Question about HP Computers & Internet
My Windows Vista will not keep the correct time. When I correct it, it will go back an hour...I need Central Indiana with the new time change, we are now the same time as the East coast. Is there a solution for this problem? Also my trash bin disapeared. I could not find it so I made a new default bin. It says full even when it is empty...where did the one that came with this PC go and how do I get it back and working correct? Thank You ConnieM1855@yahoo.com
  • JDTec
    JDTec May 11, 2010
    Did you set it to time zone you are in. It won't keep the time if the time zone is incorrect.
    President:
  • 1,901 Answers
Click on the clock, then on "Change date and time settings".
Click on "Change Time Zone".
Select Eastern Time Zone and check the box if your area observes Daylight Savings Time.
Posted on Oct 18, 2008
I need a manual for the 00593W weather station. Please?
Push and hold the "-" button on the main unit until "P" displays on the screen. You'll now set the time zone so the system can automatically set the clock. The screen will begin cycling between the time zones. Push the "Set" button when the correct time zone appears.
Mar 06, 2013 | Acu-Rite Acurite Wireless Weather...
I need the manual of breil milano shosholoza.the model is bw0480
The crown has 3 positions.
Normal screwed down.
First pull out position.
Second pull out position.
Setting the Time:
Pull out the crown to position 3.
Rotate the crown to set the exact time.
Ensure that you are in the daytime12 hour segment by allowing the hands to pass 12 o'clock and notice if the date moved on or not.
If the date changed, then you will need to advance at least 2 hours before moving on to set the date.
If you do not need to change the date, return the crown to position 1.
Setting the Date:
DO NOT DO THIS IF THE WATCH IS BETWEEN 8pm & 2am
Pull crown to position 2.
Rotate the crown clockwise to set to the correct date.
Return the crown to position 1.
Setting the Alarm [12 hour]
Pull the crown to position 2.
Rotate the crown anti clockwise to move the alarm hand to the desired time.
To activate the alarm, press the 8 o'clock button. You will hear 2 beeps.
To deactivate the alarm, press the 8 o'clock button. You will hear 1 beep.
NB If the alarm is not cancelled while it sounds the first time, it will repeat again in 2 minutes time. The alarm sound last for 15 seconds. If the alarm time coincides with 1 beep of the countdown, the alarm function will be cancelled.
Battery EOL [End Of Life]
The Swiss ISA 8270 movement uses a 395 cell and will signify a low power state by advancing the small seconds hand 4 steps every 4 seconds.
Setting the Countdown
You can specify a countdown of between 1 and 10 minutes.
Press the 4 o'clock button to enter setting mode. You will hear 1 beep.
Press the 4 o'clock button to move the central timing hand successively to the desired countdown time.
Wait 3 seconds for the watch to automatically exit the setting mode.
You can change the duration of the countdown [except in the last minute] at any time.
e.g. If the countdown is set to 10minutes, and you now want to change the countdown to 9 minutes, press the 4 o'clock button. The hours/seconds counter sub-dial will perform one complete turn and then stop at 60, before continuing.
Activating the Countdown:
Press the 2 o'clock button to start the countdown. You will hear 2 beeps.
When the countdown begins, the hour/seconds counter sub-dial indicates the seconds with 1 step every 2 seconds, and the central timing hand indicates the minutes with 1 step being 2.4 seconds.
Countdown tone:
There are 2 beeps every minute.
in the last minute:
50 seconds=1 beep.
40 seconds=1 beep.
30 seconds=2 beeps.
20 seconds=2 beeps.
10 seconds and less=1 beep every second with zero being 1 second long beep. Timer function automatically starts.
Timer:
After countdown has finished the timer starts automatically.
The central timing hand indicates the minutes with 1 step every 12 seconds. The hour/minutes counter sub-dial indicates the hours up to a maximum of 96.
Press the 4 o'clock button to see the timer seconds [display lasts up to a minute].
Press the 4 o'clock button to see the timer hours.
The timer has a maximum time of 96 hours [4 days] after which the hour/seconds sub-dial counter will stay at 0 and the central timing hand will stay at 12.
Start/Stop Timer:
Press the 2 o'clock button to stop the timer. You will hear 1 beep.
Press the 2 o'clock button to resume the timer. You will hear 2 beeps.
Setting the Countdown & Timer:
Countdown reset:
Press the 2 o'clock button to stop the countdown. You will hear 1 beep.
Press the 4 o'clock button to reset.
Setting the Timer:
Press the 2 o'clock button to stop the timer. The hour/seconds counter sub-dial will show the elapsed hours and the central timing hand the elapsed minutes.
Press the 4 o'clock button to view the seconds elapsed on the hour/seconds counter sub-dial.
Resetting the Hands:
If the hands do not zero correctly, which might occur after a battery change or a violent shock, you can make adjustments by doing the following settings as long as the countdown is not in operation.
To correct the hour/seconds counter sub-dial, pull the crown out to position 2 and wait 1 second.
Press either the 2 or 4 o'clock button; the central timing hand will turn and stop [not necessarily at 12].
Press the 2 o'clock button to increment the hours/seconds counter sub-dial hand to position it at 60.
