Bunn NHB Coffee Maker
Problem for Bunn NHB Coffee Maker
Bunn coffee unit leaking
By rjkatje on Oct 18, 2008
Same Problem
Dec 20, 2008
-   Our Bunn coffee maker drips water for quite some time after the coffee is made and after we remove the coffee filter. It eventually stops dripping, but many times will drip right when we pick up the carafe to pour a cup.-   Guest
Oct 30, 2008
-   Ditto...I have the same problem it IS getting worse every day!
Sad :o(-   Guest
Oct 24, 2008
-   My pot is also leaking - it seems to be getting worse daily.-   psmallwood
Oct 24, 2008
-   My bunn pot leaks when I put water in tank -   mwethington5
Solution #1
posted on Feb 11, 2009
Somewhat Helpful)
furnoptn
Rank: Guru
Rating: 89%, 68 votes
most likely this is leaking out of the plastic tray where you pour the water in. this can be replaced, but you will have to call your local Bunn repair shop to see if they have a used one there, because Bunn will not ship parts for the home brewers. If you are within your warranty period of three years, give Bunn a call at 1-800-263-2256 and ask forwarranty department.
Was this helpful?
Yes
No
Popular Solutions for Bunn NHB Coffee Maker
Questions and Unsolved Problems for Bunn NHB Coffee Maker
Do you recommend Bunn NHB Coffee Maker?
Answer
Answer
The top burner on our bunn coffee maker is getting to hot, causing the coffee to pop, do you have... (More)
Answer
How much water do I put in resivior to start the coffee pot.
Answer
I have a small water leak at the back of the coffee pot. Water is coming from inside the coffee pot.... (More)
Answer
when water is put in the maker, it will leak about a cup. can it be fixed
Answer
my bunn coffee pot is leeaking water out the holding pot, then it onloy makes half a pot of coffee... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Bunn NHB Coffee Maker:
Top Coffee and Esp... Experts
Rank: Guru Guru
Solutions: 1582
Experience: I run a Full-time Appliance Service Co.with HVAC/Auto Air Conditioning and Small Engine Service.
Ask Me
Find more Coffee and Esp... Experts
Top Small Appliance Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
