Question about HP DeskJet 710c InkJet Printer
Color problems when i print out a photo it comes out with a blue haze & yellow does not show up at all?i have cleaned/primed & reset the cartridges any ideas? i am running windows xp.Thanks
  • 432 Answers
Try it with a different software package. Also try different paper.
Posted on Jun 26, 2007
I have never used the Photo ink Cartridge #58. It intal pic shows putting it where the black one goes-does this mean I would use the color and the photo one at the same time instead of the black one?
Yes correct.The photo cartridge has to be inserted, where you install black cartridge.The photo cartridge gives finishing touch to the photos which you print.The actual photo comes from the color cartridge only, but for lightness and darkness, the color(ink) from photo cartridge gets used.In photo cartridge there are three color ink, that are light pink, light blue and grayish black.In color cartridge there are three color ink, that are pink(magenta), yellow and cyan( blue).------------- This are the details.Thank you for using fixya.
Mar 24, 2011 | HP Deskjet F340 All-In-One Printer
My Canon Pixma MP210 prints only red and blue while the yellow color tank is still full. I tried cleaning, no results. The yellow ink is coming out on the clothing when I clean but still no yellow on the...
Canon makes it ******* owners by using a small electronic chip on each cartridge that opens when it is taken out of the printer. Sometimes removing a cartridge will not open and when replaced in the print head, it works, but if the cartridge sensor fails to communicate with the printer, you would need a resetting device to bring the cartridge back to normal. Rather than become upset with the issue, it would be best to get a new cartridge from any reseller on the internet (not Canon) and go from there.
Feb 20, 2018 | Canon PIXMA MP210 Photo All-In-One Printer
I just replaced the Yellow and the Photo Magenta cartridge in my Canon i900D printer as the computer advised. However, now my photos are coming out with green hair, lips and the other colors are not...
I would first try cleaning the print head, it is possible that print nozzles are clogged and simply not enough ink is able to make its way onto the media.
If the nozzle check page looks good I would try printing some full bleed color pages and see what it does, it is possible,but not likely, that there is either a air bubble in the ink system that could prevent ink flow. If this is true there should be a function for "priming the print head" and it should solve the problem.
Good luck.
Mar 18, 2010 | Canon Office Equipment & Supplies
Printed pages have blank lines in the print for the red, blue and yellow colors. Have tried cleaning and deep cleaning several times. No change.
If cartridge is good, prime and allign, remove cartridge and clean copper contacts with contact cleaner, if all fails replace printer.
Dec 17, 2009 | Canon MP610 Photo All-In-One Printer
Color on photos suddenly has a blue - purple wash with no greens
Your yellow cartridge is probably not working as your photos suggest. Remove and reinsert the yellow cartridge. Try printing only yellow color.
Your printer has a separate head for printing; the nozzle for yellow ink might be clogged. Try running a head cleaning routine from your printer software.
Sep 15, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
IS THERE A SPECIAL CARTRIDGE FOR PHOTO PRINTING. MY PRINTS COME OUT WITH A BLUE TINGE TO THEM my printer takes No. 32 black and 33 colour..
Sir,
Your problem is not of specially cartrigde but what you need is a special Paper which is made to print Photos and other colour full pictures. If you see is not this problem then there is chance that your cartridge is leaking from blue color point as there are three inks in color cartridge Red,Blue and yellow , than you need to replace you colou cartridge with new one .
Aug 28, 2009 | Office Equipment & Supplies
Despite installing new cartridges,cleaning and priming, my HP Deskjet 710C prints pink only. Using Windows XP test page shows no blue, or yellow.
hi,
do you installing both cartridges (black and colour)?
if you do so, my advice is to reinstall the driver for your printer.
if you install ONLY the black cartridge, and the color cartridge remain the old one, (which in my opinion is the present case), your problem is from the color cartridge.
The color cartridge have 3 colors and this are: cyan (some kind of blue), yellow and magenta (similar with a pink color, but more intense). The problem is simple: in your color cartridge has left only the magenta color, cyan and yellow tanks are empty.
have 2 options:
1. buy a new color cartridge
2. refill the color cartridge.
Sep 23, 2008 | HP Office Equipment & Supplies
Lexmark X83 printer has streaks printing color pictures (but text is fine)
This is the problem with the cartridge if you brought original Lexmark cartridge you can get it exchanged as the cartridge is nay be defective and the cartridge comes with one year warranty...........................................
Jun 02, 2008 | Lexmark X83 All-In-One InkJet Printer
Printer color problem
The ink cartridge cleaning process can be performed even with the alignment message showing in the display. Follow the steps below to perform an ink cartridge cleaning process from the front panel:
  1. On the front panel, press Menu or Setup (depending on the model).
  2. Press the Right Arrow (>) until Maintenance or Tools appears, and then press the Enter or OK .
  3. Clean ink Cartridges should appear in the display. Press Enter or OK to begin the cartridge cleaning process. A page will be printed during the cleaning process with all of the colors on it. If any of the colors or the black are missing, faded, or streaked on the alignment page, there is a ink cartridge problem.
Nov 30, 2007 | HP PSC 2110 All-In-One InkJet Printer
All colors print blue
You did the right thing. Sometimes a bad printhead or a bad cartridge will cause a leak and will damage both. Good job!
Jun 05, 2007 | Canon i850 InkJet Photo Printer
HP DeskJet 710c InkJet Printer Logo
120 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
