Question about Sony Handycam DCR-TRV350 Digital Camcorder
Recording when I turn my camcorder on there are no images that appear on camera or the screen it records sound but no images. what can I do
  • 320 Answers
I would bet that the camera iris is stuck closed. On some of the Sony cameras, the iris actuator (a small motor-like device) leaks oil onto the two slippery sheets that slide acrossed one another and act as the iris. A qualified tech can pull the iris assy out and clean it. I have repaired many Sony cameras this way. Sony usually recommends replacing the lens assy which is expensive
Posted on Oct 18, 2008
No image on LCD screen
It sounds like you're receiving partial information on the LCD screen and that the image sensor isn't sending information to the screen.
If you know the sensor is working by recording some video on an SD card and being able to view the recorded video on your PC, then there is a disconnect between the LCD and the image sensor.
If you are not recording video to your SD card and only get black images or no files, the image sensor is damaged.
If you are recording video, but no image appears on your LCD for internal viewing/playback, you can try a firmware update if one is available from www.insigniaproducts.com, but this is a discontinued item so there's not much available for support.
Hope this helps!
Apr 25, 2010 | Insignia NS-DCC5HB09 High Definition Flash...
Black screen
image sensor gone bad... buy a new one...
Feb 16, 2010 | Canon ZR60 Mini DV Digital Camcorder
My JVC-GRd72 camcord - error cap lens error when cap is NOT ON
Replace the CCD base Assy on the optical block assy.
Sep 27, 2009 | JVC GR-D30U Camcorder
Screen sometimes won't show what you are wanting to record.
Its known problem of CCD imager sensor in Canon ZR60 and CCD imager needs to be replaced.
Canon will repair ZR60 free of cost as per announced CCD imager support scheme.
Click Canon CCD Advisory for details.
Good luck.
Jan 13, 2009 | Canon ZR60 Mini DV Digital Camcorder
Nothing appears in view finder or on screen when recording
I HAD THIS PROBLEM ERROR CODE C31 : 22 WOULD COME UP AND TRV 118 CAM WOULD NOT WORK. I TRIED EVERYTHING TILL ONE DAY I BANGED IT ON A CARPETED FLOOR ON THE BOTTOM OF THE CAMCORDER 5 TIMES QUITE HARD. THEN THE CAM WORKED JUST FINE! MY CAM HADN'T WORKED FOR OVER 7 MONTHS. NOW I HAVE IT BACK. HOPE THIS HELPS SOMEONE.
Jun 18, 2008 | Video Cameras
Recorded images has verticle lines
No, most camcorders doesn’t work when you recording the image directly on the screen, that means you use your camcorder shot directly to the screen. Maybe the frequency is different, I have tried used RC plugs directly connect to the VCR and recorded, it is much clear.
Jun 15, 2008 | JVC GR-D22U Camcorder
Recording problem
Knowledge Article C116445
There is no picture or a black screen appears in the viewfinder or LCD when attempting to record. Follow this procedure to troubleshoot if there is no picture or a black screen appears in the viewfinder or LCD when attempting to record. NOTES:
  • Because each of these steps represents a possible solution to this issue, check the viewfinder or LCD status after completing each step.
  • It may be necessary to refer to the operating instructions provided with the camcorder for information on how to perform a task on your specific model.
  1. Ensure the lens cap on the front of the camcorder has been removed.
  2. Ensure a fully-charged battery is inserted in the camcorder.
  3. Ensure the STANDBY/LOCK switch is set to the STANDBY position.
  4. Turn on the camcorder and set it to the CAMERA mode.
  5. Look to see if an image can be seen in the viewfinder or LCD.
  6. IMPORTANT: Some camcorders have both a viewfinder and LCD. To conserve power, the viewfinder and LCD will not display at the same time. To use the viewfinder, the LCD must be closed.
  7. If the issue is not resolved, reset the camcorder to factory specifications.
NOTE: If the issue is still unresolved after completing the troubleshootin
Nov 30, 2007 | Sony Handycam DCR-HC42 Mini DV Digital...
Camcorder Dropped
Sounds like your display screen is broken, but a least it can still record, which is most important; just don't use the zoom feature and point the camera at the action.
Oct 21, 2007 | Sony Handycam DCR-HC42 Mini DV Digital...
Won't record/No picture thru the LCD screen or viewfinder in Record or Standby Mode
it is a common problem with them. sony has a recall on ccd imager for this model. call sony and they will fix it for free
May 29, 2007 | Sony Handycam DCR-TRV22 Mini DV Digital...
Sound is ok, but do not record images.
I have had the same problem since I purchased mine 4 years ago and it has been repaired 3x and is in the shop for a 4th. I had the extended warranty and Futureshop refuses to acknowledge that it is a Lemon and should be replaced as they don't consider resoldering wires as a "repair". My unit has been in the service center a total of 12 weeks over the 4 years. The service center recommends Sony Camcorders and the Claim center said they get few Sony camcorders so I would say the Canon problem is an issue that is common. Sorry to say. Mike
Jan 08, 2007 | Canon Optura 10 Mini DV Digital Camcorder
Sony Handycam DCR-TRV350 Digital Camcorder Logo
80 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
