Question about Presto HeatDish Compact Heater
Presto parabolic buzzes as soon as you turn on.
I have cleaned it, I blew out the coils with compressed air, I removed the back cover to expose the electricals.  I attempted to follow the instructions of another post to by-pass the buzzer, to no avail.  I reconnected everything, put it back together, as originally came,  and for now it is working without a problem.  I have no idea what I did to make it work properly, which is really frustrating! Is it possible that just removing and replacing the inside connections may have removed some resistance and therefore allowing it to function as it should? Am verrrrry curious! jim
  • fredsmith0 Apr 23, 2009
    My heatdish buzzes on Mwed after 15 to 20 mins, have been real pleased with it over the many years weve had it about 15, maybee irts finished but the heat er still works great, and it just started, and u give me a clue as to how to fix the zubzzing, im purchasing a new one but if i can fix this one we can still use it also thanks Fred
  • 56 Answers
You may have gotten the "tip switch" conections back on a little tighter but sounds like you are going to have the same problem later on. if this is the case I have given a step by step fix for this just find my solution and follow the steps and "presto" its fixed forever.
Posted on Dec 25, 2008
  • Gregory Stobbe
    Gregory Stobbe Dec 27, 2008
    You may also want to rewire the whole thing and eliminate all of the "braker" switches and go with the good ole on / off switch. This would effectivly make the heat selector switch on the top of the heater the only means of controlling the temp or wether it is on or off. If you need help rewiring the unit repost and ask me its pretty simple.
Have a GFSF6KEXAWW and would like advice on cleaning the coils. Do I need to remove the back cover?
Yes ,remove the back and front cover and use a well direct burst of compressed air to clean the coils. You can use a brush, but the best cleaning method can only be effected with compressed air.
Dec 23, 2010 | GE Refrigerators
RE: Presto Heat Dish buzzer going off
I almost threw my heater out! I cleaned this morning with Window Cleaner and it works just fine now. It was just dust. I cleaned the round metal area not the coils.
Hope this helps.
Emailed Presto about replacing the buzzer and here is the answer I got:
There is no such part. Buzzer sounds when heater:
- is tipped
- rests uneven on floor
- is too close to furniture or wall
- has too much dust on parabolic dish
The most common reason is that the parabolic dish is dusty.
To clean the heater:
1. Unplug the heater and clean it when it is cool
2. Spray a cloth with an all-purpose cleaner such as 409
3. Wrap the cloth around a long handle such as a wooden spoon
4. Wipe between the grate from the outer edge to the center
If you have further questions, please let me know. Or call us at 1-800-877-0441 Monday through Friday 8:00 a.m. to 4:30 p.m. Central Time.
Jan 11, 2010 | Presto HeatDish Compact Heater
Buzzer goes off
This was the answer from Presto as I had the same problem. Cleaned it with window cleaner and a wooden spoon and paper towels and now it works great!
- is tipped
Dec 29, 2009 | Presto HeatDish Compact Heater
How to clean dish? Safety grate covering face of dish does not appear to have a way to remove it so backed on dist can be removed and heat dish can be returned to near new condition. Thanks, Mike
This is the answer I got from Presto. I cleaned it with window cleaner, wooden spoon and paper towels. Dish works great now.
- is tipped
Dec 21, 2009 | Presto HeatDish Compact Heater
Is there a way to disconnect the alarm on my Presto parabolic heater? It comes on and works for about 5 minutes and then the alarm goes off. We are adults - no children around.
- is tipped
Dec 06, 2009 | Presto HeatDish Compact Heater
Please give me the number on how to purchase dust remover that came in presto heat dish box. Thank you!
- is tipped
Oct 25, 2009 | Presto HeatDish Compact Heater
Presto parabolic makes loud buzzing sound after a few minutes of
The metal dish must be dust free or it will transfer heat to the safety device. If this is not the solution call customer service at 800-877-0441
Jan 13, 2009 | Presto Like Parabolic Heater Heat Dish
PrestoPresto HeatDish Parabolic Electric Space Heater Plus Footlight
  • My Presto Heatdish has noise time after time after turn on. How can I fix this problem? Thanks.
Jun 21, 2007 | Presto HeatDish Compact Heater
Cleaning the dish on my Presto space heater.
I pried the upper rim with needle nosed pliers --,just enough to get the grid off. After cleaning with Mister Bubbles, I popped the grid back in and bent the rim back down. I then took a hammer and
smoothed the rough edges. Looks almost like new!!
Feb 26, 2007 | Presto HeatDish Compact Heater
How do I clean coils?
It is very important to clean condenser coils on forced-air refrigerators such as side-by-side and built-in models at least twice a year (if you have a refrigerator with the black coils mounted on the back, these coils don't require semi-annual cleaning). Here's how to do it: 1) Pull the refrigerator away from the wall and unplug it or, if it's a built-in model, turn off its circuit breaker. 2) Remove the cover panel to reveal the coils. On most models, the kick plate or top trim plate simply lifts off. You may have to remove a few screws to remove a back cover. 3) With a long, narrow nozzle on your vacuum, clean out all of the dust and debris (at an appliance parts store, you can also buy a special, long-handled brush that looks somewhat like a bottle brush for this job). 4) Replace the cover, and then plug the electrical cord back in or turn the circuit back on.
Jan 18, 2006 | Hoover HCA331FFK
Presto HeatDish Compact Heater Logo
286 people viewed this question
Top Presto Heating & Cooling Experts
Mack Baxter
Starnley Johnwells
Starnley Johnwells
Paul Carew
Are you a Presto Heating and Cooling Expert? Answer questions, earn points and help others