To correct the central timing hand, press the 4 o'clock button to increment the hand to the 12 position.
If the battery had been replaced, the central timing hand defaults to the 10 minute position. If the battery had not been replaced, the central timing hand will return to the previously set position.
Oct 05, 2010 | Watches
How to change the time format from 24 hour to 12 hour in windows 7 thank u.
  • click on Start > Control Panel, and choose Regional and Language Options.
  • Click the Customize button underneath the Standards and formats section.
  • Click on the Time tab and change the time format to H:mm:ss (note the uppercase H) and press OK
  • Below that button, you’ll also see an example of how each setting is currently configured for Number, Currency, Time, Short Date, and Long Date.
  • Type uppercase H or HH to Display time in a 24-hour format
  • Type lowercase h or hh to Display time in a 12-hour format
  • Type two characters, HH or hh to Display leading zeros in single-digit hours
  • Type a single uppercase H, or lowercase letter, such as h, m, or s to suppress the display of leading zeros in single-digit hours, minutes, or seconds
  • Type lowercase t to display a single letter to indicate AM or PM
  • Type lowercase tt to display two letters to indicate AM or PM
  • Type single quotation marks (’) around text to display text
  • Aug 10, 2010 | HP Computers & Internet
    My emachine wont boot up its resets while trying to boot windows i tryed reinstalling windows with the back up disk but it keeps reseting..its a t5248 model with windows vista.. any ideas??
    Go into bios and set it to boot first to the hdd - also set it to default in the bios - and - make sure the TIME is set correctly - sometimes the time get's out of wack and windows will not work right over two hours out of right times
    Apr 01, 2010 | E-Machines eMachines Desktop PC
    Maps
    Let's see if we can FixYa!
    I'm in the United States and this is the first time I have researched this question for anyone.
    (So, don't shoot me if my answer is not correct - I'm just trying to assist you as best I can.) However, if it is correct, please let me know. (Thanks)
    From what I've researched, you may need to download TRAX CENTRAL to your computer. I've included three links, so please review all of the information from all three links to include the owners manual for this program.
    Uniden TRAX CENTRAL is a free PC software program that gives access to a huge array of additional content. It is the only tool you need to manage, update, backup and personalize your Uniden TRAX series.
    - System requirements *
    • Windows 2000, XP or Vista (latest service packs recommended)
    • Pentium III or higher
    • 256 MB RAM, 512 recommended
    • Internet connection
    (preferably broadband - DSL/Cable/LAN) for downloading updates, maps or services
    • The Uniden TRAX CENTRAL software is a 11MB download requiring 2GB of disk space when installed
    • Content downloads require additional storage
    Note: Not compatible with apple Mac
    - Download TRAX CENTRAL Software
    - Download TRAX CENTRAL Installation Guide PDF
    - Download TRAX CENTRAL Operating Manual PDF
    Note: TRAX CENTRAL is only compatible with TRAX Series Uniden Navigation units.
    Benefits from Uniden TRAX CENTRAL
    Stay up-to-date - always get the latest Uniden software and updates.
    Personalize - Points of Interest, routes, voices, colour schemes and more.
    Easy to Use - Uniden TRAX Central is the only tool you'll need to manage your Trax
    Manage your Uniden TRAX CENTRAL on your Computer • Everything on your Uniden TRAX series is visible on your Computer
    • Transfer content between your Uniden TRAX series and your Computer
    • Make and restore back-ups
    • Import destinations and Routes from Google earth.
    Feb 07, 2010 | Uniden TRAX350 Car GPS Receiver
    Windows vista internet problem
    This is not a problem with vista nor the driver. Your network adapter is corrupted. Add a new network adapter.
    Hope this will solve your problem. Keep posting.
    Feb 22, 2009 | Microsoft Windows Vista Ultimate Edition
    Wrong Time
    This appears to be a issue with the Magellan code. The Magellan code is setting Daylight Savings Time according to 2007 rules and not the 2008 rules. Magellan support indicates to change the time zone from Eastern to Central, save it and then put the time zone back to Eastern Time. I do not understand this solution. You can simply uncheck the Daylight Savings Time option and this will put the clock to the correct time. You will need to check the Daylight Savings Time option to put the clock ahead one hour when the clock is off by one hour. Magellan support informs me this is a manual process. Magellan needs to create a fix in their firmware to change the clock according to 2008 Daylight Savings Time when the box is checked.
    Oct 23, 2008 | GPS
    Back ups
    Yes understood, but you need to keep trying and use only dvd not cd-rw cause you need really big space for back-up.With Vista you don't need to do back-up cause it does it internal by it'self
    Jul 31, 2008 | Microsoft Windows Vista Ultimate Edition
    Windows Vista
    check for firmware updates for the gateway/router you have.. There may be an issue, but I dont see how.. if it still isnt work, try to obtain a computer with XP and try it on there to see if you have the same problems..
    Dec 02, 2007 | 2wire 2700HG-B Router (2700HGB)
    Computers & Internet Logo
    48 people viewed this question
    Top HP Computers & Internet Experts
    pontelemon
    pontelemon
    Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
