted above the small signal board. If you do not know how to identify and replace shorted convergence IC's, allow a qualified tech to handle it for you.
Sep 03, 2007 | Akai PT4799HD Rear Projection Television
How to manually adjust the centering of the picture
On newer televisions the centering adjustment is only in the service menu. I wouldn't suggest anyone accessing it unless you understand all of the abbriviated alignments.
Feb 21, 2007 | Samsung TX-R2035 TV
Samsung PCJ614RF 61" Rear Projection Television Logo
91 people viewed this question
Jerry Greenberg
Jerry Greenberg
Demonic-2011
Demonic-2011
